06-04-2012 11:49 AM - edited 03-21-2019 05:52 AM
Hi everyone,
I have a SPA9000 Voice System configure with a hunt group in ringing all mode. In this configuration, i setup the call forward option if no answer after 20 seconds. This is the parameter in SIP tab -> PBX Parameters section:
Hunt group works propertly. All extensions rings during 20 seconds. But when the extensions stop ringing, call is not transfer to AA and AA script 1 don´t execute.
Can anyone tell me the reason? Any solutions?
Thanks in advance.
06-06-2012 03:48 PM
Change the ; to , before the cfwd.
06-07-2012 11:02 AM
Thank you, nseto,
But that change had already tested a few days and does not work.
I think that my AA does not work, because I delete the hunt group parameter and in subscriber information of Line 1 set contact list to aa:
This setup should send the call to AA, but instead the call is not delivered or the AA or any extension.
Any ideas?
I think i have my AA inactive and this is the reason of my problem.
Do you think my Auto Attendant Parameters are right?
Because in Info Tab say:
06-07-2012 11:46 AM
Is it possible that my AA script are wrong?
Perhaps, with a wrong AA script Auto Attendant doesn´t work ¿?
06-07-2012 03:55 PM
I managed to resolve the problem myself; my suspicions were true. Mi AA script was wrong.
I setup this other script and AA works; but now i have other problem: calls instead of forwarding to extension selected are dropped.
For example: i recieve an incoming call. AA pick up the call. AA say in prompt1 "If you need to talk with Frank press 1 or if you need to talk with Alfred please press 2" (Alfred are in extension 503). But when press 2 call dropped.
AA DIALPLAN:
(<1:501>|<2:503>)
AA SCRIPT:
Any ideas to fix it?
Regards.
