Sslvpn pkg upload error
gmeyer
I have been trying to install any connect 2.5 on a uc540 with my laptop and keep receiving "error in copying package file". I'm on win 7. Latest cca. Uac and firewall disabled. I can ping all uc interfaces and have disable all other nics on the laptop. I'm able to upload a file through file management in cca but not In the sslvpn install section. Any help is appreciated.
The only time i've seen that error occuring is when the flash is too full and no more directories can be added.  Try deleting some unncessary info from flash. (If you are using CDR it can cause it to fill up).
In the case of CDR delete older CDR files.  Then see if you are able to install the package via CCA.
-Trent Good ** Please rate useful posts! **
trgood
You may look into the CCA logs in your C drive under the Cisco directory to see why its failing.
Make sure you are using: anyconnect-win-2.5.6005-k9.pkg
You can also try installling from another PC to see if that is causing the issue.
Lastly I would ensure there is a CCA.xml file in NVRAM: dir nvram:
Thank you for the reply
The CCA Log Shows:
15:15:55,826 [DEBUG] Duration for [upd Mirror<--Device() @ com.cisco.cpnm.features.defn.filemanagement.FileManagementTask] = [52088] msec.
15:15:55,858 [DEBUG] Duration for [upd Mirror<--Device() @ com.cisco.cpnm.frmwrk.gen.wd.WDTabbedPane] = [32] msec.
15:16:11,972 [CLI  ] CLIEngine: Executed: http://192.168.10.1/exec/show/file/systems/|/include/flash/CR
15:16:12,019 [CLI  ] CLIEngine: Executed: http://192.168.10.1/exec/dir/flash:\/webvpn\/anyconnect-win-2.5.6005-k9.pkg/CR
15:16:12,269 [INFO ] http://192.168.10.1:80/ deviceIsTftpReachable got request
15:16:12,269 [INFO ] TftpAddressMgrImplementation:TestCoordinator(): ip = 192.168.10.180
15:16:12,316 [CLI  ] CLIEngine: Executed: http://192.168.10.1/exec/copy/tftp:\/\/192.168.10.180\/test876291679091207142813693401722696507693902210977161/test876291679091207142813693401722696507693902210977161/CR
15:16:12,409 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): receivedRequest id = test876291679091207142813693401722696507693902210977161
15:16:12,409 [INFO ] TftpAddressMgrImplementation:TestRequestGenerator(): connectedAddress = 192.168.10.180
15:16:12,425 [INFO ] http://192.168.10.1:80/ deviceIsTftpReachable returning currently tested address: 192.168.10.180
15:16:12,425 [DEBUG] ProgressBarDialogTask.constructor
15:16:12,425 [DEBUG] Progress Bar Task showProgressBar() called
15:16:12,425 [DEBUG] Waiting for Progress Bar Task to be launched
15:16:12,425 [DEBUG] Progress Bar Task showProgressBar()- before launchModalOptionDialog()- Task.getWizarDialog() = null
15:16:12,456 [DEBUG] ProgressBarDialogTask.create()
15:16:12,472 [DEBUG] Waiting for Progress Bar Task to be launched after lock.wait(), lock = [B@ae0ad6
15:16:12,472 [DEBUG] Progress Bar Task Launched
15:17:22,853 [DEBUG] McebuTftpUploadDev - getRawCliOutput result:
Netpro_UC_540 /level/15/exec/copy/tftp:\/\/192.168.10.180\/2738680344955/flash:\/webvpn\/anyconnect-win-2.5.6005-k9.pkg/CR
Netpro_UC_540
Home Exec Configure
ftp://192.168.10.180/2738680344955 flash:/webvpn/anyconnect-win-2.5.6005-k9.pkg">
Accessing tftp://192.168.10.180/2738680344955...
Loading 2738680344955 from 192.168.10.180 (via BVI1): !!!!!!!!!!!!!!!!!!!!
[OK - 4929918 bytes]
4929918 bytes copied in 54.464 secs (90517 bytes/sec)
15:17:22,884 [DEBUG] Progress Bar Task close() called
15:17:22,947 [DEBUG] Progress Bar Task terminated
15:17:22,947 [DEBUG] Progress Bar Task showProgressBar()- after launchModalOptionDialog()- Task.getWizarDialog() = null
15:17:22,978 [CLI  ] CLIEngine: Executed: http://192.168.10.1/exec/dir/flash:\/webvpn\/anyconnect-win-2.5.6005-k9.pkg/CR
15:18:41,695 [DEBUG] Start collecting data for all devices 1369340321695
15:18:41,711 [DEBUG] FileManagementTask::updateMirrorFromDevice(), starting
I am using the correct anyconnect
I have tried 3 pc's now all with the same reult.
There is a CCA.xml present in NVRAM:
Thanks again.
Trent that did the trick.. Thank you.. That didn't even occur to me since i was able to use file management to upload the same file to flash..  Apparently the SSLVPN wizard is a little more particular space.  Thanks again..
