uc 520 new did either fast busy or number not in service
john
we had a number (814) 342-5635 changed from analoge fxo to digital pri over t1/e1 so i added the entry for the new did to point to aa 600 using cca but all i'm getting is either number you have dialed is not in service or i get a fast busy signal
i don't understand how the voice translation rule / profile and dial peer in cli that's is why i'm using cca 2.2.5 i know the running config needs cleaned up and and it my have some out of bounds settings that may be causing the cca 2.2.5 not to work properly i am pasting a copy of the config please help you can email me at john@psr1.com
Current configuration : 34596 bytes
! Last configuration change at 17:43:00 EST Tue Nov 23 2010 by admin
version 15.0
parser config cache interface
no service pad
no service timestamps debug uptime
service internal
service compress-config
hostname prosatellite
boot-start-marker
boot-end-marker
card type t1 0 2
no logging buffered
no logging rate-limit
enable secret 5 $1$4R/b$8MjtfOXhKJ6IxWQ0xowfL0
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone EST -5
clock summer-time EST recurring
network-clock-participate wic 2
network-clock-select 1 T1 0/2/0
crypto pki trustpoint TP-self-signed-3217079834
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3217079834
revocation-check none
rsakeypair TP-self-signed-3217079834
crypto pki certificate chain TP-self-signed-3217079834
certificate self-signed 01
  30820244 308201AD A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33323137 30373938 3334301E 170D3130 31313233 32323130
  35315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 32313730
  37393833 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D1C6 6AA67080 916534B4 2FDF1272 64E56C55 CF8A38AE FEA328B4 7CF29A5B
  F630CE99 A64DAC63 C8BEB379 432D21FB 1AB63BEF F7BF81D8 4ABDB564 23214FE1
  37506C8B EDF3066E 053C55ED 49C7A0CB 71E37F4D 0914F808 9DB9B4E7 318F32E2
  F86E58E9 EA8C6F2C FD576608 34823F8E 97A425F5 F8682FE8 F2D11F9E B161051C
  5B370203 010001A3 6C306A30 0F060355 1D130101 FF040530 030101FF 30170603
  551D1104 10300E82 0C70726F 73617465 6C6C6974 65301F06 03551D23 04183016
  8014476C E0AFD0B9 2EC32B2A F42F8C14 F1B2A058 8A53301D 0603551D 0E041604
  14476CE0 AFD0B92E C32B2AF4 2F8C14F1 B2A0588A 53300D06 092A8648 86F70D01
  01040500 03818100 721D902D 2C829BB3 869E3186 32108E6F 94279992 7487CB0B
  F1F19ACD CA4FCC62 36DF4E5C A068AD1A 5AD808DB 6A6D6780 5E257B7E A144DC5A
  FACCF7C6 35284B54 008BF76F 0B1CE613 9685452F 81AFBB2C C800DA2C 085ADDFF
  EF95BD53 6B910A67 97F9958C B21DF632 82D02321 B73ACE15 5A8F0CE7 8B6F81D4
  D2EEDEF2 2A18E2C0
   quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp pool phone
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.2
   option 150 ip 192.168.2.2
ip name-server 63.203.35.55
ip inspect name SDM_LOW cuseeme
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
isdn switch-type primary-5ess
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class custom-cptone CCAjointone
dualtone conference
  frequency 600 900
  cadence 300 150 300 100 300 50
voice class custom-cptone CCAleavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice register global
max-dn 128
max-pool 32
voice translation-rule 1
rule 1 /8777773491/ /600/
rule 2 /8777773492/ /600/
rule 3 /\(814342887\)\(.\)/ /10\2/
rule 4 /\(814342888\)\(.\)/ /11\2/
rule 5 /8143428888/ /303/
voice translation-rule 4
rule 2 /8143428872/ /102/
rule 3 /8143428873/ /103/
rule 4 /8143428874/ /104/
rule 5 /8143428875/ /105/
rule 6 /8143428876/ /106/
rule 7 /8143428877/ /107/
rule 8 /8143428878/ /108/
rule 9 /8143428879/ /109/
rule 15 /^...$/ /814348870/
voice translation-rule 5
rule 1 /8143428872/ /102/
rule 2 /8143428873/ /103/
rule 3 /8143428874/ /104/
rule 4 /8143428875/ /105/
rule 5 /8143428876/ /106/
rule 6 /8143428877/ /107/
rule 7 /8143428878/ /108/
rule 8 /8143428879/ /109/
voice translation-rule 6
rule 1 /8143428880/ /110/
rule 2 /8143428881/ /111/
rule 3 /8143428882/ /112/
rule 4 /8143428883/ /113/
rule 5 /8143428884/ /114/
rule 6 /8143428885/ /115/
rule 7 /8143428886/ /116/
rule 8 /8143428887/ /101/
voice translation-rule 7
rule 1 /8143428870/ /600/
rule 2 /18777773491/ /600/
rule 3 /18777773492/ /600/
rule 4 /8143428871/ /600/
voice translation-rule 8
rule 1 /8143428888/ /303/
voice translation-rule 9
rule 1 /8143425635/ /600/
voice translation-rule 12
voice translation-rule 13
rule 1 /8143428871/ /600/
voice translation-rule 14
rule 1 /8143428887/ /101/
voice translation-rule 200
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
voice translation-rule 2002
rule 2 /^A/ //
voice translation-rule 2222
voice translation-profile 5635-AA_Called_9
translate called 9
voice translation-profile 8870-AA_Called_12
translate called 12
voice translation-profile 8870-AA_Called_7
translate called 7
voice translation-profile 8871-AA_Called_13
translate called 13
voice translation-profile 8887_Called_14
translate called 14
voice translation-profile AA_Profile
translate called 2001
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile INCOMINIG_DID
translate called 1
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile bfax_Called_8
translate called 8
voice translation-profile did_Called_5
translate called 5
voice translation-profile did_Called_6
translate called 6
voice translation-profile nondialable
translate called 1000
voice translation-profile psr_Called_4
translate called 4
voice translation-profile psr_Called_5
translate called 5
voice-card 0
dspfarm
dsp services dspfarm
application
service aaservice0 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
  param aa-pilot 400
  paramspace english index 0
  param drop-through-prompt _bacd_welcome.au
  param second-greeting-time 60
  param welcome-prompt _bacd_welcome.au
  paramspace english language en
  param call-retry-timer 15
  param voice-mail 155
  param max-time-call-retry 600
  param service-name bacd
  param number-of-hunt-grps 1
  paramspace english location flash:/bacdprompts/
  param drop-through-option 1
  param handoff-string aaservice0
  param max-time-vm-retry 1
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
  param number-of-hunt-grps 10
  param queue-len 30
  param queue-cme-debugs 1
  param aa-hunt1 A400
license udi pid UC520-24U-8FXO-K9 sn FTX1218Z08E
archive
log config
  logging enable
  logging size 600
  hidekeys
username admin privilege 15 secret 5 $1$dW32$y.jHc8z9fDrvkBSdqkxbY1
username tthompson password 0 ""
controller T1 0/2/0
pri-group timeslots 1-24
ip tftp source-interface Loopback0
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Vlan2
ip nat inside
service-module ip address 192.168.2.5 255.255.255.0
service-module ip default-gateway 192.168.2.1
interface FastEthernet0/1/0
switchport voice vlan 2
macro description cisco-phone
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn sending-complete
no cdp enable
interface Vlan1
ip address 192.168.1.47 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan2
ip address 192.168.2.2 255.255.255.0
ip access-group 103 in
ip nat inside
interface BVI1
mtu 1514
no ip address
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 192.168.1.47 255.255.255.255 Integrated-Service-Engine0/0
ip route 192.168.2.5 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 192.168.2.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 192.168.2.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.2.0 0.0.0.255 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 192.168.2.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.2.0 0.0.0.255 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any log
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
voice-port 0/0/0
translation-profile incoming INCOMING_DID
timeouts ringing 36
station-id name main-fax
station-id number 300
caller-id enable
voice-port 0/0/1
station-id name Cordless Phone
station-id number 301
caller-id enable
voice-port 0/0/2
station-id name CreditCard
station-id number 302
caller-id enable
voice-port 0/0/3
timeouts ringing 36
station-id name Brian's Fax
station-id number 303
caller-id enable
voice-port 0/2/0:23
bearer-cap Speech
voice-port 0/1/0
connection plar opx 600
description Configured by CCA 4 FXO-0/1/0-Custom-AA
caller-id enable
voice-port 0/1/1
description Configured by CCA 4FXO-0/1/1-Custom-AA
caller-id enable
voice-port 0/1/2
description Configured by CCA 4FXO-0/1/2-Custom-AA
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-Custom-AA
caller-id enable
voice-port 0/3/0
description Configured by CCA 4FXO-0/3/0-Custom-AA
caller-id enable
voice-port 0/3/1
description Configured by CCA 4 FXO-0/3/1-Custom-AA
caller-id enable
voice-port 0/3/2
description Configured by CCA 4 FXO-0/3/2-Custom-AA
caller-id enable
voice-port 0/3/3
description Configured by CCA 4FXO-0/3/3-Custom-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 192.168.2.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711ulaw
codec g711alaw
maximum sessions 2
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
associate application SCCP
dial-peer cor custom
name internal
name local
name domestic
name international
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 1 pots
description ** CCA Analog Fax **
destination-pattern 300
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 301
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 302
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 303
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 500
b2bua
session protocol sipv2
session target ipv4:192.168.2.5
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
b2bua
codec g711ulaw
no vad
dial-peer voice 2005 pots
translation-profile incoming AA_Profile
incoming called-number 8143425635
direct-inward-dial
port 0/2/0:23
dial-peer voice 11 pots
description PRI 9911
preference 1
destination-pattern 9911
port 0/2/0:23
forward-digits 3
dial-peer voice 12 pots
description PRI 911
preference 1
destination-pattern 911
port 0/2/0:23
forward-digits 3
dial-peer voice 13 pots
description PRI Service
preference 1
destination-pattern 9[2-8]11
port 0/2/0:23
forward-digits 3
dial-peer voice 14 pots
description PRI 7 digits
preference 1
destination-pattern 9[2-9]......
port 0/2/0:23
forward-digits 7
dial-peer voice 15 pots
description PRI 11 digits
preference 1
destination-pattern 91[2-9].........
port 0/2/0:23
forward-digits 11
dial-peer voice 16 pots
description PRI International
preference 1
destination-pattern 9011T
port 0/2/0:23
prefix 011
dial-peer voice 21 pots
preference 2
port 0/1/0
forward-digits 3
dial-peer voice 22 pots
description PRI 911
preference 2
port 0/1/0
forward-digits 3
dial-peer voice 23 pots
preference 2
port 0/1/0
forward-digits 3
dial-peer voice 24 pots
preference 2
port 0/1/0
forward-digits 7
dial-peer voice 25 pots
preference 2
port 0/1/0
forward-digits 11
dial-peer voice 26 pots
preference 2
port 0/1/0
prefix 011
dial-peer voice 2004 pots
incoming called-number .T
direct-inward-dial
dial-peer voice 27 pots
translation-profile outgoing INCOMING_DID
destination-pattern 118
port 0/0/3
dial-peer voice 3000 pots
description did
translation-profile incoming did_Called_5
incoming called-number 814342887[2-9]
direct-inward-dial
port 0/2/0:23
dial-peer voice 3001 pots
description did
translation-profile incoming did_Called_6
incoming called-number 814342888[0-6]
direct-inward-dial
port 0/2/0:23
dial-peer voice 3002 pots
description 8870-AA
translation-profile incoming 8870-AA_Called_7
incoming called-number 8143428870
direct-inward-dial
port 0/2/0:23
dial-peer voice 3003 pots
description bfax
translation-profile incoming bfax_Called_8
incoming called-number 8143428888
direct-inward-dial
port 0/2/0:23
dial-peer voice 3007 pots
description 8870-AA
translation-profile incoming 8870-AA_Called_12
direct-inward-dial
port 0/2/0:23
dial-peer voice 3008 pots
description 8871-AA
translation-profile incoming 8871-AA_Called_13
incoming called-number 8143428871
direct-inward-dial
port 0/2/0:23
dial-peer voice 3009 pots
description 8887
translation-profile incoming 8887_Called_14
incoming called-number 8143428887
direct-inward-dial
port 0/2/0:23
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 5000 voip
description *** CCA BACD ***
service aaservice0
destination-pattern 400
session target ipv4:192.168.1.47
incoming called-number 400
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 1113 pots
destination-pattern 8143428888
port 0/0/3
dial-peer voice 3004 pots
description 5635-AA
translation-profile incoming 5635-AA_Called_9
direct-inward-dial
port 0/2/0:23
no dial-peer outbound status-check pots
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 5
sdspfarm tag 1 confprof1
conference hardware
max-ephones 32
max-dn 128
ip source-address 192.168.2.2 port 2000
max-redirect 20
auto assign 10 to 43
auto assign 5 to 8 type anl
caller-id block code *67
calling-number initiator
service phone videoCapability 0
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
url information http://192.168.1.1
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://192.168.2.1/voiceview/authentication/authenticate.do
load 7960-7940 P00308000500
load 7970 SCCP70.8-2-2SR2S
load 7971 SCCP70.8-2-2SR2S
time-zone 12
voicemail 500
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name jfinch secret 5 $1$bHfN$agXbta.pbTJbSzdxPb3mX.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
create cnf-files version-stamp 7960 Nov 13 2010 14:34:01
ephone-template  15
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized  Cfwdall Endcall Redial Pickup Meetme Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn ConfList RmLstC Acct Park Select Join
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  1
number 1000
intercom 1000
ephone-dn  2  dual-line
number 155
label Open Hours Voice Mail
description Open Hours Voice Mail
name Open Hours Voice Mail
call-forward all 500
call-forward busy 500
call-forward noan 500 timeout 20
ephone-dn  3
number 106
label Nick Washic
description Nick Washic
name Nick Washic
call-forward noan 500 timeout 24
hold-alert 30 originator
ephone-dn  6  dual-line
number 302 no-reg primary
label 302
description 302
name 302
ephone-dn  9
number BCD no-reg primary
description MoH
moh ip 239.10.16.8 port 2139 out-call ABC
ephone-dn  11  dual-line
number 102 no-reg primary
label 102
description Teresa Thompson
name Teresa Thompson
ephone-dn  12  dual-line
number 103 no-reg primary
label 103
description Robert Manners
name Robert Manners
call-forward noan 500 timeout 30
ephone-dn  13  dual-line
number 104
label 104
ephone-dn  14  dual-line
number 105 no-reg primary
label 105
description John Finch
name John Finch
ephone-dn  16  dual-line
number 107 no-reg primary
label 107
description Victoria Flango
name Victoria Flango
call-forward noan 500 timeout 10
corlist incoming user-international
ephone-dn  17  dual-line
number 108 no-reg primary
label 108
description Alyssa Martin
name Alyssa Martin
ephone-dn  18  dual-line
number 109 no-reg primary
label Teresa Thompson
ephone-dn  19  dual-line
number 110 no-reg primary
label 110
name John Finch
ephone-dn  20  dual-line
number 111
label 111
description Annex Shop
name Annex Shop
ephone-dn  21  dual-line
number 112 no-reg primary
label 112
description Teck Phone
name Teck Phone
ephone-dn  22  dual-line
number 113 no-reg primary
label 113
description Main UPS
name Main UPS
ephone-dn  23  dual-line
number 114 no-reg primary
label 114
description Terri Thompson
name Terri Thompson
ephone-dn  24  dual-line
number 115 no-reg primary
label 115
description Jim Bagrosky
name Jim Bagrosky
ephone-dn  25  dual-line
number 116
label 116
description Annex UPS
name Annex UPS
ephone-dn  26  dual-line
number 101 no-reg primary
label Brian Hoopsick
description 101
name Brian Hoopsick
huntstop channel
ephone-dn  36  dual-line
number 200
call-forward noan 150 timeout 40
huntstop channel
no huntstop
ephone-dn  37  dual-line
number 200
huntstop channel
no huntstop
ephone-dn  38  dual-line
number 200
huntstop channel
no huntstop
ephone-dn  39  dual-line
number 200
preference 1
huntstop channel
ephone-dn  100  dual-line
number 150 no-reg primary
label After Hours Voice Mail
description After Hours Voice Mail
name After Hours Voice Mail
ephone-dn  125  octo-line
number 771 no-reg primary
conference meetme
ephone-dn  126  octo-line
number C001 no-reg primary
conference ad-hoc
ephone-dn  127
number A801... no-reg primary
mwi off
ephone-dn  128
number A800... no-reg primary
mwi on
ephone  1
device-security-mode none
mac-address 001F.E23A.D360
ephone-template 16
type CIPC
ephone  2
video
mac-address 0021.55D5.B444
ephone-template 16
type 7941
button  1:14 2:2
pin 12345
ephone  5
video
mac-address 001C.58F9.8E75
ephone-template 16
username "bhoopsick" password 12345
type 7970
button  1:26
ephone  6
video
mac-address 001F.6C81.0030
ephone-template 16
username "jdfinch" password 12345
speed-dial 1 107 label "Victoria"
speed-dial 2 108 label "Alissa"
type 7960
button  1:19 2:2
pin 12345
ephone  7
video
mac-address 001F.9E24.3DC6
ephone-template 16
username "amartin" password 12345
type 7960
button  1:17 2:2 3:100
ephone  8
video
mac-address 001F.6C81.0147
ephone-template 16
username "VFlango" password 12345
type 7960
button  1:16 2:2 3:100
ephone  9
video
mac-address 001F.6C80.0B33
ephone-template 16
username "jspicer" password 12345
type 7960
button  1:18
ephone  10
video
mac-address 001F.6C81.0035
ephone-template 16
username "thoopsick" password 12345
type 7960
button  1:3 2:2 3:100
ephone  11
video
mac-address 0021.55D5.B73A
ephone-template 16
username "empty" password 12345
type 7941
button  1:13
ephone  12
video
mac-address 0021.55D5.B706
ephone-template 16
username "rmanners" password 12345
type 7941
button  1:12
ephone  14
video
mac-address 0021.55D5.B738
ephone-template 16
username "tthompson" password 12345
type 7970
button  1:11 2:2
ephone  15
video
mac-address 0021.55D5.B5E3
ephone-template 16
username "ausp" password 12345
type 7941
button  1:25
ephone  16
video
mac-address 0021.55D5.B642
ephone-template 16
username "tphone" password 12345
type 7941
button  1:21
ephone  17
video
mac-address 0021.55D5.B55C
ephone-template 16
username "mups" password 12345
type 7941
button  1:22
ephone  18
video
mac-address 0021.55D5.B337
ephone-template 16
username "tltompson" password 12345
type 7941
button  1:23
ephone  19
video
mac-address 001F.CA35.3E1D
ephone-template 16
username "jbagrosky" password 12345
type 7941
button  1:24 2:100
ephone  20
video
mac-address 001F.CA35.40BF
ephone-template 16
username "ashop" password 123456
type 7941
button  1:20
ephone-hunt 50 longest-idle
pilot A400
list 110, 102, 106, 107, 108, 109, 114, 115, 104
timeout 16, 16, 16, 16, 16, 16, 16, 16, 16
no-reg pilot
statistics collect
ephone-hunt 51 sequential
description *** Reserved for CCA BACD ***
ephone-hunt 52 sequential
ephone-hunt 53 sequential
ephone-hunt 54 sequential
ephone-hunt 55 sequential
ephone-hunt 56 sequential
ephone-hunt 57 sequential
ephone-hunt 58 sequential
ephone-hunt 59 sequential
banner login ^CCisco Configuration Assistant. Version: 2.2 (5). Sun Nov 07 17:57:54 EST 2010^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 5 100
ntp master
end
Brandon Buffin
If you turn on "debug voip dialpeer" and "term mon" and place the call, do you see the call hit the UC520? What dial peer is it matching?
Brandon
doesn't look like it is not getting a match
it should be matching this
dial-peer voice 3004 pots description 5635-AA
direct-inward-dial
port 0/2/0:23
translate called 9
prosatellite# ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8  callref = 0x01FC         Bearer Capability i = 0x8090A2                 Standard = CCITT                 Transfer Capability = Speech                 Transfer Mode = Circuit                 Transfer Rate = 64 kbit/s         Channel ID i = 0xA98381                 Exclusive, Channel 1         Facility i = 0x9F8B0100A10F02010106072A8648CE1500040A0100         Calling Party Number i = 0x2183, '8149341274'                 Plan:ISDN, Type:National         Called Party Number i = 0xA1, '8143425635'                 Plan:ISDN, Type:National ISDN Se0/2/0:23 Q931: Received SETUP  callref = 0x81FC callID = 0x004F switch = primary-5ess interface = User //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Calling Number=8149341274, Called Number=8143425635, Voice-Interface=0x87EA22 C4,   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,   Peer Info Type=DIALPEER_INFO_SPEECH //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=2005 //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0 //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Calling Number=8149341274, Called Number=8143425635, Voice-Interface=0x0,   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,   Peer Info Type=DIALPEER_INFO_FAX //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Result=NO_MATCH(-1) After All Match Rules Attempt //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   Calling Number=, Called Number=8143425635, Peer Info Type=DIALPEER_INFO_SPEEC H //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=8143425635 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1) //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1 //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:   Result=NO_MATCH(-1) //-1/A429CFB88039/CCAPI/cc_api_display_ie_subfields:   cc_api_call_setup_ind_common:   cisco-username=   ----- ccCallInfo IE subfields -----   cisco-ani=8149341274   cisco-anitype=2   cisco-aniplan=1   cisco-anipi=0   cisco-anisi=3   dest=8143425635   cisco-desttype=2   cisco-destplan=1   cisco-rdie=FFFFFFFF   cisco-rdn=   cisco-lastrdn=   cisco-rdntype=-1   cisco-rdnplan=-1   cisco-rdnpi=-1   cisco-rdnsi=-1   cisco-redirectreason=-1  fwd_final_type =0   final_redirectNumber =   hunt_group_timeout =0 //-1/A429CFB88039/CCAPI/cc_api_call_setup_ind_common:   Interface=0x87EA22C4, Call Info(   Calling Number=8149341274,(Calling Name=)(TON=National, NPI=ISDN, Screening=N etwork, Presentation=Allowed),   Called Number=8143425635(TON=National, NPI=ISDN),   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFl ag=TRUE,   Incoming Dial-peer=2005, Progress Indication=NULL(0), Calling IE Present=TRUE ,   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS E), Call Id=-1 //-1/A429CFB88039/CCAPI/ccCheckClipClir:   In: Calling Number=8149341274(TON=National, NPI=ISDN, Screening=Network, Pres entation=Allowed) //-1/A429CFB88039/CCAPI/ccCheckClipClir:   Out: Calling Number=8149341274(TON=National, NPI=ISDN, Screening=Network, Pre sentation=Allowed) //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: :cc_get_feature_vsa malloc success //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: cc_get_feature_vsa count is 5 //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: :FEATURE_VSA attributes are: feature_name:0,feature_time:2314744768,feature_id:6 90 //343/A429CFB88039/CCAPI/cc_api_call_setup_ind_common:   Set Up Event Sent;   Call Info(Calling Number=8149341274(TON=National, NPI=ISDN, Screening=Network , Presentation=Allowed),   Called Number=8143425635(TON=National, NPI=ISDN)) //343/A429CFB88039/CCAPI/cc_process_call_setup_ind:   Event=0x87709E60 //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:   Try with the demoted called number 8143425635 //343/A429CFB88039/CCAPI/ccCallSetContext:   Context=0x89C1F020 //343/A429CFB88039/CCAPI/cc_process_call_setup_ind:   >>>>CCAPI handed cid 343 with tag 2005 to app "_ManagedAppProcess_Default" //343/A429CFB88039/CCAPI/ccCallProceeding:   Progress Indication=NULL(0) //-1/A429CFB88039/DPM/dpMatchPeersCore:   Calling Number=, Called Number=8143425635, Peer Info Type=DIALPEER_INFO_SPEEC H //-1/A429CFB88039/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=8143425635 //-1/A429CFB88039/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1) //-1/A429CFB88039/DPM/dpMatchSafModulePlugin:   dialstring=8143425635, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1 //-1/A429CFB88039/DPM/dpMatchPeersMoreArg:   Result=NO_MATCH(-1) //-1/A429CFB88039/DPM/dpMatchPeersCore:   Calling Number=, Called Number=8143425635, Peer Info Type=DIALPEER_INFO_SPEEC H //-1/A429CFB88039/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=8143425635 //-1/A429CFB88039/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1) //-1/A429CFB88039/DPM/dpMatchSafModulePlugin:   dialstring=8143425635, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1 //-1/A429CFB88039/DPM/dpMatchPeersMoreArg:   Result=NO_MATCH(-1) //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   Calling Number=8143425635, Called Number=8143425635, Peer Info Type=DIALPEER_ INFO_SPEECH //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=8143425635 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1) //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=8143425635, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:   Result=NO_MATCH(-1) //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Calling Number=8143425635, Called Number=, Voice-Interface=0x0,   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,   Peer Info Type=DIALPEER_INFO_SPEECH //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Result=NO_MATCH(-1) After All Match Rules Attempt //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1 //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Calling Number=8143425635, Called Number=, Voice-Interface=0x0,   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,   Peer Info Type=DIALPEER_INFO_SPEECH //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Result=NO_MATCH(-1) After All Match Rules Attempt //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   Calling Number=, Called Number=8143425635, Peer Info Type=DIALPEER_INFO_SPEEC H //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=8143425635 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1) //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=8143425635, saf_enabled=0, saf_dndb_lookup=1, dp_result=-1 //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:   Result=NO_MATCH(-1) //-1/A429CFB88039/DPM/dpMatchPeersCore:   Calling Number=, Called Number=8143425635, Peer Info Type=DIALPEER_INFO_SPEEC H //-1/A429CFB88039/DPM/dpMatchPeersCore:   Match Rule=DP_MATCH_DEST; Called Number=8143425635 //-1/A429CFB88039/DPM/dpMatchPeersCore:   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1) //-1/A429CFB88039/DPM/dpMatchSafModulePlugin:   dialstring=8143425635, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1 //-1/A429CFB88039/DPM/dpMatchPeersMoreArg:   Result=NO_MATCH(-1) //343/A429CFB88039/CCAPI/ccCallDisconnect:   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Ca use=0) //343/A429CFB88039/CCAPI/ccCallDisconnect:   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1) //343/A429CFB88039/CCAPI/cc_api_get_transfer_info:   Transfer Number Is Null ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x81FC         Channel ID i = 0xA98381                 Exclusive, Channel 1 ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x81FC         Cause i = 0x8081 - Unallocated/unassigned number ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x01FC ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81FC //343/A429CFB88039/CCAPI/cc_api_call_disconnect_done:   Disposition=0, Interface=0x87EA22C4, Tag=0x0, Call Id=343,   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0) //343/A429CFB88039/CCAPI/cc_api_call_disconnect_done:   Call Disconnect Event Sent //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: :cc_free_feature_vsa freeing 89F833B8 //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: vsacount in free is 4 //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Calling Number=, Called Number=, Voice-Interface=0x0,   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,   Peer Info Type=DIALPEER_INFO_SPEECH //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:   Result=NO_MATCH(-1) After All Match Rules Attempt //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Looks like it is matching dial peer 2005 which has the same incoming called number configured. Remove this dial peer with "no dial-peer voice 2005" and test again.
Hope this helps.
Brandon
that was it i guess i've been looking at it to hard  and a fresh set of eyes helps thanks brandon
