Transfer call to outside number (cell) issues
Joe Gadell
We have been having this issue for awhile now - haven't had enough time to address it.  We use SIP trunking - FYI.
This only happens on transfers to outside numbers.
Here is the process:
1. Outside call comes in to receptionist
2. Receptionst answers call, hits Trnsfer and dials the new number (typically a cell phone)
3. Receptions discusses transfer with cell phone recipient and then hits the Trnsfer button again
4. After pushing the Trnsfer button, receptionist sees that both calls are placed on hold on her phone.
5. She is able to grab both calls individually again but can never complete the outside transfer.
Any thoughts?
Thanks.
5 Replies 5
bjames
Level 5
Level 5
How many trunks do you have? Does she dial the digit for outside line?
If you debug the SIP traffic what do you see?
Bob James
Brian,
We have 20 SIP channels with Windstream over a T1.  The two "outside calls" connect, so the dialing 9 isn't an issue.  She is able to communicate with the original caller and the person she is transferring to.  However, when she his the Trnsfer button for the final time, it just leaves both callers on hold and hangs up her phone.  She can still see the pause symbol next to both calls on her phone, but her phone is on-hook.
Haven't run debugs yet, I thought it might be a simple configuration problem.
Joe
David Trad
Hi Joe,
It is this part here that is of concern, and it made me wonder if it is possible if you have the following:
  • Set the receptionist phone up as either a dual-line or an octo-line, if the phone is setup as neither this particular result can be see as well
  • If you have enough DSP resources, have you allocated your DSP resources correctly using CCA?
Can you give us a little more information about your setup? Is this a CLI based configuration or a CCA built system??
Maybe if possible can you please post your configuration with all the sensative stuff removed, however check the above first and let us know.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
David,
Thanks for the response.
1. Her ephone-dn is configured as a dual-line
2. I'm not exactly sure what the dsp resources should look like - can you compare to your configs for me?
I'm including the relevant parts of our config ( I hope ).  Thanks again.
Our config was created with an early CCA and has since been maintained CLI only due to integration with Exchange, MS Speech Server, and a few other 3rd party systems.
voice call send-alert voice rtp send-recv ! voice service voip no notify redirect ip2ip allow-connections h323 to h323 allow-connections h323 to sip allow-connections sip to h323 allow-connections sip to sip supplementary-service h450.12 no supplementary-service sip moved-temporarily fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw sip   registrar server expires max 3600 min 3600 ! voice class codec 1 codec preference 1 g711ulaw ! ! voice class cause-code 1 no-circuit dspfarm profile 2 transcode description CCA transcoding for SIP Trunk NuVox codec g711ulaw codec g729abr8 codec g729ar8 codec g711alaw codec g729r8 maximum sessions 6 associate application SCCP ! telephony-service sdspfarm units 5 sdspfarm transcode sessions 6 sdspfarm tag 2 mtp001b8fafb460 video moh-file-buffer 920 fxo hook-flash max-ephones 14 max-dn 56 ip source-address 10.1.1.1 port 2000 max-redirect 20 auto assign 1 to 1 type bri calling-number initiator service phone videoCapability 1 service phone ehookenable 1 service dnis overlay service dnis dir-lookup timeouts interdigit 5 url services http://10.1.10.1/voiceview/common/login.do url authentication http://10.1.10.2/CCMCIP/authenticate.asp load 7960-7940 P00308010200 load 7941 SCCP41.8-5-3S load 7941GE SCCP41.8-5-3S load 7961 SCCP41.8-5-3S load 7961GE SCCP41.8-5-3S load 7970 SCCP70.8-5-3S load 7971 SCCP70.8-5-3S load 521G-524G cp524g-8-1-17 load 525G spa525g-7-4-4 load 501G spa50x-30x-7-4-6 load 502G spa50x-30x-7-4-6 load 504G spa50x-30x-7-4-6 load 508G spa50x-30x-7-4-6 load 509G spa50x-30x-7-4-6 load 301 spa50x-30x-7-4-6 load 303 spa50x-30x-7-4-6 time-zone 8 voicemail 501 mwi relay max-conferences 4 gain -6 call-forward pattern .T moh flash:/media/jazz2.wav multicast moh 239.10.16.16 port 2000 dn-webedit time-webedit transfer-system full-consult dss transfer-pattern 9.T transfer-pattern .T transfer-pattern 6... blind secondary-dialtone 9 fac standard create cnf-files version-stamp 7960 Jan 18 2011 09:18:47 ! ephone-dn  12  dual-line number 203 no-reg primary pickup-group 1 label 203 - Dani name Dani J call-forward busy 501 call-forward noan 501 timeout 20 ! ephone  11 device-security-mode none mac-address 001E.BE90.7871 ephone-template 16 username "DaniJ" password 12345 type 7960 button  1:12 2m17 3m14 4w11 button  5w15 6w20 !
David Trad
Hi Joe,
Your config at first sight looks fine...
Can you get some debug captures by any chance?
If you do not know how to debug the call please let me know and I will dig up the commands, but it would be good to see what is taking place to prevent the transfer taking place.
I will look over what you have posted further, although it would be better to provide you running configuration with just the sensitive stuff removed as there potentially could be more parts to the config that needs to be looked at, such as your dial-peers as well.
Cheers,
David.
