Taking SPA50x config and applying it to new phone?
richard klein
I am looking to make take a template from SPA504G #1 and using the TFTP protocol using hte config file to send to SPA504G #2.
I used the file here:
http://192.168.168.199/admin/spacfg.xml
then saved as a cfg file.
How do i send that config file to the other phone without duplicating the mac info ?
If i copy the CFG file to the new phone will it just 'work' with all the same info (network, etc)?
Rich
Dan Lukes
Sorry, but what you mean "duplicating the mac info" ?
MAC of phone can't be changed, the cfg attribute in question is read-only.
Just try it ...
