SPA9000 and SPA400 wizard
hectorahinojosa
Can someone help me get the setup wizard thatbplays well with both of these? I downloaded he one in the software center but this one looks for an SPA 8000 and i do jot have one.
testeven
You can refer to this post below:
https://supportforums.cisco.com/docs/DOC-9876
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
testeven
Tere.
Thanks for reply i already downloaded the program and ran it but now it connected successfully to the SPA400 but wont connect to the SPA9000. It tells me it needs a password though i can log into it via html with user Admin password (blank).
Any help?
I think the password is not mandatory, you can leave it blank and continue isn't it?
Tere.
