02-22-2013 11:44 AM - edited 03-21-2019 07:01 AM
I have 2 UC 560s in a multisite config, site a and site b have pots lines for outside access, site a has an ext range of 1XX, site b has an extension range of 2XX, and forwarders are in place on both sites to dial across the multisite by 3 digit extension. The problem we are having is that when, say a user at site a does a cfa to a cell phone and a call comes in to the number for site b, when whoever answers the number at site b tries to transfer to the forwarded extension, it does nothing at all. When the user at site b transfers to a live extension at site a and a user answers, the user who answered can transfer to the forwaded line and it will contact the cell phone. Any thoughts?
Solved! Go to Solution.
02-28-2013 02:36 PM
Hello David,
I want you to try this for me..
Remove the following from the multisite dial-peers:
corlist incoming call-internal
This should be done on both sites, on the multisite dial-peers. (This would be dial-peers 2100 and 2101 at Site A. Not sure about Site B, as I don't have the running config from that site.)
Let me know what happens.
Thank you,
Darren
02-26-2013 05:05 AM
Anyone?
02-26-2013 08:08 AM
Hello David,
Your description is good, but I don't think we have enough info to figure out what is going on.
We probably need to see what is happening to the call when it hits Site A. My suggestion would be to get a debug from Site A, when the user at Site B is trying to transfer the call to the Site A extension with the CallForward All. (We would probably need to see the running configuration also, at least from Site A.)
Debugs:
debug voice ccapi inout
debug vpm signal
Thank you,
Darren
02-27-2013 02:39 AM
simple question....did your cfa have the required prefix included, in order to get out?
Else, agreed with Darren, not enough info.
02-27-2013 06:46 PM
You can only restore to the same exact model. T1 to T1 will work, but FXO to T1 will not work.
-john
02-28-2013 11:20 AM
Here are some debugs. In this scenario, a user from Site A had her desk phone forwarded to her cell phone. I called in to Site B with my cell phone and dialed her extension (132). From SIte B, a floating extension translates the three digit extension from 132 to 82132 to send it across MultiSite. Debugs used were ccapi inout and vpm signalling.
Site A:
004453: Feb 27 21:08:05.614: //-1/85F1CE8F97D0/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=192.168.7.1
----- ccCallInfo IE subfields -----
cisco-ani=8149326293
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=82132
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=132
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=15 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
004454: Feb 27 21:08:05.614: //-1/85F1CE8F97D0/CCAPI/cc_api_call_setup_ind_common:
Interface=0x879ED7EC, Call Info(
Calling Number=8149326293,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=82132(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=2100, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=9273
004455: Feb 27 21:08:05.614: //-1/85F1CE8F97D0/CCAPI/ccCheckClipClir:
In: Calling Number=8149326293(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
004456: Feb 27 21:08:05.614: //-1/85F1CE8F97D0/CCAPI/ccCheckClipClir:
Out: Calling Number=8149326293(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
004457: Feb 27 21:08:05.614: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004458: Feb 27 21:08:05.614: :cc_get_feature_vsa malloc success
004459: Feb 27 21:08:05.614: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004460: Feb 27 21:08:05.614: cc_get_feature_vsa count is 3
004461: Feb 27 21:08:05.614: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004462: Feb 27 21:08:05.614: :FEATURE_VSA attributes are: feature_name:0,feature_time:2353198456,feature_id:17864
004463: Feb 27 21:08:05.614: //9273/85F1CE8F97D0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=8149326293(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=82132(TON=Unknown, NPI=Unknown))
004464: Feb 27 21:08:05.614: //9273/85F1CE8F97D0/CCAPI/cc_process_call_setup_ind:
Event=0x88B5D1F0
004465: Feb 27 21:08:05.614: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 82132
004466: Feb 27 21:08:05.614: //9273/85F1CE8F97D0/CCAPI/ccCallSetContext:
Context=0x8CABED38
004467: Feb 27 21:08:05.614: //9273/85F1CE8F97D0/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 9273 with tag 2100 to app "_ManagedAppProcess_Default"
004468: Feb 27 21:08:05.614: //9273/85F1CE8F97D0/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
004469: Feb 27 21:08:05.618: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=132, Called Number=132, Calling Number=8149326293, Calling DN=-1 Calling Id=9273,
Redirect Number=918145258655, Redirect Reason=15
004470: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
type=6 redirecting_number=132
004471: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004472: Feb 27 21:08:05.622: :cc_get_feature_vsa malloc success
004473: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004474: Feb 27 21:08:05.622: cc_get_feature_vsa count is 4
004475: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004476: Feb 27 21:08:05.622: :FEATURE_VSA attributes are: feature_name:0,feature_time:2353195992,feature_id:17865
004477: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004478: Feb 27 21:08:05.622: feature_vsa is 8C42F570,featname is 0
004479: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004480: Feb 27 21:08:05.622: :cc_get_feature_vsa malloc success
004481: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004482: Feb 27 21:08:05.622: cc_get_feature_vsa count is 5
004483: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004484: Feb 27 21:08:05.622: :FEATURE_VSA attributes are: feature_name:0,feature_time:2353201368,feature_id:17866
004485: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004486: Feb 27 21:08:05.622: : Generating new featurevsa,inserting it
004487: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004488: Feb 27 21:08:05.622: feature call forward featname is 1
004489: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004490: Feb 27 21:08:05.622: :cc_free_feature_vsa freeing 8C42EBD0
004491: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004492: Feb 27 21:08:05.622: vsacount in free is 4
004493: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004494: Feb 27 21:08:05.622: :cc_get_feature_vsa malloc success
004495: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004496: Feb 27 21:08:05.622: cc_get_feature_vsa count is 5
004497: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
004498: Feb 27 21:08:05.622: :FEATURE_VSA attributes are: feature_name:0,feature_time:2353195992,feature_id:17867
004499: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
004500: Feb 27 21:08:05.622: feature call forward featname is 1
004501: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004502: Feb 27 21:08:05.622: :cc_free_feature_vsa freeing 8C42EBD0
004503: Feb 27 21:08:05.622: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004504: Feb 27 21:08:05.622: vsacount in free is 4
004505: Feb 27 21:08:05.626: //9273/85F1CE8F97D0/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
004506: Feb 27 21:08:05.626: //9273/85F1CE8F97D0/CCAPI/ccCallDisconnect:
Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
004507: Feb 27 21:08:05.626: //9273/85F1CE8F97D0/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
004508: Feb 27 21:08:05.626: //9273/85F1CE8F97D0/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x879ED7EC, Tag=0x0, Call Id=9273,
Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
004509: Feb 27 21:08:05.626: //9273/85F1CE8F97D0/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
004510: Feb 27 21:08:05.626: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004511: Feb 27 21:08:05.630: :cc_free_feature_vsa freeing 8C4300D0
004512: Feb 27 21:08:05.630: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004513: Feb 27 21:08:05.630: vsacount in free is 3
004514: Feb 27 21:08:05.630: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
004515: Feb 27 21:08:05.630: vsacount in free is 2
Site B:
002788: Feb 27 15:14:12.934: %SYS-5-CONFIG_I: Configured from http by ccmadmin on 172.16.1.41 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 12 11
002789: Feb 27 15:18:27.483: %SYS-5-CONFIG_I: Configured from console by ccmadmin on vty0 (172.16.1.41) VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 14 13 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 20 19 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 6 5 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 8 7 VCC, mtp1 index, mtp2 index, stream1, stream2 = 1 1 12 11
002790: Feb 27 21:07:50.929: htsp_process_event: [0/2/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
002791: Feb 27 21:07:50.929: htsp_timer - 125 msec
002792: Feb 27 21:07:51.057: htsp_process_event: [0/2/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
002793: Feb 27 21:07:51.057: htsp_timer - 10000 msec
002794: Feb 27 21:07:51.057: htsp_timer3 - 5600 msec
002795: Feb 27 21:07:51.057: [0/2/1] htsp_start_caller_id_rx:BELLCORE
002796: Feb 27 21:07:51.057: htsp_start_caller_id_rx create dsp_stream_manager
002797: Feb 27 21:07:51.057: [0/2/1] htsp_dsm_create_success returns 1
002798: Feb 27 21:07:51.789: htsp_process_event: [0/2/1, FXOLS_RINGING, E_DSP_SIG_0100]
002799: Feb 27 21:07:51.789: fxols_ringing_not
002800: Feb 27 21:07:51.789: htsp_timer_stop
002801: Feb 27 21:07:51.789: htsp_timer - 10000 msec
002802: Feb 27 21:07:52.109: htsp_process_event: [0/2/1, FXOLS_RINGING, E_DSP_SIG_0000]
002803: Feb 27 21:07:52.945: htsp_process_event: [0/2/1, FXOLS_RINGING, E_DSP_SIG_0100]
002804: Feb 27 21:07:52.945: fxols_ringing_not
002805: Feb 27 21:07:52.945: htsp_timer_stop
002806: Feb 27 21:07:52.945: htsp_timer - 10000 msec
002807: Feb 27 21:07:54.065: [0/2/1] htsp_dsm_feature_notify_cb returns 2 id=DSM_FEATURE_SM_CALLERID_RX
002808: Feb 27 21:07:54.065: htsp_process_event: [0/2/1, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
002809: Feb 27 21:07:54.065: htsp_timer_stop
002810: Feb 27 21:07:54.065: htsp_timer_stop3
002811: Feb 27 21:07:54.065: [0/2/1] htsp_stop_caller_id_rx. message length 170htsp_setup_ind
002812: Feb 27 21:07:54.065: [0/2/1] get_fxo_caller_id:Caller ID received. Message type=128 length=42 checksum=C0
002813: Feb 27 21:07:54.065: [0/2/1] Caller ID String 80 27 01 08 30 32 32 37 32 31 30 36 02 0A 38 31 34 39 33 32 36 32 39 33 07 0F 4D 4F 57 45 52 59 20 44 41 56 49 44 20 20 20 C0
002814: Feb 27 21:07:54.069: [0/2/1] get_fxo_caller_id calling num=8149326293 calling name=MOWERY DAVID calling time=02/27 21:06
002815: Feb 27 21:07:54.069: fxols_callerid_done: call being answered
002816: Feb 27 21:07:54.069: //-1/7F1490DF97CA/CCAPI/cc_api_display_ie_subfields:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=398
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
002817: Feb 27 21:07:54.069: //-1/7F1490DF97CA/CCAPI/cc_api_call_setup_ind_common:
Interface=0x88A84544, Call Info(
Called Number=398(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=101, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
002818: Feb 27 21:07:54.069: //-1/7F1490DF97CA/CCAPI/ccCheckClipClir:
002819: Feb 27 21:07:54.069: //-1/7F1490DF97CA/CCAPI/ccCheckClipClir:
002820: Feb 27 21:07:54.069: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002821: Feb 27 21:07:54.069: :cc_get_feature_vsa malloc success
002822: Feb 27 21:07:54.069: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002823: Feb 27 21:07:54.069: cc_get_feature_vsa count is 3
002824: Feb 27 21:07:54.069: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002825: Feb 27 21:07:54.069: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349945216,feature_id:73287
002826: Feb 27 21:07:54.069: //39848/7F1490DF97CA/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=398(TON=Unknown, NPI=Unknown))
002827: Feb 27 21:07:54.073: [0/2/1] htsp_dsm_close_done
002828: Feb 27 21:07:54.073: htsp_process_event: [0/2/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
002829: Feb 27 21:07:54.073: fxols_wait_setup_ack:
002830: Feb 27 21:07:54.073: htsp_timer - 6000 msec
002831: Feb 27 21:07:54.073: //39848/7F1490DF97CA/CCAPI/cc_process_call_setup_ind:
Event=0x88A0E9F8
002832: Feb 27 21:07:54.073: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 398
002833: Feb 27 21:07:54.073: //39848/7F1490DF97CA/CCAPI/ccCallSetContext:
Context=0x8CD1160C
002834: Feb 27 21:07:54.073: //39848/7F1490DF97CA/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 39848 with tag 101 to app "_ManagedAppProcess_Default"
002835: Feb 27 21:07:54.073: //39848/7F1490DF97CA/CCAPI/ccCallProceeding:
002836: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=2001, Params=0x8C12CB94, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
002837: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccCheckClipClir:
002838: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccCheckClipClir:
002839: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccCallSetupRequest:
Destination Pattern=398, Called Number=398, Digit Strip=FALSE
002840: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccCallSetupRequest:
Redirect Number=, Display Info=MOWERY DAVID
Account Number=, Final Destination Flag=TRUE,
Guid=7F1490DF-8082-11E2-97CA-EC0F43BEDF33, Outgoing Dial-peer=2001
002841: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=398
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
002842: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x885F7C38, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=8149326293,(Calling Name=MOWERY DAVID )(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=398(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2001, Call Count On=FALSE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
002843: Feb 27 21:07:54.077: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002844: Feb 27 21:07:54.077: :cc_get_feature_vsa malloc success
002845: Feb 27 21:07:54.077: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002846: Feb 27 21:07:54.077: cc_get_feature_vsa count is 4
002847: Feb 27 21:07:54.077: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002848: Feb 27 21:07:54.077: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349951488,feature_id:73288
002849: Feb 27 21:07:54.077: //39849/7F1490DF97CA/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
002850: Feb 27 21:07:54.077: //39849/7F1490DF97CA/CCAPI/ccCallSetContext:
Context=0x8C12CB44
002851: Feb 27 21:07:54.077: //39848/7F1490DF97CA/CCAPI/ccSaveDialpeerTag:
002852: Feb 27 21:07:54.077: htsp_process_event: [0/2/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
002853: Feb 27 21:07:54.081: //39849/7F1490DF97CA/CCAPI/cc_api_call_proceeding:
Interface=0x885F7C38, Progress Indication=NULL(0)
002854: Feb 27 21:07:54.597: //39849/7F1490DF97CA/CCAPI/cc_api_call_alert:
Interface=0x885F7C38, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
002855: Feb 27 21:07:54.597: //39849/7F1490DF97CA/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
002856: Feb 27 21:07:54.597: //39848/7F1490DF97CA/CCAPI/ccCallAlert:
002857: Feb 27 21:07:54.597: //39848/7F1490DF97CA/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)htsp_alert_notify
002858: Feb 27 21:07:54.597: htsp_process_event: [0/2/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
002859: Feb 27 21:07:54.613: //39849/7F1490DF97CA/CCAPI/cc_api_call_connected:
Interface=0x885F7C38, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
002860: Feb 27 21:07:54.613: //39849/7F1490DF97CA/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
002861: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=39848
002862: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/ccConferenceCreate:
(confID=0x8C1E8C50, callID1=0x9BA8, gcid=7F1490DF-808211E2-97CAEC0F-43BEDF33, tag=0x0)
002863: Feb 27 21:07:54.617: //39849/7F1490DF97CA/CCAPI/ccConferenceCreate:
(confID=0x8C1E8C50, callID2=0x9BA9, gcid=7F1490DF-808211E2-97CAEC0F-43BEDF33, tag=0x0)
002864: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/ccConferenceCreate:
Conference Id=0x8C1E8C50, Call Id1=39848, Call Id2=39849, Tag=0x0
002865: Feb 27 21:07:54.617: htsp_call_bridged invoked
002866: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/cc_api_bridge_done:
Conference Id=0x34E0, Source Interface=0x88A84544, Source Call Id=39848,
Destination Call Id=39849, Disposition=0x0, Tag=0xFFFFFFFF
002867: Feb 27 21:07:54.617: //39849/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002868: Feb 27 21:07:54.617: cc_api_get_xcode_stream : 4702
002869: Feb 27 21:07:54.617: //39849/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
002870: Feb 27 21:07:54.617: cc_api_get_xcode_stream : 4702
002871: Feb 27 21:07:54.617: //39849/7F1490DF97CA/CCAPI/cc_api_bridge_done:
Conference Id=0x34E0, Source Interface=0x885F7C38, Source Call Id=39849,
Destination Call Id=39848, Disposition=0x0, Tag=0x0
002872: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/cc_generic_bridge_done:
002873: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x34E0, Destination Call Id=39849)
002874: Feb 27 21:07:54.617: //39849/7F1490DF97CA/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x34E0, Destination Call Id=39848)
002875: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/cc_api_caps_ind:
Destination Interface=0x885F7C38, Destination Call Id=39849, Source Call Id=39848,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
002876: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
002877: Feb 27 21:07:54.617: //39849/7F1490DF97CA/CCAPI/cc_api_caps_ind:
Destination Interface=0x88A84544, Destination Call Id=39848, Source Call Id=39849,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
002878: Feb 27 21:07:54.617: //39849/7F1490DF97CA/CCAPI/cc_api_caps_ind:
002879: Feb 27 21:07:54.617: //39849/7F1490DF97CA/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1959)
002880: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/cc_api_caps_ack:
002881: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
002882: Feb 27 21:07:54.617: //39848/7F1490DF97CA/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
002883: Feb 27 21:07:54.621: htsp_process_event: [0/2/1, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
002884: Feb 27 21:07:54.621: [0/2/1] set signal state = 0xC timestamp = 0
002885: Feb 27 21:07:54.621: htsp_timer_stop
002886: Feb 27 21:07:54.621: //39848/7F1490DF97CA/CCAPI/cc_api_voice_mode_event:
Call Id=39848
002887: Feb 27 21:07:54.621: //39848/7F1490DF97CA/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x8CD1160C)
002888: Feb 27 21:07:54.621: htsp_process_event: [0/2/1, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
002889: Feb 27 21:07:54.621: //39848/7F1490DF97CA/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x34E0, Call Id1=39848, Call Id2=39849
002890: Feb 27 21:07:54.893: htsp_process_event: [0/2/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
002891: Feb 27 21:07:54.893: htsp_timer_stop2
002892: Feb 27 21:07:54.893: htsp_timer_stop2
002893: Feb 27 21:07:58.929: //39848/7F1490DF97CA/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 1 to dstCallId 0x9BA9
002894: Feb 27 21:07:58.929: //39848/7F1490DF97CA/CCAPI/cc_relay_digit_begin_for_3way_conference:
Check DTMF relay digit begin for 3way conf
002895: Feb 27 21:07:59.301: //39848/7F1490DF97CA/CCAPI/cc_api_call_digit_end:
002896: Feb 27 21:07:59.301: //39848/7F1490DF97CA/CCAPI/cc_relay_digit_end_for_3way_conference:
Check DTMF relay digit end for 3way conf
002897: Feb 27 21:07:59.301: htsp_digit_ready(0/2/1): digit = 1
002898: Feb 27 21:07:59.589: //39848/7F1490DF97CA/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 3 to dstCallId 0x9BA9
002899: Feb 27 21:07:59.589: //39848/7F1490DF97CA/CCAPI/cc_relay_digit_begin_for_3way_conference:
002900: Feb 27 21:08:00.021: //39848/7F1490DF97CA/CCAPI/cc_api_call_digit_end:
002901: Feb 27 21:08:00.021: //39848/7F1490DF97CA/CCAPI/cc_relay_digit_end_for_3way_conference:
002902: Feb 27 21:08:00.021: htsp_digit_ready(0/2/1): digit = 3
002903: Feb 27 21:08:00.289: //39848/7F1490DF97CA/CCAPI/cc_api_call_digit_begin:
Consume mask is not set. Relaying Digit 2 to dstCallId 0x9BA9
002904: Feb 27 21:08:00.289: //39848/7F1490DF97CA/CCAPI/cc_relay_digit_begin_for_3way_conference:
002905: Feb 27 21:08:00.741: //39848/7F1490DF97CA/CCAPI/cc_api_call_digit_end:
002906: Feb 27 21:08:00.741: //39848/7F1490DF97CA/CCAPI/cc_relay_digit_end_for_3way_conference:
002907: Feb 27 21:08:00.741: htsp_digit_ready(0/2/1): digit = 2
002908: Feb 27 21:08:05.573: //39848/7F1490DF97CA/CCAPI/ccGenerateToneInfo:
Tone Direction=Sum Network, Params=0x0, Call Id=39848
002909: Feb 27 21:08:05.573: //39849/7F1490DF97CA/CCAPI/cc_api_call_facility:
Interface=0x885F7C38, Call Id=39849
002910: Feb 27 21:08:05.573: //39849/7F1490DF97CA/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
002911: Feb 27 21:08:05.573: //39848/7F1490DF97CA/CCAPI/ccConferenceDestroy:
Conference Id=0x34E0, Tag=0x0
002912: Feb 27 21:08:05.573: //39848/7F1490DF97CA/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=39849, Disposition=0x0, Tag=0x0
002913: Feb 27 21:08:05.573: //39849/7F1490DF97CA/CCAPI/cc_api_bridge_drop_done:
002914: Feb 27 21:08:05.573: //39848/7F1490DF97CA/CCAPI/cc_generic_bridge_done:
002915: Feb 27 21:08:05.573: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002916: Feb 27 21:08:05.573: :cc_get_feature_vsa malloc success
002917: Feb 27 21:08:05.573: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002918: Feb 27 21:08:05.573: cc_get_feature_vsa count is 5
002919: Feb 27 21:08:05.573: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002920: Feb 27 21:08:05.573: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349944768,feature_id:73289
002921: Feb 27 21:08:05.573: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002922: Feb 27 21:08:05.573: feature_vsa is 8C1169F8,featname is 0
002923: Feb 27 21:08:05.573: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002924: Feb 27 21:08:05.573: :cc_get_feature_vsa malloc success
002925: Feb 27 21:08:05.573: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002926: Feb 27 21:08:05.573: cc_get_feature_vsa count is 6
002927: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002928: Feb 27 21:08:05.577: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349952608,feature_id:73290
002929: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002930: Feb 27 21:08:05.577: : Generating new featurevsa,inserting it
002931: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002932: Feb 27 21:08:05.577: feature call forward featname is 4
002933: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002934: Feb 27 21:08:05.577: feature_vsa is 8C115178,featname is 0
002935: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002936: Feb 27 21:08:05.577: :cc_get_feature_vsa malloc success
002937: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002938: Feb 27 21:08:05.577: cc_get_feature_vsa count is 7
002939: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002940: Feb 27 21:08:05.577: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349947456,feature_id:73291
002941: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002942: Feb 27 21:08:05.577: : Generating new featurevsa,inserting it
002943: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002944: Feb 27 21:08:05.577: feature call forward featname is 4
002945: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002946: Feb 27 21:08:05.577: :cc_free_feature_vsa freeing 8C114FB8
002947: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002948: Feb 27 21:08:05.577: vsacount in free is 6
002949: Feb 27 21:08:05.577: //39848/7F1490DF97CA/CCAPI/ccSaveDialpeerTag:
Outgoing Dial-peer=0
002950: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002951: Feb 27 21:08:05.577: :cc_get_feature_vsa malloc success
002952: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002953: Feb 27 21:08:05.577: cc_get_feature_vsa count is 7
002954: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002955: Feb 27 21:08:05.577: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349944768,feature_id:73292
002956: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002957: Feb 27 21:08:05.577: : updating existing feature vsa
002958: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002959: Feb 27 21:08:05.577: feature call forward featname is 4
002960: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002961: Feb 27 21:08:05.577: :cc_free_feature_vsa freeing 8C114FB8
002962: Feb 27 21:08:05.577: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002963: Feb 27 21:08:05.577: vsacount in free is 6
002964: Feb 27 21:08:05.581: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
002965: Feb 27 21:08:05.581: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=132, Called Number=132, Calling Number=8149326293, Calling DN=-1 Calling Id=39848,
Redirect Number=82132, Redirect Reason=15
002966: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
002967: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002968: Feb 27 21:08:05.585: :cc_get_feature_vsa malloc success
002969: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002970: Feb 27 21:08:05.585: cc_get_feature_vsa count is 7
002971: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002972: Feb 27 21:08:05.585: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349944768,feature_id:73293
002973: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002974: Feb 27 21:08:05.585: feature_vsa is 8C115A38,featname is 4
002975: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002976: Feb 27 21:08:05.585: feature_vsa is 8C115178,featname is 0
002977: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002978: Feb 27 21:08:05.585: :cc_get_feature_vsa malloc success
002979: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002980: Feb 27 21:08:05.585: cc_get_feature_vsa count is 8
002981: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002982: Feb 27 21:08:05.585: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349950368,feature_id:73294
002983: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002984: Feb 27 21:08:05.585: : Generating new featurevsa,inserting it
002985: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
002986: Feb 27 21:08:05.585: feature call forward featname is 1
002987: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002988: Feb 27 21:08:05.585: :cc_free_feature_vsa freeing 8C114FB8
002989: Feb 27 21:08:05.585: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
002990: Feb 27 21:08:05.585: vsacount in free is 7
002991: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2101, Params=0x8CD1549C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
002992: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccCheckClipClir:
002993: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccCheckClipClir:
002994: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccCallSetupRequest:
Destination Pattern=82..., Called Number=82132, Digit Strip=FALSE
002995: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccCallSetupRequest:
Redirect Number=132, Display Info=MOWERY DAVID
Guid=85F1CE8F-8082-11E2-97D0-EC0F43BEDF33, Outgoing Dial-peer=2101
002996: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=82132
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=132
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
002997: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x88462334, Interface Type=1, Destination=, Mode=0x0,
Called Number=82132(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2101, Call Count On=FALSE,
002998: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
002999: Feb 27 21:08:05.589: :cc_get_feature_vsa malloc success
003000: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003001: Feb 27 21:08:05.589: cc_get_feature_vsa count is 8
003002: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003003: Feb 27 21:08:05.589: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349944768,feature_id:73295
003004: Feb 27 21:08:05.589: //39851/7F1490DF97CA/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
003005: Feb 27 21:08:05.589: //39851/7F1490DF97CA/CCAPI/ccCallSetContext:
Context=0x8CD1544C
003006: Feb 27 21:08:05.589: //39848/7F1490DF97CA/CCAPI/ccSaveDialpeerTag:
003007: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
003008: Feb 27 21:08:05.589: feature call forward featname is 1
003009: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
003010: Feb 27 21:08:05.589: feature_vsa is 8C114FB8,featname is 0
003011: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003012: Feb 27 21:08:05.589: :cc_get_feature_vsa malloc success
003013: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003014: Feb 27 21:08:05.589: cc_get_feature_vsa count is 9
003015: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
003016: Feb 27 21:08:05.589: :FEATURE_VSA attributes are: feature_name:0,feature_time:2349948352,feature_id:73296
003017: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
003018: Feb 27 21:08:05.589: : Generating new featurevsa,inserting it
003019: Feb 27 21:08:05.589: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
003020: Feb 27 21:08:05.589: feature call forward featname is 1
003021: Feb 27 21:08:05.629: //39851/7F1490DF97CA/CCAPI/cc_api_call_disconnected:
Cause Value=1, Interface=0x88462334, Call Id=39851
003022: Feb 27 21:08:05.629: //39851/7F1490DF97CA/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
003023: Feb 27 21:08:05.629: //39848/7F1490DF97CA/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
003024: Feb 27 21:08:05.629: //39851/7F1490DF97CA/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=39851
003025: Feb 27 21:08:05.629: //39851/7F1490DF97CA/CCAPI/ccCallDisconnect:
Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
003026: Feb 27 21:08:05.629: //39851/7F1490DF97CA/CCAPI/ccCallDisconnect:
003027: Feb 27 21:08:05.629: //39851/7F1490DF97CA/CCAPI/cc_api_get_transfer_info:
003028: Feb 27 21:08:05.633: //39851/7F1490DF97CA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88462334, Tag=0x0, Call Id=39851,
003029: Feb 27 21:08:05.633: //39851/7F1490DF97CA/CCAPI/cc_api_call_disconnect_done:
003030: Feb 27 21:08:05.633: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003031: Feb 27 21:08:05.633: :cc_free_feature_vsa freeing 8C115DB8
003032: Feb 27 21:08:05.633: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003033: Feb 27 21:08:05.633: vsacount in free is 8
003034: Feb 27 21:08:05.633: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003035: Feb 27 21:08:05.633: vsacount in free is 7
003036: Feb 27 21:08:48.822: htsp_process_event: [0/2/1, FXOLS_CONNECT, E_DSP_SIG_1100]fxols_offhook_disc
003037: Feb 27 21:08:48.822: htsp_timer2 - 350 msec
003038: Feb 27 21:08:49.174: htsp_process_event: [0/2/1, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
003039: Feb 27 21:08:49.174: htsp_timer_stop
003040: Feb 27 21:08:49.174: htsp_timer_stop2
003041: Feb 27 21:08:49.174: htsp_timer_stop3
003042: Feb 27 21:08:49.174: //39848/7F1490DF97CA/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x88A84544, Call Id=39848
003043: Feb 27 21:08:49.174: //39848/7F1490DF97CA/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
003044: Feb 27 21:08:49.174: //39849/7F1490DF97CA/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
003045: Feb 27 21:08:49.174: //39849/7F1490DF97CA/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
003046: Feb 27 21:08:49.174: //39848/7F1490DF97CA/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
003047: Feb 27 21:08:49.174: //39848/7F1490DF97CA/CCAPI/ccCallDisconnect:
003048: Feb 27 21:08:49.174: //39848/7F1490DF97CA/CCAPI/cc_api_get_transfer_info:
003049: Feb 27 21:08:49.174: htsp_timer_stop3
003050: Feb 27 21:08:49.182: //39849/7F1490DF97CA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x885F7C38, Tag=0x0, Call Id=39849,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
003051: Feb 27 21:08:49.182: //39849/7F1490DF97CA/CCAPI/cc_api_call_disconnect_done:
003052: Feb 27 21:08:49.182: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003053: Feb 27 21:08:49.182: :cc_free_feature_vsa freeing 8C116E58
003054: Feb 27 21:08:49.182: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003055: Feb 27 21:08:49.182: vsacount in free is 6
003056: Feb 27 21:08:49.182: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003057: Feb 27 21:08:49.182: vsacount in free is 5
003058: Feb 27 21:08:49.202: htsp_process_event: [0/2/1, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
003059: Feb 27 21:08:49.202: htsp_timer_stop
003060: Feb 27 21:08:49.202: htsp_timer_stop2
003061: Feb 27 21:08:49.202: htsp_timer_stop3
003062: Feb 27 21:08:49.202: [0/2/1] set signal state = 0x4 timestamp = 0
003063: Feb 27 21:08:49.202: htsp_timer - 2000 msec
003064: Feb 27 21:08:49.202: //39848/7F1490DF97CA/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x88A84544, Tag=0x0, Call Id=39848,
003065: Feb 27 21:08:49.202: //39848/7F1490DF97CA/CCAPI/cc_api_call_disconnect_done:
003066: Feb 27 21:08:49.202: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003067: Feb 27 21:08:49.202: :cc_free_feature_vsa freeing 8C116598
003068: Feb 27 21:08:49.202: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003069: Feb 27 21:08:49.202: vsacount in free is 4
003070: Feb 27 21:08:49.202: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003071: Feb 27 21:08:49.202: vsacount in free is 3
003072: Feb 27 21:08:49.202: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
003073: Feb 27 21:08:49.202: vsacount in free is 2
003074: Feb 27 21:08:49.482: htsp_process_event: [0/2/1, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
003075: Feb 27 21:08:50.390: htsp_process_event: [0/2/1, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
003076: Feb 27 21:08:51.202: htsp_process_event: [0/2/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
003077: Feb 27 21:08:51.202: htsp_process_event: [0/2/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
003078: Feb 27 21:09:15.395: %SYS-5-CONFIG_I: Configured from console by ccmadmin on vty0 (172.16.1.40)
Thanks for looking, folks!
02-28-2013 12:28 PM
Hello David,
I looked at the debugs, and it appears that the incoming call is never getting to the FXO lines as there is no VPM information in the debugs at Site A. (Unless the VPM debug was not started on Site A when you were testing.)
The call fails with:
Cause Value=1 - This means that it is trying to direct the call to a number that does not exist. In this case it is 918145258655. (Which I assume is the cell phone number.)
At this point, I would probably need to see the running configuration from Site A to see how the call should be flowing though the configuration.
Thank you,
Darren
02-28-2013 01:26 PM
The vpm debug was active at the time of the call.
Here is the config for Site A:
Current configuration : 52323 bytes
! Last configuration change at 16:17:47 EST Thu Feb 28 2013 by ccmadmin
! NVRAM config last updated at 09:26:34 EST Thu Feb 28 2013
version 15.1
parser config cache interface
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service internal
service compress-config
service sequence-numbers
hostname Shrock
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/3
no logging queue-limit
no logging rate-limit
enable secret 4 RmD1QNVJIxtXohEct7GAwlbz0WkpxM.iYy40mtI658U
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-3481847793
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3481847793
revocation-check none
rsakeypair TP-self-signed-3481847793
crypto pki certificate chain TP-self-signed-3481847793
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33343831 38343737 3933301E 170D3132 30383231 31373533
33395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34383138
34373739 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100B062 879F1C30 FA5FB494 E83D94C8 271DEB9E DB2404A9 BD1D2595 AC945A27
631CB2CC 3F09E9A0 B8EF3D23 3EE6402E 30F13BC2 75D62DB2 4900DD9F 063CBFCA
0C810414 A8B14D22 0B8579E8 35E628B2 335B3461 D5B6E6B9 15B7D1F0 95000C74
FBA11B5F 40C6159B 5ACD923A FC3FD5EC EF70FE3D 9EC52AB7 27C18072 7811941B
89FB0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14B250F0 AE3CD2D8 6300A7CC 7C9216E7 EB2E1C75 A0301D06
03551D0E 04160414 B250F0AE 3CD2D863 00A7CC7C 9216E7EB 2E1C75A0 300D0609
2A864886 F70D0101 05050003 81810064 8101B6FA 5B346BAA 46A8B139 8ACAAC4C
DA7E6DD4 7A39BC8E FAB350F4 544E56A9 9D7569D9 B9D946E4 50AB855B 891F5527
97B1D255 B6B2BBC6 9269BD28 6E0CA745 E352C92A F464FD3D 62CA7AAD 18F9F752
7BF03003 FE95A110 6A33999C 7336D328 5DC94BC7 966A6ECA ADF1F119 4DEA77B2
3EE5A625 14C3B254 2E5E4D1B 7E8916
quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp binding cleanup interval 10
ip dhcp excluded-address 10.1.10.1
ip dhcp excluded-address 10.1.2.0
ip dhcp excluded-address 10.1.2.1 10.1.2.99
ip dhcp excluded-address 10.1.2.250 10.1.2.255
ip dhcp excluded-address 10.1.1.1 10.1.1.3
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
default-router 10.1.2.1
dns-server 192.168.0.202
ip dhcp pool Data
import all
network 10.1.2.0 255.255.255.0
dns-server 8.8.8.8
ip name-server 192.168.0.202
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
port 0/0/0
fallback-dn 107
port 0/0/1
fallback-dn 402
port 0/0/3
fallback-dn 107
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme sequential
trunk group ALL_T1E1
hunt-scheme longest-idle
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
sip
rel1xx disable
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
call start slow
voice class custom-cptone CCAjointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone CCAleavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
create profile sync 0000600214899255
voice hunt-group 1 parallel
final 290
list 101,105,114,117,118,124,125
timeout 16
pilot 190
voice hunt-group 2 parallel
final 300
list 108,109,116,125,126
timeout 16
pilot 555
voice translation-rule 4
rule 15 // //
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1113
rule 1 /^82\(...\)/ /\1/
voice translation-rule 1114
rule 1 /\(^...$\)/ /82\1/
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile multisiteInbound
translate called 1113
voice translation-profile multisiteOutbound
translate calling 1114
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
license udi pid UC560-T1E1-K9 sn FGL162813U3
archive
log config
logging enable
logging size 600
hidekeys
username ccmadmin privilege 15 password 0 c1$c0cucm
username pingerID password 0 999609
process-max-time 50
ip tftp source-interface Vlan1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 1800
crypto isakmp key q1w2e3r4 address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10 periodic
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map multisite 1 ipsec-isakmp
description Mason
set peer 192.168.1.170
set transform-set ESP-3DES-SHA
match address 107
qos pre-classify
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address 192.168.0.170 255.255.255.0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport trunk native vlan 101
switchport mode trunk
no ip address
macro description cisco-router
spanning-tree portfast
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
switchport access vlan 150
no ip address
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
no ip address
interface Vlan1
description $FW_INSIDE$
ip address 192.168.10.1 255.255.255.0
ip nat inside
no autostate
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip nat inside
interface Vlan100
ip address 10.1.100.1 255.255.255.0
ip access-group 103 in
ip nat inside
interface Vlan101
ip address 10.1.2.1 255.255.255.0
ip nat inside
h323-gateway voip bind srcaddr 10.1.2.1
interface Vlan150
ip address 10.1.1.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.1.10.1 255.255.255.255 Vlan90
ip route 192.168.7.0 255.255.255.0 192.168.1.170
ip route 192.168.10.0 255.255.255.0 192.168.1.170
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 10.1.100.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.0.0 0.0.0.255 any
access-list 101 deny ip 10.1.10.0 0.0.0.3 any
access-list 101 permit ip 10.1.2.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit tcp 10.1.2.0 0.0.0.255 eq 2000 any
access-list 102 permit udp 10.1.2.0 0.0.0.255 eq 2000 any
access-list 102 deny ip 192.168.0.0 0.0.0.255 any
access-list 102 deny ip 10.1.100.0 0.0.0.255 any
access-list 102 deny ip 10.1.2.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip 192.168.0.0 0.0.0.255 any
access-list 103 deny ip 10.1.100.0 0.0.0.255 any
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark SDM_ACL Category=17
access-list 104 permit ip 192.168.7.0 0.0.0.255 10.1.2.0 0.0.0.255
access-list 104 permit udp host 192.168.1.170 host 192.168.0.170 eq non500-isakmp
access-list 104 permit udp host 192.168.1.170 host 192.168.0.170 eq isakmp
access-list 104 permit esp host 192.168.1.170 host 192.168.0.170
access-list 104 permit ahp host 192.168.1.170 host 192.168.0.170
access-list 104 permit ip any any
access-list 105 remark CryptoACL for Mason
access-list 105 remark SDM_ACL Category=4
access-list 105 permit ip 10.1.2.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 105 permit ip 10.1.2.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 106 remark SDM_ACL Category=18
access-list 106 deny ip 10.1.2.0 0.0.0.255 192.168.7.0 0.0.0.255
access-list 106 permit ip 192.168.10.0 0.0.0.255 any
access-list 106 permit ip 10.1.10.0 0.0.0.3 any
access-list 106 permit ip 10.1.100.0 0.0.0.255 any
access-list 106 permit ip 10.1.2.0 0.0.0.255 any
access-list 106 permit ip 10.1.1.0 0.0.0.255 any
access-list 107 remark CryptoACL for Mason
access-list 107 remark SDM_ACL Category=4
access-list 107 permit ip 10.1.2.0 0.0.0.255 192.168.7.0 0.0.0.255
route-map SDM_RMAP_1 permit 1
match ip address 106
snmp-server community public RO
snmp-server host 1.1.1.1 cms
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-9c.bin alias spa50x-30x-7-4-9c.bin
tftp-server flash:/phones/7937/apps37sccp.1-4-4-0.bin alias apps37sccp.1-4-4-0.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
voice-port 0/0/0
station-id name Shop
caller-id enable
voice-port 0/0/1
station-id name Overhead Ring
station-id number 402
caller-id enable
voice-port 0/0/2
station-id name Overhead Page
station-id number 198
caller-id enable
voice-port 0/0/3
timeouts ringing infinity
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
ring number 3
connection plar opx 398
description Configured by CCA 4 FXO-0/1/0-AA
caller-id enable
caller-id alerting ring 2
voice-port 0/1/1
trunk-group ALL_FXO 62
ring number 3
description Configured by CCA 4 FXO-0/1/1-AA
caller-id enable
voice-port 0/1/2
trunk-group ALL_FXO 61
ring number 3
description Configured by CCA 4 FXO-0/1/2-AA
caller-id enable
voice-port 0/1/3
trunk-group ALL_FXO 59
ring number 3
description Configured by CCA 4 FXO-0/1/3-AA
caller-id enable
voice-port 0/2/0
trunk-group ALL_FXO 60
ring number 3
description Configured by CCA 4 FXO-0/2/0-AA
caller-id enable
voice-port 0/2/1
trunk-group ALL_FXO 63
ring number 3
description Configured by CCA 4 FXO-0/2/1-AA
caller-id enable
voice-port 0/2/2
shutdown
description Configured by CCA 4 FXO-0/2/2-AA
caller-id enable
voice-port 0/2/3
shutdown
description Configured by CCA 4 FXO-0/2/3-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 10.1.10.2 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
associate profile 2 register mtp442b03d54160
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Multisite Only
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 10
associate application SCCP
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711alaw
codec g711ulaw
maximum conference-participants 32
maximum sessions 8
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 198
port 0/0/2
no sip-register
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 100 pots
port 0/2/0
dial-peer voice 101 pots
port 0/2/1
dial-peer voice 102 pots
port 0/2/2
dial-peer voice 103 pots
port 0/2/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 104 pots
destination-pattern A4
port 0/2/0
no sip-register
dial-peer voice 105 pots
destination-pattern A5
port 0/2/1
no sip-register
dial-peer voice 106 pots
destination-pattern A6
port 0/2/2
no sip-register
dial-peer voice 107 pots
destination-pattern A7
port 0/2/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 300
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 398
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 397
b2bua
codec g711ulaw
no vad
dial-peer voice 69 pots
trunkgroup ALL_FXO 1
corlist outgoing call-national
description **CCA*North American-7-Digit*Long Distance**
destination-pattern 91[2-9]..[2-9].......
forward-digits all
no sip-register
dial-peer voice 62 pots
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-Digit*Emergency**
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 84 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 85 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-7-Digit*7-Digit Local**
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 86 pots
trunkgroup ALL_FXO
description **CCA*North American-7-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 87 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 88 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 89 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 90 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 91 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 92 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 93 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 2100 voip
description **CCA*INTERSITE inbound call to Schrock
translation-profile incoming multisiteInbound
incoming called-number 82...
voice-class h323 1
dtmf-relay h245-alphanumeric
fax protocol cisco
no vad
dial-peer voice 2101 voip
description **CCA*INTERSITE outbound calls to Mason
translation-profile outgoing multisiteOutbound
destination-pattern 81...
session target ipv4:192.168.7.1
voice-class h323 1
fax protocol cisco
no vad
no dial-peer outbound status-check pots
sip-ua
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 1 confprof1
sdspfarm tag 2 mtp442b03d54160
conference hardware
video
fxo hook-flash
max-ephones 138
max-dn 600
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone webAccess 0
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Center Rock, Inc.
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file perphone
load 7937 apps37sccp.1-4-4-0
load 521G-524G cp524g-8-1-17
load 501G spa50x-30x-7-4-9c
load 502G spa50x-30x-7-4-9c
load 504G spa50x-30x-7-4-9c
load 508G spa50x-30x-7-4-9c
load 509G spa50x-30x-7-4-9c
load 301 spa50x-30x-7-4-9c
load 303 spa50x-30x-7-4-9c
time-zone 12
keepalive 30 auxiliary 4
voicemail 300
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$o1zW$p6ljODQV2z3bNA2z.dUzv0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service code *22
night-service day Sun 17:00 09:00
night-service day Mon 17:00 08:00
night-service day Sat 17:00 09:00
night-service date Jan 1 00:00 23:59
night-service date Dec 25 00:00 23:59
night-service date Nov 22 00:00 23:59
night-service date Nov 21 00:00 23:59
night-service date Dec 21 00:00 23:59
night-service date Dec 24 00:00 23:59
night-service date Dec 31 00:00 23:59
directory entry 1 915403897033 name Virginia Office
directory entry 2 915019770081 name Arkansas Office
directory entry 3 914144617810 name Wisconsin Office
directory entry 4 915707314923 name NorthernPA Office
directory entry 5 92673768 name Mason Office
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys alerting Acct Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn ConfList RmLstC Acct Park Select Join
button-layout 7931 2
ephone-template 15
softkeys idle Redial Newcall Mobility Cfwdall Pickup Gpickup Dnd HLog Login
softkeys connected Hold Endcall Mobility Trnsfer TrnsfVM Confrn ConfList RmLstC Acct Park Select Join
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 1
number 199 no-reg primary
description IP-Paging1
name Shrock Paging Group
paging ip 239.1.1.1 port 2000
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 488 octo-line
number 778 no-reg primary
conference meetme unlocked
preference 3
ephone-dn 489 octo-line
preference 2
no huntstop
ephone-dn 490 octo-line
preference 1
no huntstop
ephone-dn 491 octo-line
no huntstop
ephone-dn 492 octo-line
number 777 no-reg primary
preference 3
ephone-dn 493 octo-line
preference 2
no huntstop
ephone-dn 494 octo-line
preference 1
no huntstop
ephone-dn 495 octo-line
no huntstop
ephone-dn 496 octo-line
number 776 no-reg primary
preference 3
ephone-dn 497 octo-line
preference 2
no huntstop
ephone-dn 498 octo-line
preference 1
no huntstop
ephone-dn 499 octo-line
no huntstop
ephone-dn 500 octo-line
number 775 no-reg primary
preference 3
ephone-dn 501 octo-line
preference 2
no huntstop
ephone-dn 502 octo-line
preference 1
no huntstop
ephone-dn 503 octo-line
no huntstop
ephone-dn 504 octo-line
number C004 no-reg primary
conference ad-hoc
preference 3
ephone-dn 505 octo-line
conference ad-hoc
preference 2
no huntstop
ephone-dn 506 octo-line
conference ad-hoc
preference 1
no huntstop
ephone-dn 507 octo-line
conference ad-hoc
no huntstop
ephone-dn 508 octo-line
number C003 no-reg primary
conference ad-hoc
preference 3
ephone-dn 509 octo-line
conference ad-hoc
preference 2
no huntstop
ephone-dn 510 octo-line
conference ad-hoc
preference 1
no huntstop
ephone-dn 511 octo-line
conference ad-hoc
no huntstop
ephone-dn 512 octo-line
number C002 no-reg primary
conference ad-hoc
preference 3
ephone-dn 513 octo-line
conference ad-hoc
preference 2
no huntstop
ephone-dn 514 octo-line
conference ad-hoc
preference 1
no huntstop
ephone-dn 515 octo-line
conference ad-hoc
no huntstop
ephone-dn 516 octo-line
number C001 no-reg primary
conference ad-hoc
preference 3
ephone-dn 517 octo-line
conference ad-hoc
preference 2
no huntstop
ephone-dn 518 octo-line
conference ad-hoc
preference 1
no huntstop
ephone-dn 519 octo-line
conference ad-hoc
no huntstop
ephone-dn 522
number 301 no-reg primary
description *** CCA Floating Extension ***
name Voice Mail
call-forward all 81301
ephone-dn 523
number 299 no-reg primary
name OverPhone Paging
call-forward all 81299
ephone-dn 524
number 216 no-reg primary
name Monte Walker
call-forward all 81216
ephone-dn 525
number 218 no-reg primary
name Trailer Shop
call-forward all 81218
ephone-dn 526
number 217 no-reg primary
name Coty Slifco
call-forward all 81217
ephone-dn 527
number 227 no-reg primary
name Jim Rose
call-forward all 81227
ephone-dn 528
number 229 no-reg primary
name Jamie Resh
call-forward all 81229
ephone-dn 529
number 226 no-reg primary
name Doug Philip
call-forward all 81226
ephone-dn 530
number 214 no-reg primary
name Ron Persuhn
call-forward all 81214
ephone-dn 531
number 225 no-reg primary
name Travis Mosholder
call-forward all 81225
ephone-dn 532
number 215 no-reg primary
name Mechanic Shop
call-forward all 81215
ephone-dn 533
number 219 no-reg primary
name Joe McKenzie
call-forward all 81219
ephone-dn 534
number 224 no-reg primary
name Hammer Shop
call-forward all 81224
ephone-dn 535
number 223 no-reg primary
name Christen Fisher
call-forward all 81223
ephone-dn 536
number 220 no-reg primary
name Becky Fisher
call-forward all 81220
ephone-dn 537
number 213 no-reg primary
name Alex Fisher
call-forward all 81213
ephone-dn 538
number 222 no-reg primary
name Rick Athey
call-forward all 81222
ephone-dn 539
number 221 no-reg primary
name Jody Humberson
call-forward all 81221
ephone-dn 543
number 228 no-reg primary
name Clinton Clark
call-forward all 81228
ephone-dn 544
number 290 no-reg primary
name Operator Group
call-forward all 81290
ephone-dn 545
number 210 no-reg primary
name Dan Stoner
call-forward all 81210
ephone-dn 547
number 212 no-reg primary
name Becky Dorcon
call-forward all 81212
ephone-dn 560
number 211 no-reg primary
name Jamie Boyce
call-forward all 81211
ephone-dn 561
number 390 no-reg primary
name Answering Service
call-forward all 918776977018
ephone-dn 562
number 298 no-reg primary
name OverHead Paging
call-forward all 81298
ephone-dn 563 dual-line
number 107 no-reg primary
name Shop Phone
ephone-dn 564 dual-line
ring internal
number 105 no-reg primary
label Lindsay Dorcon - 105
description Lindsay Dorcon - 105
name Receptionist Phone
call-forward busy 300
call-forward noan 300 timeout 20
translation-profile incoming CallBlocking
ephone-dn 565 dual-line
number 129 no-reg primary
label Break Room - 129
description Break Room - 129
name Break Room
ephone-dn 566 dual-line
number 112 no-reg primary
label Kitchen Phone - 112
description Kitchen Phone - 112
name Kitchen Phone
ephone-dn 567 dual-line
number 134 no-reg primary
label Spare Desk - 134
description Spare Desk - 134
name Spare Desk
ephone-dn 568 dual-line
number 133 no-reg primary
label David Custer - 133
description David Custer - 133
name David Custer
ephone-dn 569 dual-line
number 132 no-reg primary
label Marina Fisher - 132
description Marina Fisher - 132
name Marina Fisher
mobility
ephone-dn 570 dual-line
number 131 no-reg primary
label Luke Miller - 131
description Luke Miller - 131
name Luke Miller
ephone-dn 571 dual-line
number 130 no-reg primary
label Randy Chicca - 130
description Randy Chicca - 130
name Randy Chicca
ephone-dn 572 dual-line
number 127 no-reg primary
label Upstairs Conference Room - 127
description Upstairs Conference Room - 127
name Upstairs CRoom
ephone-dn 573 dual-line
number 124 no-reg primary
label Brenda Philip - 124
description Brenda Philip - 124
name Brenda Philip
ephone-dn 574 dual-line
number 122 no-reg primary
label Dave Rose - 122
description Dave Rose - 122
name Dave Rose
ephone-dn 575 dual-line
number 119 no-reg primary
label Garrett Muir - 119
description Garrett Muir - 119
name Garrett Muir
ephone-dn 576 dual-line
number 118 no-reg primary
label Peggy Pletcher - 118
description Peggy Pletcher - 118
name Peggy Pletcher
ephone-dn 577 dual-line
number 117 no-reg primary
label Amanda Pletcher - 117
description Amanda Pletcher - 117
name Amanda Pletcher
ephone-dn 578 dual-line
number 114 no-reg primary
label Lori Ling - 114
description Lori Ling - 114
name Lori Ling
ephone-dn 579 dual-line
number 106 no-reg primary
label Derwin Gilbreath - 106
description Derwin Gilbreath - 106
name Derwin Gilbreath
ephone-dn 580 dual-line
number 104 no-reg primary
label Shelby Philip - 104
description Shelby Philip - 104
name Shelby Philip
ephone-dn 581 dual-line
number 103 no-reg primary
label Ted Proctor - 103
description Ted Proctor - 103
name Ted Proctor
ephone-dn 582 dual-line
number 113 no-reg primary
label Jason Benedict - 113
description Jason Benedict - 113
name Jason Benedict
ephone-dn 583 dual-line
number 102 no-reg primary
label Brandon Fisher - 102
description Brandon Fisher - 102
name Brandon Fisher
call-forward busy 190
call-forward noan 190 timeout 20
ephone-dn 584 dual-line
number 101 no-reg primary
label Tonya Conn - 101
description Tonya Conn - 101
name Tonya Conn
ephone-dn 585 dual-line
number 126 no-reg primary
label Jeff Brant - 126
description Jeff Brant - 126
name Jeff Brant
ephone-dn 586 dual-line
number 125 no-reg primary
label Matt Caton - 125
description Matt Caton - 125
name Matt Caton
ephone-dn 587 dual-line
number 120 no-reg primary
label Dale Miller - 120
description Dale Miller - 120
name Dale Miller
ephone-dn 588 dual-line
number 116 no-reg primary
label Joe Logsdon - 116
description Joe Logsdon - 116
name Joe Logsdon
ephone-dn 589 dual-line
number 110 no-reg primary
label Steve Bungard - 110
description Steve Bungard - 110
name Steve Bungard
ephone-dn 590 dual-line
number 109 no-reg primary
label Ryan Saylor - 109
description Ryan Saylor - 109
name Ryan Saylor
mobility
snr 98142796525 delay 1 timeout 30 cfwd-noan 300
ephone-dn 591 dual-line
number 115 no-reg primary
label Downstairs Conference Room 115
description Conference Room
name Conference Room
ephone-dn 592
number 354 no-reg primary
park-slot timeout 60 limit 2 recall retry 60 limit 2
label CallPark5
ephone-dn 593
number 353 no-reg primary
label CallPark4
ephone-dn 594
number 352 no-reg primary
label CallPark3
ephone-dn 595
number 351 no-reg primary
label CallPark2
ephone-dn 596
number 350 no-reg primary
label CallPark1
ephone-dn 597
number A801... no-reg primary
mwi off
ephone-dn 598
number A800... no-reg primary
mwi on
ephone-dn 599 dual-line
number 108 no-reg primary
label Gary Meager - 108
description Gary Meager
name Gary Meager
ephone-dn 600
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 300
ephone 1
device-security-mode none
mac-address 649E.F377.F09F
ephone-template 16
max-calls-per-button 2
username "GMeager" password 123456
paging-dn 1
type 508G
button 1:599
night-service bell
ephone 2
mac-address 0004.F2EE.C1AB
ephone-template 16
username "croom" password 12345
type 7937
button 1:591
night-service bell
ephone 3
mac-address 649E.F377.F0B5
ephone-template 16
username "rsaylor" password 12345
type 508G
button 1:590
night-service bell
ephone 4
mac-address 649E.F377.F0EE
ephone-template 16
username "sbungard" password 12345
type 508G
button 1:589
night-service bell
ephone 5
mac-address 649E.F377.F0F9
ephone-template 16
username "jlogsdon" password 12345
type 508G
button 1:588
night-service bell
ephone 6
mac-address 649E.F377.E8EF
ephone-template 16
username "dmiller" password 12345
paging-dn 1
type 508G
button 1:587
night-service bell
ephone 7
mac-address 649E.F377.EAEA
ephone-template 1
username "mcaton" password 12345
type 508G
button 1:586
night-service bell
ephone 8
mac-address 649E.F377.F0D0
ephone-template 16
username "jbrant" password 12345
paging-dn 1
type 508G
button 1:585
night-service bell
ephone 9
mac-address 649E.F377.F103
ephone-template 1
username "tconn" password 12345
type 508G
button 1:584
night-service bell
ephone 10
mac-address 649E.F377.F034
ephone-template 16
username "bfisher" password 12345
type 508G
button 1:583
night-service bell
ephone 11
mac-address 649E.F377.EEAC
ephone-template 16
username "jbenedict" password 12345
paging-dn 1
type 508G
button 1:582
night-service bell
ephone 12
mac-address 649E.F377.F0E5
ephone-template 16
username "tproctor" password 1234
type 508G
button 1:581
night-service bell
ephone 13
mac-address 649E.F377.F05E
ephone-template 16
username "sphilip" password 12345
paging-dn 1
type 508G
button 1:580
night-service bell
ephone 14
mac-address 649E.F377.EAED
ephone-template 16
username "dgilbreath" password 12345
type 508G
button 1:579
night-service bell
ephone 15
mac-address 649E.F377.F075
ephone-template 1
username "lling" password 12345
type 508G
button 1:578
night-service bell
ephone 16
mac-address 649E.F377.EFFE
ephone-template 1
username "apletcher" password 12345
type 508G
button 1:577
night-service bell
ephone 17
mac-address 649E.F377.F072
ephone-template 1
username "ppletcher" password 12345
paging-dn 1
type 508G
button 1:576
night-service bell
ephone 18
mac-address 649E.F377.F095
ephone-template 16
username "gmuir" password 12345
type 508G
button 1:575
night-service bell
ephone 19
mac-address 649E.F377.EA14
ephone-template 16
username "drose" password 12345
type 508G
button 1:574
night-service bell
ephone 20
mac-address 649E.F377.EBA5
ephone-template 1
username "bphilip" password 12345
type 508G
button 1:573
night-service bell
ephone 21
mac-address 649E.F377.EA7A
ephone-template 16
username "ucroom" password 12345
paging-dn 1
type 508G
button 1:572
night-service bell
ephone 22
mac-address 649E.F377.EA79
ephone-template 16
username "rchicca" password 12345
paging-dn 1
type 508G
button 1:571
night-service bell
ephone 23
mac-address 649E.F377.F07D
ephone-template 16
username "lmiller" password 12345
paging-dn 1
type 508G
button 1:570
night-service bell
ephone 24
mac-address 649E.F377.EF2A
ephone-template 16
username "mfisher" password 12345
fastdial 1 92674185 name home
fastdial 2 94459675 name time\temp
fastdial 3 918147427700 name Link
speed-dial 1 92674185 label "Home"
speed-dial 2 918147427700 label "Link"
speed-dial 4 915403897033 label "VA Engineers"
speed-dial 5 915019770081 label "Arkansas Office"
speed-dial 55 92674185 label "Home - Marina"
type 508G
button 1:569
night-service bell
ephone 25
mac-address 649E.F377.F0E1
ephone-template 16
username "dcuster" password 12345
type 508G
button 1:568
night-service bell
ephone 26
mac-address 649E.F377.EBB2
ephone-template 16
username "sdesk" password 12345
paging-dn 1
type 508G
button 1:567
night-service bell
ephone 27
mac-address 7081.053D.204E
ephone-template 1
username "kphone" password 112112
paging-dn 1
type 504G
button 1:566
night-service bell
ephone 28
mac-address 7081.053D.2204
ephone-template 16
username "broom" password 12345
paging-dn 1
type 504G
button 1:565
night-service bell
ephone 29
mac-address 7081.053D.2361
ephone-template 16
username "ldorcon" password 12345
type 504G addon 1 500S 2 500S
button 1:564 6w584 7w583 8w581
button 9w580 11w579 13w599 14w590
button 15w589 17w566 18w582 19w578
button 20w591 21w588 22w577 23w576
button 24w575 25w587 27w574 29w573
button 30w586 31w585 32w572 34w565
button 35w571 36w570 37w569 38w568
button 39w567
night-service bell
ephone 33
mac-address B03D.5416.2003
ephone-template 16
username "sphone" password 12345
type anl
button 1:563
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
banner login ^CCisco Configuration Assistant. Version: 3.2 (2). Thu Feb 21 15:13:39 EST 2013^C
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
ntp server 64.90.182.55 prefer
event manager session cli username "pingerID"
event manager applet vpn-pinger
event timer watchdog time 120 maxrun 100
action 1.0 cli command "enable"
action 2_Mason cli command "ping ip 192.168.7.1 source Vlan1 repeat 2 timeout 5"
end
02-28-2013 02:36 PM
Hello David,
I want you to try this for me..
Remove the following from the multisite dial-peers:
corlist incoming call-internal
This should be done on both sites, on the multisite dial-peers. (This would be dial-peers 2100 and 2101 at Site A. Not sure about Site B, as I don't have the running config from that site.)
Let me know what happens.
Thank you,
Darren
03-01-2013 06:57 AM
That was the issue, Darren, thank you! That was driving me nuts, and I guess I just glossed over the CoR!
