08-02-2011 08:12 AM - edited 03-21-2019 04:26 AM
UC540. Calls come in on FXO. The desired behavior:
- Business hours ring and extension or a blast group, if not answered go to AA
- After hours go to AA
Is this possible to configure in CCA? At first glance, I think I need to create a new Unity Express script.
Roman
Solved! Go to Solution.
08-02-2011 08:26 AM
Roman,
Using CCA, you can configure a "floating extension" and use "night service" that will accomplish this for you.
Example:
Extension 350 - Floating extension, configured with Call Forward All to Blast group, then if no answer, forward to AA.
Night Service - Add Ext. 350 to night service, forward to AA when night service active.
Thank you,
Darren
08-02-2011 08:26 AM
Roman,
Example:
Thank you,
Darren
08-02-2011 03:16 PM
Thanks Darren, this helped.
Interesting that night service doesn't work until you reboot UC500.
08-02-2011 09:38 AM
Here is an example of some CCA screens to accomplish close to your call flow....
