When I call the number it rings once and then it will get busy signal there after on incoming calls
A VOIP provider uses a 74.122.242.0/24 network range for incoming and outgoing VOIP services.Their setup documents request that we allow the entire range.Typical of Cisco, the CCA only allows individual IP addresses to be entered.Can someone inform m...
Have a client with a UC540W with a 25MB/3MB Charter Internet connection. Flow: Internet - ASA5505 - UC540When directly connected to the switch which goes through the UC540W, they get regular 25MB download speeds.When connected to the wireless, the s...
When I try to enable my UC540 alternate greeting prompt it plays but then the regular prompt plays directly after it. I am using script v04.aef, when using v03.aef it doesn't even come on when enabled. Any suggestions?
Hi,I've setup a UC540 with 6x FXO lines using the addin VIC card. The 6x FXO lines have been split into 2 Trunk Groups.The client wants to be able to use 9 for dialing out on one group, and 0 for the other.I've setup the Outgoing Call Handling Prefer...
ForumLast week Cisco RMA's a replacement UC520 box for a client of mine.We replaced the legacy UC520 with the RMA unit on last Friday.I got a call yesterday that the clients on hold music was missing.Thereafter I petitioned the Cisco Rep as to what t...
Hi All,We have recently set up a UC320W with a number of SPA303 and 301 phones. Quite happy with the system although we are having a couple of problems as it seems a region pack is not yet available for us over here. We have found th...
Hello everybody,We have setup a UC540 at a clients office, and now they are asking if we can setup a Auto Dialer, so they can put a bunch of phone numbers and the system will call those phone numbers and read a small script. Basically like have the s...
Hello,I have alot of customers in the medical field and have deployed UC500's pretty successfully. Does anyone have any suggestions on call queue software that works with UC series really well. The AA does a good job but if patie...
I have a SPA504G that will not power up. All of the buttons are lit & will not go off. Help!!!!There is no factory reset allowed only the speaker, headphone & mic buttons will not go off.This happens on POE or external power.
We have an UC560 with 12 SPA525G2 phones and a AP541 forwireless.From time to time when we are in the middle of a call the phone soft-reset, and then when the phone is rebooting it can't connect to the AP (it just "hangs" in the connecting to AP scre...
I have a problem i have a SIP trunk working well but when i configure the jabber ios, at UC500, this siptrnk drop calls for incomming and ountgoing, the CME is 8.6 if anybody has the solution..
We've just installed a 7975 with 2x 7916 KEMs for use as a reception/front desk phone.We used the 7975 as it takes 2x Kems and we needed the extra BLF soft keys.When a call is taken you cant simply press the softkey of the extension you want to trans...
Hi all,I want to register SPA525G on CME 2901. can anyone tell how to configure it.thanks
I'm looking to migrate a company from Call Manager/Unity to a uc560. I have all the users vm greetings as .wav files off the unity server. Is there a way to import these into CUE on a uc560 and assign them back to the users voice mailboxes as their...
