SPA962 Phone reboot every 30s and cannot factory reset
dflores83
I have a spa962   and  change  the ip address, then the phone
reboot and reboot every 30 seconds but never start up and cannot
factory reset ,
When I plug in the adapter AC or PoE,  only lighting the buttons but 30 sec after
reboot again.
somebody know  any way to reset with the softkeys ?
thanks a lot
nseto
Level 6
Level 6
Try this, just have the power supply connected to the phone, no ethernet cable connected, then go into the phone UI menu and and select number 14 which is factory reset.
nseto
Level 6
Level 6
thanks men
this is the solution but I first of all tried  leave the phone 5 minutes
without energy and then connect the power supply and then can
reset to the factory
