TAPI for UC540
apedder123
Can anyone tell me where I can download TAPI for UC540?
I'm not interested in SmartCall Connector - I just want click to dial from a couple of Windows apps.
Adam
David Trad
Hi Adam,
I am unable to find the file I once used on the Cisco Web site anywhere... Maybe it has been taken down??
The name of the file is "Cisco-CUCME-TSP-2.1.2.zip" if you get stuck let me know and I can try to e-mail it to you as it is only a 4.5Mb file.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David,
I'd appreciate it, email address is adam at sfax.co.uk
Adam
Steven DiStefano
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp
login and select support file url
then select CME8.1 (that is the current CME in SWP 8.1.0)
download it (it contains CME-TSP-2.2.0.5.zip)
