SPA8800 & CID
stevemag76
Hi, Sorry to re-post.. I just think that the title of my previous post is not correct and I made some progress....
I am using a SPA8800 as a gateway, connected to an Asterisk server.
I am sure that the PSTN line send the CID of the caller....
On the SPA8800, I select
PSTN CID for VoIP CID : yes
and I am sending according the Dailplan ;  S0(<:123123>)
On the sever,
-------   SIP
[pstn]
type=friend
host=dynamic
qualify=24000
defaultuser=xxx
secret=pstn-21
dtmfmode=rfc2833
nat=yes
invite=very
directmedia=yes
context=incoming
port=560
And with this config, I see on my VoIP phone ..."PSTN"
How can I display the caller ID of the caller ?
- Is there any way ?
- Did I miss out something ?
10 Replies 10
Enable the SPA8800 log and post the result of a call.
Regards.
Euuhh... How can I log the SPA8800 activity ??
Hi Daniele,
Here is the Log  :
Apparently, the phone number is correctly detected ( and transmit ?)
9/15/2012 12:09:31 PM [1] From:steve-PC (0.0.0.0) Fac:5 Sev:5 Msg >>> Starting Syslog Server 1.2.0
9/15/2012 12:11:14 PM [2] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: fu:1:c8ba, 001d 001e 03cc 0001
9/15/2012 12:11:42 PM [3] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M1: [1]RegOK. NextReg in 3570 (1)
9/15/2012 12:11:42 PM [4] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Stop PSTN Tone
9/15/2012 12:11:45 PM [5] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: [0]RegOK. NextReg in 3570 (1)
9/15/2012 12:11:45 PM [6] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: [1]RegOK. NextReg in 3570 (1)
9/15/2012 12:11:45 PM [7] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M0: AUD:Stop PSTN Tone
9/15/2012 12:14:40 PM [8] From:steve-PC (0.0.0.0) Fac:5 Sev:5 Msg >>> Starting Syslog Server 1.2.0
9/15/2012 12:14:50 PM [9] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M1: [1]RegOK. NextReg in 3570 (1)
9/15/2012 12:14:50 PM [10] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Stop PSTN Tone
9/15/2012 12:14:53 PM [12] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: [1]RegOK. NextReg in 3570 (1)
9/15/2012 12:14:53 PM [13] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M0: AUD:Stop PSTN Tone
9/15/2012 12:14:53 PM [11] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: [0]RegOK. NextReg in 3570 (1)
9/15/2012 12:15:29 PM [20] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: CC:Ringback
9/15/2012 12:15:29 PM [14] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: FXO:Start CNDD
9/15/2012 12:15:29 PM [15] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Stop PSTN Tone
9/15/2012 12:15:29 PM [16] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Stop PSTN Tone
9/15/2012 12:15:29 PM [17] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: Calling:0312659405@78.202.177.39:0
9/15/2012 12:15:29 PM [21] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: [1:0]RTP Rx Dn
9/15/2012 12:15:29 PM [22] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Play PSTN Tone 9
9/15/2012 12:15:29 PM [19] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: [1:0]RTP Rx Up
9/15/2012 12:15:29 PM [18] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: [1:0]AUD ALLOC CALL (port=17439)
9/15/2012 12:15:30 PM [23] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: FXO:CNDD name=, number=0603764449
9/15/2012 12:15:30 PM [24] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: FXO:Stop CNDD
9/15/2012 12:15:30 PM [25] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M1: FXO:CNDD Name= Phone=0603764449
9/15/2012 12:15:37 PM [27] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Play PSTN Tone 9
9/15/2012 12:15:37 PM [26] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M1: [1]RegOK. NextReg in 3570 (1)
9/15/2012 12:15:40 PM [30] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M0: AUD:Stop PSTN Tone
9/15/2012 12:15:40 PM [28] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: [0]RegOK. NextReg in 3570 (1)
9/15/2012 12:15:40 PM [29] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M0: [1]RegOK. NextReg in 3570 (1)
9/15/2012 12:15:42 PM [37] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: DLG Terminated 345c64
9/15/2012 12:15:42 PM [31] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Stop PSTN Tone
9/15/2012 12:15:42 PM [32] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M1: FXO:On Hook
9/15/2012 12:15:42 PM [33] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: AUD:Stop PSTN Tone
9/15/2012 12:15:42 PM [34] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: FXO:Stop CNDD
9/15/2012 12:15:42 PM [35] From: (192.168.0.246) Fac:19 Sev:7 Msg >>> M1: [0]FM Alert Stop RxTx (c=002b5f38;a=0)
9/15/2012 12:15:42 PM [36] From: (192.168.0.246) Fac:18 Sev:7 Msg >>> M1: [1:0]AUD Rel Call
Can you also enable SIP log under Line menu?
In this way we can see what is sent to the asterisk.
Regards.
stevemag76
Well, it was already selected.
Do you want me to enable a SIP debug log from the Asterisk server ? Would it be useful ?
OK, maybe I didn't wait enough, in order to see something from the SIP protocole...
( I just enable the log and gave a call on the PSTN line.... )
I will start again this log.... waiting longer....
- Do you know how is transmit this  CID ? is that via the SIP protocole ?
Stéphane
have some trouble to get something interesting...
Here is what I could get .
With Wireshark
the SIP protocol.....
Message [truncated]: NOTIFY sip:78.214.xx.yy SIP/2.0\r\nVia: SIP/2.0/UDP
192.168.0.246:41201;branch=z9hG4bK-8287e207\r\nFrom: "LOCAL"
;tag=760d3828e8e91ad5o1\r\nTo:
<78.214.XX.YY>\r\nCall-ID: 92e4500c-c97844
( pstn-2 ) is the name of my peer on the Asterisk server
I can see that it's sending LOCAL..This  is the name of the the  ' subscriber information'
I joined a copy of my SIP config, into the 'Line' menu
Does it help ?
Seems an asterisk issue. Try to read this:
http://forums.digium.com/viewtopic.php?f=1&t=82018
Regards.
Thank you for your reply but I don't understand really.
Honsetly, there is no difference betwen a SIP phone and the ATA, in term of SIP configuration
Into the SIP.CONF, I've defined a 'friend' ( or a peer ) as I did for the ATA.
So, why the phone can display the phone number ? and not the ATA ?
According to the link that you sent to me, that sounds to be a DAHDI problem... ( which is IN the SPA8800, if we compare the 2 systems.. ) but not sure that this is the Asterisk itself ?
Maybe, a tricky config of the 'LINE' -> SIP can solve the problem ?
- Do you have a SPA8800 ? Do you have the same problem ?
Thanks and regards ,
Stéphane
Can you capture the sip traffic on your asterisk with tcpdump?
You can trace a call from a SIP Phone and a call from the SPA.
In this way we can compare two SIP signalling and discover the difference.
Regards.
