04-03-2013 05:06 AM - edited 03-21-2019 10:01 AM
I have an SPA8000 Bridged to a ADSL2+ Modem and the SPA8000 performs PPPoE Authentication. If there is a drop in the service, it will automatically redial back in, however if there is an extended outage (eg. Loss of Line Sync, Carrier Issues) the SPA8000 will refuse to reconnect automatically without intervention (eg. Rebooting).
The SPA8000 is running version 6.1.11, some basic settings:
Under WAN:
WAN Type: PPPoE
DNS Server: Manual
Username and Password are setup as per the PPPoE Account Details.
Everything is default.
Under Voice:
SIP Registry Expires on the Line are set to 600 seconds, Provider SIP Proxy is set along (DNS Based not IP Address) with Username and Password - everything else is left as default.
This is been tested on 3 separate SPA8000 devices experencing the same issue. NAT Keep Alive has been toggled to no success either.
Are you able to provide insight into this? I can supply further information if required.
David
04-03-2013 07:59 AM
Have you updated the firmware on the DSL modem?
Are there any log messages on the dsl modem?
I would suggest setting up syslog and debug so you can see the messages coming out of one of the spa8000s,
set up a syslog server to capture those messages, I like tftpd32 or solarwinds free syslog server. The syslog server will have to be attached to the aux port, because the other port is down at that point.
then post the messages. there may be a something we can look up it may show the issue.
To enable logging on the spa in the GUI go to
Voice --> system
add the IP address of your log server in the debug and syslog, set debug level =3
** you don't need for this issue, but to enable sip debugging **
Go into the extension --> sip settings --> sip debug option to full
This will allow you to get all the sip messages between the call manager and the ATA.
** you don't need for this issue **
To set up syslog and debug through provisioning add lines similar to these to the config
SPA1x2 device:
You can also call 866-606-1866 and open a case with the small business TAC to follow up with this issue.
Dan
04-23-2013 12:59 AM
Hi Dan,
Apologies for the late reply to this message - I had to setup a test environment to emulate this problem. It appears there is a problem where by the SPA8000 (and this may apply to other models as well) does not try to re-authenticate again after initially retrying 4 Times (in quick 2 second increments) after receiving an Invalid Username/Password Response or Timeout from a PPPoE Server or LNS. It does however work if there it does not respond to a PPPoE discovery (eg. Unplugging the Ethernet Cable between the SPA8000 and the Modem/NTU or there is no communication between the network and Modem/NTU).
Here are the debug logs from where it did not try to re-authenticate and the only requests that I had back on the LNS. In this example the SIP Registry Expiry was set to 600 seconds and I changed the Password that it originally connected with and dropped/cleared the connection from the LNS. I waited the full 600 seconds and the PPPoE did not try again to re-authenticate.
The Logs don't seem to indicate much (and I have changed IP Addresses/Hostnames in the below logs as well):
<134>M2: System started: ip@192.168.0.3, reboot reason:H0
192.168.0.3 23/04 17:10:32.642
<143>M2: subnet mask: 255.255.255.0
<143>M2: gateway ip: 192.168.0.1
<143>M2: dns servers(1): 192.168.0.3 23/04 17:10:32.642
<143>M2: 192.168.0.1 192.168.0.3 23/04 17:10:32.642
<143>M2:
<159>M0: IDBG: st-0
192.168.0.1 23/04 17:10:32.682
<159>M2: mslink server task up (2)
192.168.0.3 23/04 17:10:34.422
<134>M3: System started: ip@192.168.0.4, reboot reason:H0
192.168.0.4 23/04 17:10:35.793
<143>M3: subnet mask: 255.255.255.0
<143>M3: gateway ip: 192.168.0.1
<134>M1: System started: ip@192.168.0.2, reboot reason:H0
192.168.0.2 23/04 17:10:35.793
<143>M3: dns servers(1): 192.168.0.4 23/04 17:10:35.793
<143>M3: 192.168.0.1 192.168.0.4 23/04 17:10:35.793
<143>M1: subnet mask: 255.255.255.0
<143>M3:
<143>M1: gateway ip: 192.168.0.1
<143>M1: dns servers(1): 192.168.0.2 23/04 17:10:35.793
<143>M1: 192.168.0.1 192.168.0.2 23/04 17:10:35.793
<143>M1:
<159>M3: mslink server task up (3)
192.168.0.4 23/04 17:10:37.493
<159>M1: mslink server task up (1)
192.168.0.2 23/04 17:10:37.533
<159>M1: IDBG: st-0
192.168.0.2 23/04 17:10:38.203
<159>M1: fs:008275:008693:131072
192.168.0.2 23/04 17:10:38.303
<159>M1: fls:af:1:0:0
<159>M1: fbr:0:3000:3000:03985:0002:0001:6.1.12
<159>M1: PLKUP: 8192, 2102, 12, 1.5
192.168.0.2 23/04 17:10:38.333
<159>M1: fu:0:3997, 0003 0001
192.168.0.2 23/04 17:10:38.483
<159>M2: IDBG: st-0
192.168.0.3 23/04 17:10:39.093
<159>M2: fs:008200:008342:131072
192.168.0.3 23/04 17:10:39.193
<159>M2: fls:af:1:0:0
<159>M2: fbr:0:3000:3000:0358b:0002:0001:6.1.12
<159>M2: PLKUP: 8192, 2102, 12, 1.5
192.168.0.3 23/04 17:10:39.223
<159>M2: fu:0:359d, 0003 0001
192.168.0.3 23/04 17:10:39.373
<159>M2: mslink client task (2) gw=192.168.0.1 ip=192.168.0.3
192.168.0.3 23/04 17:10:39.423
<159>M0: MSLINK module 2 is at 192.168.0.3
192.168.0.1 23/04 17:10:40.164
<159>M3: IDBG: st-0
192.168.0.4 23/04 17:10:40.174
<159>M0: MSLINK code module 2: 0(32) sn:0
192.168.0.1 23/04 17:10:40.214
<159>M3: fs:008200:008351:131072
192.168.0.4 23/04 17:10:40.254
<159>M3: fls:af:1:0:0
192.168.0.4 23/04 17:10:40.264
<159>M3: fbr:0:3000:3000:04219:0002:0001:6.1.12
<159>M3: PLKUP: 8192, 2102, 12, 1.5
192.168.0.4 23/04 17:10:40.284
<159>M3: fu:0:422b, 0003 0001
192.168.0.4 23/04 17:10:40.444
<159>M3: mslink client task (3) gw=192.168.0.1 ip=192.168.0.4
192.168.0.4 23/04 17:10:42.484
<159>M1: mslink client task (1) gw=192.168.0.1 ip=192.168.0.2
192.168.0.2 23/04 17:10:42.524
<159>M0: MSLINK module 3 is at 192.168.0.4
192.168.0.1 23/04 17:10:43.234
<159>M0: MSLINK module 1 is at 192.168.0.2
192.168.0.1 23/04 17:10:43.374
<159>M0: MSLINK code module 3: 0(32) sn:0
<159>M0: MSLINK code module 1: 0(32) sn:0
192.168.0.1 23/04 17:10:43.864
<159>M0: fs:025125:025125:131072
192.168.0.1 23/04 17:10:47.215
<159>M0: fls:af:1:0:0
<159>M0: fbr:1:3000:3000:17329:0004:0005:6.1.12
<159>M0: fhs:01:0:0001:upg:app:0:5.1.10
192.168.0.1 23/04 17:10:47.225
<159>M0: fhs:02:0:0002:upg:app:1:5.1.10
192.168.0.1 23/04 17:10:47.275
<159>M0: fhs:03:0:0003:upg:app:2:5.1.10
192.168.0.1 23/04 17:10:47.315
<159>M0: fhs:04:0:0004:upg:app:0:6.1.12
192.168.0.1 23/04 17:10:47.385
<159>M0: fhs:05:0:0005:upg:app:1:6.1.12
192.168.0.1 23/04 17:10:47.405
<159>M0: fhs:06:0:0006:upg:app:2:6.1.12
192.168.0.1 23/04 17:10:47.435
<159>M0: PLKUP: 8192, 2102, 12, 1.5
192.168.0.1 23/04 17:10:47.525
<159>M0: fu:1:733b, 0003 0001
192.168.0.1 23/04 17:10:47.885
<159>M0: mslink P:12831 V:55495
192.168.0.1 23/04 17:11:00.106
<159>M1: CC_init
192.168.0.2 23/04 17:11:02.516
<134>M1: SLIC is si3215
192.168.0.2 23/04 17:11:02.606
<159>M1: IDBG[0]:4
192.168.0.2 23/04 17:11:03.107
<159>M1: IDBG[1]:4
<159>M2: CC_init
192.168.0.3 23/04 17:11:03.407
<134>M2: SLIC is si3215
192.168.0.3 23/04 17:11:03.487
192.168.0.3 23/04 17:11:03.497
<159>M2: IDBG[0]:4
192.168.0.3 23/04 17:11:03.997
<159>M2: IDBG[1]:4
<134>M1: [0]Reg Addr Change(0) 0:0->a800104:6060
192.168.0.2 23/04 17:11:04.237
<134>M1: [1]Reg Addr Change(0) 0:0->a800104:6060
192.168.0.2 23/04 17:11:04.247
<159>M3: CC_init
192.168.0.4 23/04 17:11:04.477
<134>M3: SLIC is si3215
192.168.0.4 23/04 17:11:04.557
192.168.0.4 23/04 17:11:04.567
<159>M3: IDBG[0]:5
192.168.0.4 23/04 17:11:05.057
<159>M3: IDBG[1]:3
<159>M0: CC_init
192.168.0.1 23/04 17:11:05.957
<134>M0: SLIC is si3215
192.168.0.1 23/04 17:11:06.517
192.168.0.1 23/04 17:11:06.527
<159>M0: IDBG[0]:6
192.168.0.1 23/04 17:11:07.017
<159>M0: IDBG[1]:4
<159>M1: [0]RegFail. Retry in 30
192.168.0.2 23/04 17:11:36.231
<159>M1: [1]RegFail. Retry in 30
192.168.0.2 23/04 17:11:36.241
<151>M1: CID:OSI
192.168.0.2 23/04 17:11:38.231
<151>M1: CID:OSI
192.168.0.2 23/04 17:11:38.241
<151>M1: CID:OnHookTx Pol
192.168.0.2 23/04 17:11:38.491
192.168.0.2 23/04 17:11:38.501
<151>M1: Start DTMF/FSK
192.168.0.2 23/04 17:11:38.792
<151>M1: CID:DONE
192.168.0.2 23/04 17:11:39.232
<151>M1: CID:DONE
192.168.0.2 23/04 17:11:39.242
<134>M0: System started: ip@10.128.1.4, reboot reason:H0
192.168.0.1 23/04 17:11:46.632
<143>M0: subnet mask: 255.255.255.255
<143>M0: gateway ip: 10.128.1.254
192.168.0.1 23/04 17:11:46.642
<143>M0: dns servers(2): 192.168.0.1 23/04 17:11:46.642
<143>M0: 4.2.2.1 192.168.0.1 23/04 17:11:46.642
<143>M0:
192.168.0.1 23/04 17:11:46.652
<134>M0: [0]Reg Addr Change(0) 0:0->a800104:6060
192.168.0.1 23/04 17:11:46.883
<134>M0: [1]Reg Addr Change(0) 0:0->a800104:6060
192.168.0.1 23/04 17:11:46.893
<134>M0: [2]Reg Addr Change(0) 0:0->7dfe3007:5060
192.168.0.1 23/04 17:11:46.933
<134>M0: [2]->10.10.10.7:5060(577)
192.168.0.1 23/04 17:11:46.943
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5060(486)
192.168.0.1 23/04 17:11:46.953
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5060(395)
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(485)
192.168.0.1 23/04 17:11:46.963
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5061(394)
<134>M0:
<134>M0:
<159>M0: [0]RegOK. NextReg in 2130706430 (1)
<159>M0: [1]RegOK. NextReg in 2130706430 (1)
<134>M0: [pxy]<<127.0.0.1:5060(426)
192.168.0.1 23/04 17:11:46.973
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5060(363)
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5060(463)
<134>M0:
192.168.0.1 23/04 17:11:46.983
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(426)
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5061(363)
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5061(463)
<134>M0:
<134>M0:
<151>M0: [0]SubOK
<151>M0: NextSub in 2147483646 (1)
192.168.0.1 23/04 17:11:46.993
<151>M0: [1]SubOK
<134>M0: [2]<<10.10.10.7:5060(545)
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5060(352)
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(352)
<134>M0:
<134>M0:
<134>M0: [2]->10.10.10.7:5060(745)
<134>M0:
192.168.0.1 23/04 17:11:47.003
<134>M0:
<134>M0: [2]<<10.10.10.7:5060(566)
192.168.0.1 23/04 17:11:47.053
<134>M0:
<134>M0:
192.168.0.1 23/04 17:11:47.063
<159>M0: [2]RegOK. NextReg in 594 (1)
<151>M0: CID:OSI
192.168.0.1 23/04 17:11:48.973
<151>M0: CID:OSI
192.168.0.1 23/04 17:11:48.983
<151>M0: CID:OnHookTx Pol
192.168.0.1 23/04 17:11:49.233
192.168.0.1 23/04 17:11:49.243
<151>M0: Start DTMF/FSK
192.168.0.1 23/04 17:11:49.533
192.168.0.1 23/04 17:11:49.543
<151>M0: CID:DONE
192.168.0.1 23/04 17:11:49.983
<151>M0: CID:DONE
192.168.0.1 23/04 17:11:49.993
<134>M0: [pxy]<<192.168.0.2:5160(487)
192.168.0.1 23/04 17:12:06.235
<134>M0:
<134>M0:
<134>M0: [pxy]->192.168.0.2:5160(398)
192.168.0.1 23/04 17:12:06.245
<134>M0:
<134>M0:
192.168.0.1 23/04 17:12:06.255
<134>M0: [pxy]<<192.168.0.2:5161(487)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:12:06.265
<159>M1: [0]RegOK. NextReg in 2130706430 (1)
192.168.0.2 23/04 17:12:06.265
<134>M0: [pxy]->192.168.0.2:5161(398)
192.168.0.1 23/04 17:12:06.275
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5160(426)
<134>M0:
<134>M0:
<159>M1: [1]RegOK. NextReg in 2130706430 (1)
192.168.0.2 23/04 17:12:06.275
<134>M0: [pxy]->192.168.0.2:5160(363)
192.168.0.1 23/04 17:12:06.285
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5160(464)
<134>M0:
<134>M0:
<151>M1: [0]SubOK
192.168.0.2 23/04 17:12:06.285
<151>M1: NextSub in 2147483646 (1)
<134>M0: [pxy]<<192.168.0.2:5161(427)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:12:06.295
<134>M0: [pxy]->192.168.0.2:5161(364)
<134>M0:
<134>M0:
<151>M1: [1]SubOK
192.168.0.2 23/04 17:12:06.295
<134>M0: [pxy]->10.128.1.4:5161(464)
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5160(352)
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5161(353)
<134>M0:
192.168.0.1 23/04 17:12:06.305
<134>M0:
<151>M0: IDBG: pppld
192.168.0.1 23/04 17:12:26.798
<151>M0: [2]SIP:ICMP Error -1 (7dfe3007:5060, 8)
192.168.0.1 23/04 17:21:41.045
<134>M0:
<134>M0:
<159>M0: RSE_DEBUG: getting alternate from domain:sip.siptest.com
192.168.0.1 23/04 17:21:41.055
<159>M0: [2]RegFail. Retry in 30
192.168.0.1 23/04 17:22:11.049
192.168.0.1 23/04 17:22:11.059
192.168.0.1 23/04 17:22:11.069
<134>M0:
<134>M0:
core-rtr#
Apr 23 07:12:28.636: %LINK-3-UPDOWN: Interface Virtual-Access78, changed state to down
Apr 23 07:12:29.636: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access78, changed state to down
Apr 23 07:12:33.688: ppp261 PPP: Authorization required
Apr 23 07:12:33.692: ppp261 PPP: Authorization required
Apr 23 07:12:33.732: ppp261 CHAP: O CHALLENGE id 2 len 29 from "core-rtr"
Apr 23 07:12:33.776: ppp261 CHAP: I RESPONSE id 2 len 55 from "voicetest@test.com"
Apr 23 07:12:33.776: ppp261 PPP: Sent CHAP LOGIN Request
Apr 23 07:12:35.776: ppp261 PPP: Received LOGIN Response FAIL
Apr 23 07:12:35.776: ppp261 CHAP: O FAILURE id 2 len 25 msg is "Authentication failed"
Apr 23 07:12:37.788: ppp262 PPP: Authorization required
Apr 23 07:12:37.832: ppp262 CHAP: O CHALLENGE id 2 len 29 from "core-rtr"
Apr 23 07:12:37.872: ppp262 CHAP: I RESPONSE id 2 len 55 from "voicetest@test.com"
Apr 23 07:12:37.872: ppp262 PPP: Sent CHAP LOGIN Request
Apr 23 07:12:39.872: ppp262 PPP: Received LOGIN Response FAIL
Apr 23 07:12:39.872: ppp262 CHAP: O FAILURE id 2 len 25 msg is "Authentication failed"
Apr 23 07:12:41.880: ppp263 PPP: Authorization required
Apr 23 07:12:41.924: ppp263 CHAP: O CHALLENGE id 2 len 29 from "core-rtr"
Apr 23 07:12:41.964: ppp263 CHAP: I RESPONSE id 2 len 55 from "voicetest@test.com"
Apr 23 07:12:41.964: ppp263 PPP: Sent CHAP LOGIN Request
Apr 23 07:12:43.968: ppp263 PPP: Received LOGIN Response FAIL
Apr 23 07:12:43.968: ppp263 CHAP: O FAILURE id 2 len 25 msg is "Authentication failed"
Apr 23 07:12:45.980: ppp264 PPP: Authorization required
Apr 23 07:12:46.020: ppp264 CHAP: O CHALLENGE id 2 len 29 from "core-rtr"
Apr 23 07:12:46.064: ppp264 CHAP: I RESPONSE id 2 len 55 from "voicetest@test.com"
Apr 23 07:12:46.064: ppp264 PPP: Sent CHAP LOGIN Request
Apr 23 07:12:48.064: ppp264 PPP: Received LOGIN Response FAIL
Apr 23 07:12:48.064: ppp264 CHAP: O FAILURE id 2 len 25 msg is "Authentication failed"
core-rtr#
Here is the log from a successful reauthentication AFTER the modem/NTU had lost connectivity to the network:
192.168.0.2 23/04 17:26:12.220
<143>M1: dns servers(1): 192.168.0.2 23/04 17:26:12.220
<143>M1: 192.168.0.1 192.168.0.2 23/04 17:26:12.220
<143>M1:
192.168.0.2 23/04 17:26:12.290
<159>M0: IDBG: st-0
192.168.0.1 23/04 17:26:12.430
192.168.0.4 23/04 17:26:14.390
<143>M3: dns servers(1): 192.168.0.4 23/04 17:26:14.400
<143>M3: 192.168.0.1 192.168.0.4 23/04 17:26:14.400
<143>M3:
192.168.0.3 23/04 17:26:14.400
<143>M2: dns servers(1): 192.168.0.3 23/04 17:26:14.400
<143>M2: 192.168.0.1 192.168.0.3 23/04 17:26:14.400
<143>M2:
192.168.0.3 23/04 17:26:16.190
192.168.0.4 23/04 17:26:16.260
192.168.0.2 23/04 17:26:16.280
192.168.0.1 23/04 17:26:17.010
192.168.0.1 23/04 17:26:17.060
<159>M1: IDBG: st-0
192.168.0.2 23/04 17:26:18.240
192.168.0.2 23/04 17:26:18.330
<159>M1: fbr:0:3000:3000:03997:0002:0001:6.1.12
192.168.0.2 23/04 17:26:18.370
<159>M1: fu:0:39a9, 0003 0001
192.168.0.2 23/04 17:26:18.540
<159>M2: IDBG: st-0
192.168.0.3 23/04 17:26:18.860
192.168.0.3 23/04 17:26:18.960
<159>M2: fbr:0:3000:3000:0359d:0002:0001:6.1.12
192.168.0.3 23/04 17:26:18.990
<159>M2: fu:0:35af, 0003 0001
192.168.0.3 23/04 17:26:19.150
<159>M3: IDBG: st-0
192.168.0.4 23/04 17:26:19.931
192.168.0.4 23/04 17:26:20.021
<159>M3: fbr:0:3000:3000:0422b:0002:0001:6.1.12
192.168.0.4 23/04 17:26:20.051
<159>M3: fu:0:423d, 0003 0001
192.168.0.4 23/04 17:26:20.211
192.168.0.4 23/04 17:26:20.251
192.168.0.1 23/04 17:26:20.991
192.168.0.1 23/04 17:26:21.041
192.168.0.3 23/04 17:26:21.181
192.168.0.1 23/04 17:26:22.262
192.168.0.1 23/04 17:26:22.332
192.168.0.1 23/04 17:26:26.852
<159>M0: fbr:1:3000:3000:1733b:0004:0005:6.1.12
192.168.0.1 23/04 17:26:26.882
192.168.0.1 23/04 17:26:26.922
192.168.0.1 23/04 17:26:26.962
192.168.0.1 23/04 17:26:26.992
192.168.0.1 23/04 17:26:27.032
192.168.0.1 23/04 17:26:27.132
<159>M0: fu:1:734d, 0003 0001
192.168.0.1 23/04 17:26:27.442
<159>M0: mslink P:12222 V:58850
192.168.0.1 23/04 17:26:39.354
<159>M1: CC_init
192.168.0.2 23/04 17:26:42.275
192.168.0.2 23/04 17:26:42.355
<159>M1: IDBG[0]:4
192.168.0.2 23/04 17:26:42.845
<159>M1: IDBG[1]:4
<159>M2: CC_init
192.168.0.3 23/04 17:26:43.175
192.168.0.3 23/04 17:26:43.255
<159>M2: IDBG[0]:4
192.168.0.3 23/04 17:26:43.745
<159>M2: IDBG[1]:3
192.168.0.2 23/04 17:26:43.985
<159>M3: CC_init
192.168.0.4 23/04 17:26:44.245
192.168.0.4 23/04 17:26:44.325
<159>M3: IDBG[0]:5
192.168.0.4 23/04 17:26:44.815
<159>M3: IDBG[1]:4
<159>M0: CC_init
192.168.0.1 23/04 17:26:45.715
192.168.0.1 23/04 17:26:46.275
<159>M0: IDBG[0]:6
192.168.0.1 23/04 17:26:46.755
<159>M0: IDBG[1]:4
192.168.0.1 23/04 17:26:46.765
192.168.0.1 23/04 17:27:13.110
192.168.0.1 23/04 17:27:13.120
<143>M0: gateway ip: 125.254.48.254
<143>M0: dns servers(2): 192.168.0.1 23/04 17:27:13.120
<143>M0: 4.2.2.1 192.168.0.1 23/04 17:27:13.120
<143>M0: 4.2.2.2 192.168.0.1 23/04 17:27:13.120
<143>M0:
192.168.0.1 23/04 17:27:13.370
192.168.0.1 23/04 17:27:13.420
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5060(485)
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5060(394)
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(486)
192.168.0.1 23/04 17:27:13.430
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5061(395)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:27:13.440
<134>M0: [pxy]<<127.0.0.1:5060(433)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:27:13.450
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(425)
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5061(362)
192.168.0.1 23/04 17:27:13.460
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<151>M0: [0]SubOK
<151>M0: [1]SubOK
192.168.0.1 23/04 17:27:13.470
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5060(351)
192.168.0.1 23/04 17:27:13.480
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(350)
<134>M0:
<134>M0:
<134>M0:
<134>M0:
192.168.0.1 23/04 17:27:13.550
<134>M0:
<134>M0:
<151>M0: CID:OSI
192.168.0.1 23/04 17:27:15.460
<151>M0: CID:OSI
<134>M0: [pxy]<<192.168.0.2:5160(486)
192.168.0.1 23/04 17:27:15.480
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5161(486)
192.168.0.1 23/04 17:27:15.490
<134>M0:
<134>M0:
<159>M1: [0]RegOK. NextReg in 2130706400 (31)
192.168.0.2 23/04 17:27:15.490
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5160(427)
192.168.0.1 23/04 17:27:15.500
<134>M0:
<134>M0:
<159>M1: [1]RegOK. NextReg in 2130706400 (31)
192.168.0.2 23/04 17:27:15.500
<134>M0: [pxy]->192.168.0.2:5160(364)
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5160(463)
<134>M0:
<134>M0:
<151>M1: [0]SubOK
192.168.0.2 23/04 17:27:15.510
<134>M0: [pxy]<<192.168.0.2:5161(426)
192.168.0.1 23/04 17:27:15.510
<134>M0:
<134>M0:
<134>M0: [pxy]->192.168.0.2:5161(363)
<134>M0:
<134>M0:
<151>M1: [1]SubOK
<134>M0: [pxy]->10.128.1.4:5161(463)
<134>M0:
192.168.0.1 23/04 17:27:15.520
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5161(352)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:27:15.720
192.168.0.1 23/04 17:27:16.020
192.168.0.1 23/04 17:27:16.030
<151>M0: CID:DONE
192.168.0.1 23/04 17:27:16.470
<151>M0: CID:DONE
<151>M1: CID:OSI
192.168.0.2 23/04 17:27:17.500
<151>M1: CID:OSI
192.168.0.2 23/04 17:27:17.510
192.168.0.2 23/04 17:27:17.760
192.168.0.2 23/04 17:27:17.770
192.168.0.2 23/04 17:27:18.060
192.168.0.2 23/04 17:27:18.070
<151>M1: CID:DONE
192.168.0.2 23/04 17:27:18.510
<151>M1: CID:DONE
192.168.0.2 23/04 17:27:18.520
<159>M0: system request reboot
192.168.0.1 23/04 17:28:04.277
<159>M0: fu:1:7380, 0038 0049 043c 0445 0001
192.168.0.1 23/04 17:28:07.347
192.168.0.1 23/04 17:28:07.357
<159>M0: fu:1:742e, 03e4 05b0 0001
192.168.0.1 23/04 17:28:07.437
192.168.0.2 23/04 17:28:22.570
<143>M1: dns servers(1): 192.168.0.2 23/04 17:28:22.580
<143>M1: 192.168.0.1 192.168.0.2 23/04 17:28:22.580
<143>M1:
<159>M0: IDBG: st-0
192.168.0.1 23/04 17:28:22.690
192.168.0.2 23/04 17:28:24.560
192.168.0.3 23/04 17:28:25.620
<143>M2: dns servers(1): 192.168.0.3 23/04 17:28:25.630
<143>M2: 192.168.0.1 192.168.0.3 23/04 17:28:25.630
<143>M2:
192.168.0.4 23/04 17:28:25.630
<143>M3: dns servers(1): 192.168.0.4 23/04 17:28:25.640
<143>M3: 192.168.0.1 192.168.0.4 23/04 17:28:25.640
<143>M3:
192.168.0.3 23/04 17:28:27.451
192.168.0.4 23/04 17:28:27.521
<159>M1: IDBG: st-0
192.168.0.2 23/04 17:28:28.221
192.168.0.2 23/04 17:28:28.321
192.168.0.2 23/04 17:28:28.331
<159>M1: fbr:0:3000:3000:039a9:0002:0001:6.1.12
192.168.0.2 23/04 17:28:28.351
<159>M1: fu:0:39bb, 0003 0001
192.168.0.2 23/04 17:28:28.511
192.168.0.2 23/04 17:28:28.541
<159>M2: IDBG: st-0
192.168.0.3 23/04 17:28:29.121
192.168.0.3 23/04 17:28:29.221
<159>M2: fbr:0:3000:3000:035af:0002:0001:6.1.12
192.168.0.3 23/04 17:28:29.241
192.168.0.1 23/04 17:28:29.291
192.168.0.1 23/04 17:28:29.341
<159>M2: fu:0:35c1, 0003 0001
192.168.0.3 23/04 17:28:29.401
<159>M3: IDBG: st-0
192.168.0.4 23/04 17:28:30.191
192.168.0.4 23/04 17:28:30.281
192.168.0.4 23/04 17:28:30.291
<159>M3: fbr:0:3000:3000:0423d:0002:0001:6.1.12
192.168.0.4 23/04 17:28:30.311
<159>M3: fu:0:424f, 0003 0001
192.168.0.4 23/04 17:28:30.471
192.168.0.3 23/04 17:28:31.441
192.168.0.1 23/04 17:28:32.261
192.168.0.1 23/04 17:28:32.461
192.168.0.4 23/04 17:28:32.511
192.168.0.1 23/04 17:28:33.431
192.168.0.1 23/04 17:28:34.211
<159>M0: fs:025278:025278:131072
192.168.0.1 23/04 17:28:37.382
<159>M0: fbr:1:3000:3000:1742e:0004:0005:6.1.12
192.168.0.1 23/04 17:28:37.422
192.168.0.1 23/04 17:28:37.482
192.168.0.1 23/04 17:28:37.542
192.168.0.1 23/04 17:28:37.592
192.168.0.1 23/04 17:28:37.632
192.168.0.1 23/04 17:28:37.692
<159>M0: fu:1:7440, 0003 0001
192.168.0.1 23/04 17:28:38.182
<159>M0: mslink P:12378 V:53243
192.168.0.1 23/04 17:28:50.064
<159>M1: CC_init
192.168.0.2 23/04 17:28:52.534
192.168.0.2 23/04 17:28:52.614
192.168.0.2 23/04 17:28:52.624
<159>M1: IDBG[0]:4
192.168.0.2 23/04 17:28:53.124
<159>M1: IDBG[1]:3
<159>M2: CC_init
192.168.0.3 23/04 17:28:53.434
192.168.0.3 23/04 17:28:53.514
192.168.0.3 23/04 17:28:53.524
<159>M2: IDBG[0]:4
192.168.0.3 23/04 17:28:54.024
<159>M2: IDBG[1]:3
192.168.0.2 23/04 17:28:54.254
192.168.0.2 23/04 17:28:54.264
<159>M3: CC_init
192.168.0.4 23/04 17:28:54.504
192.168.0.4 23/04 17:28:54.584
192.168.0.4 23/04 17:28:54.594
<159>M3: IDBG[0]:4
192.168.0.4 23/04 17:28:55.084
<159>M3: IDBG[1]:3
<159>M0: CC_init
192.168.0.1 23/04 17:28:55.965
192.168.0.1 23/04 17:28:56.525
<159>M0: fu:1:7455, 03e4 05b0 0001
192.168.0.1 23/04 17:28:56.605
<159>M0: IDBG[0]:6
192.168.0.1 23/04 17:28:57.025
<159>M0: IDBG[1]:4
<134>M0: System started: ip@10.128.1.4, reboot reason:C200
192.168.0.1 23/04 17:29:23.348
192.168.0.1 23/04 17:29:23.358
<143>M0: dns servers(2): 192.168.0.1 23/04 17:29:23.358
<143>M0: 4.2.2.1 192.168.0.1 23/04 17:29:23.358
<143>M0: 4.2.2.2 192.168.0.1 23/04 17:29:23.358
<143>M0:
192.168.0.1 23/04 17:29:23.598
192.168.0.1 23/04 17:29:23.608
192.168.0.1 23/04 17:29:23.648
<134>M0: [2]->10.10.10.7:5060(576)
192.168.0.1 23/04 17:29:23.658
<134>M0:
<134>M0:
192.168.0.1 23/04 17:29:23.668
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5060(397)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:29:23.678
<134>M0:
<134>M0:
<134>M0: [pxy]->127.0.0.1:5061(397)
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5060(462)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:29:23.688
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5061(462)
<134>M0:
<134>M0:
<151>M0: [0]SubOK
<151>M0: [1]SubOK
192.168.0.1 23/04 17:29:23.698
<134>M0: [2]<<10.10.10.7:5060(544)
192.168.0.1 23/04 17:29:23.708
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]<<127.0.0.1:5061(351)
<134>M0:
<134>M0:
<134>M0: [2]->10.10.10.7:5060(744)
192.168.0.1 23/04 17:29:23.718
<134>M0:
<134>M0:
<134>M0: [2]<<10.10.10.7:5060(565)
192.168.0.1 23/04 17:29:23.768
<134>M0:
192.168.0.1 23/04 17:29:23.778
<134>M0:
<151>M0: CID:OSI
192.168.0.1 23/04 17:29:25.688
<151>M0: CID:OSI
192.168.0.1 23/04 17:29:25.698
192.168.0.1 23/04 17:29:25.748
<134>M0:
192.168.0.1 23/04 17:29:25.758
<134>M0:
<134>M0: [pxy]->192.168.0.2:5160(399)
<134>M0:
<134>M0:
192.168.0.1 23/04 17:29:25.768
<134>M0:
<134>M0:
192.168.0.2 23/04 17:29:25.778
192.168.0.1 23/04 17:29:25.778
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0:
<134>M0: [pxy]->10.128.1.4:5160(461)
<134>M0:
<134>M0:
<151>M1: [0]SubOK
<134>M0:
192.168.0.1 23/04 17:29:25.788
<134>M0:
<134>M0:
<134>M0:
<151>M1: [1]SubOK
192.168.0.2 23/04 17:29:25.788
<134>M0: [pxy]->10.128.1.4:5161(462)
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5160(350)
<134>M0:
<134>M0:
<134>M0: [pxy]<<192.168.0.2:5161(351)
192.168.0.1 23/04 17:29:25.809
<134>M0:
<134>M0:
192.168.0.1 23/04 17:29:25.949
192.168.0.1 23/04 17:29:25.959
192.168.0.1 23/04 17:29:26.249
192.168.0.1 23/04 17:29:26.259
<151>M0: CID:DONE
192.168.0.1 23/04 17:29:26.699
<151>M0: CID:DONE
192.168.0.1 23/04 17:29:26.709
<151>M1: CID:OSI
192.168.0.2 23/04 17:29:27.779
<151>M1: CID:OSI
192.168.0.2 23/04 17:29:27.799
192.168.0.2 23/04 17:29:28.039
192.168.0.2 23/04 17:29:28.059
192.168.0.2 23/04 17:29:28.339
192.168.0.2 23/04 17:29:28.359
<151>M1: CID:DONE
192.168.0.2 23/04 17:29:28.789
<151>M1: CID:DONE
192.168.0.2 23/04 17:29:28.809
192.168.0.1 23/04 17:32:18.333
If you can look into this further it would be appreciated.
David
