UC 540 and Voicemail
Hi, I have SBS 2011 and UC 540 and I wanted to configure UC 540 to forward all voicemails to Exchange 2010. Unfortunatelly unsuccessfull. In voicemail (configuration Assistant) I checked Enable voicemail Notification, and enable email notification, populated fields like OUtgoing Email Reply to address, SMTP server address and port.  On Notification tab I craeted user, extension and email address. With this config it didn't work. So I created on Exchange 2010 new receive connector I added IP of UC, adn still nothing.
I found some datasheets how to configure via Unity express, I was using Cisco Configuration Assistant. Which CLI commands can I use to check what is going on , and if possible to configure SMTP server , voicemail ...
Also Voicemail is enabled in Users and devices.
Thanks.
P.S. I configured IMAP connection with Unified messaging (Smart Application) and that worked, but it would be nice if only one mailbox can be used .
Please any help is appreciated.
The first thing I would check, is to see if you can ping both ways, from the Exchange server to the CUE subnet.  You may need to add a route to a router, if there is one on your network, or you may need to add a route on the Exchange server itself.  My first question would be "What is the default gateway of the Exchange server?"  If it is not the UC500, a route is likely needed somewhere, depending on your topology.
Thank you,
Darren
5 Replies 5
David Trad
Hi Aleksandar,
The only way I am aware of how this can work is that on the clients side (The Users PC) you configure a new INBOX to point to the CUE's IP address, which by default will be 10.1.10.1 unless you changed it.
In order for this to work you would then need to make sure that your Inter-Vlan-Routing is working so that way users on the Data subnet can route to the users on the Voice/CUE subnet.
This is not a direct Exchange integration, rather a User level integration using their Outlook account and creating a IMAP connection to the CUE.
I have heard of some places creating an IMAP service within Exchange and then on the Exchange server working out a distribution method, however I am not Exchange expert and cannot advise you on how this is done, but I do know it is just easy and simple to create a new IMAP account on the users end and have it point to their Mail-Box ID, this way if they delete it from their Outlook it will also delete it from the UC.
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David, thank you for your answer. I already configured IMAP with separate account in Microsoft Outlook. It looks great but if user is not in the office we use Exchange ActiveSync to deploy email to mobile. And that means that he wont get email (ok we need to provide one more connection to UC but then all other users that use IMAP to connect to exchange will be lost). I read here about how to configure UC and mail server to work together.
Here is the debug log file :
Press to exit...
2283 08/22 10:49:57.211 capi smtp 0 SmtpSysdbNode: commit(): Attribute: authRequired,Value: false
32211 08/22 11:05:41.093 VMSS mnot 0 MessageNotification: Enter insertIntoMsgNotifQueue(): msg recipient: User1notif target: User1
32211 08/22 11:05:41.167 capi smtp 0 SmtpServer: getSysdb(): Attribute: address
2283 08/22 11:05:41.169 capi smtp 0 SmtpSysdbNode: get(): address
32211 08/22 11:05:41.169 VMSS mnot 0 MessageNotification: query: INSERT INTO outall_email_job VALUES ('User1', 48, 1345626341094, 37, 0, 'User1');
32211 08/22 11:05:41.202 VMSS mnot 0 MessageNotification: Notifying sender threads
32211 08/22 11:05:41.202 VMSS mnot 0 MessageNotification: Exit insertIntoMsgNotifQueue(): notifyEmailThread=true, notifyPhoneThread=false
3014 08/22 11:05:41.293 VMSS mnot 0 EmailSender: Processing job: 1
3014 08/22 11:05:41.314 VMSS mnot 0 EmailSender:
  Got a job: [owner_id=User1, contact=user1@domain.com, extra_text=null, nextSendTime=1345626341094, device_type=32, device_id=48, retryCount=0, targetId=User1, attach_vm=true, isUrgent=false,
  isPrivate=false, ndrreason=0, uid=37, messagetype=1, preferenceA, sender=25, callerName=Caller 1
3014 08/22 11:05:41.319 VMSS mnot 0 EmailSender: sendEmailNotification: checkSendPreConditions passed
3014 08/22 11:05:41.319 capi smtp 0 SmtpServer: getSysdb(): Attribute: address
2294 08/22 11:05:41.320 capi smtp 0 SmtpSysdbNode: get(): address
3014 08/22 11:05:41.321 capi smtp 0 SmtpServer: getSysdb(): Attribute: port
2283 08/22 11:05:41.322 capi smtp 0 SmtpSysdbNode: get(): port
3014 08/22 11:05:41.322 capi smtp 0 SmtpServer: getSysdb(): Attribute: userid
2314 08/22 11:05:41.323 capi smtp 0 SmtpSysdbNode: get(): userid
3014 08/22 11:05:41.324 capi smtp 0 SmtpServer: getSysdb(): Attribute: password
2313 08/22 11:05:41.325 capi smtp 0 SmtpSysdbNode: get(): password
3014 08/22 11:05:41.325 capi smtp 0 SmtpServer: getSysdb(): Attribute: authRequired
2294 08/22 11:05:41.326 capi smtp 0 SmtpSysdbNode: get(): authRequired
3014 08/22 11:05:41.333 VMSS mnot 0 EmailSender: Begin processing email job, UID=37
3014 08/22 11:05:41.363 VMSS mnot 0 EmailSender: Attachment body part added, UID=37
3014 08/22 11:07:41.416 VMSS mnot 0 EmailSender: Error sending email, UID= 37 :javax.mail.SendFailedException: Sending failed;
  nested exception is:
        class javax.mail.MessagingException: Could not connect to SMTP host: 192.168.10.6, port: 25;
        java.net.ConnectException: connection to 192.168.10.6 timed out
3014 08/22 11:07:41.416 VMSS mnot 0 EmailSender: Send email rc=2
3014 08/22 11:07:41.416 VMSS mnot 0 EmailSender: Deleting email job: Device ID=48, UID=37
3014 08/22 11:07:41.539 VMSS mnot 0 EmailSender: calculateWaitTime(): current time: 1345626461537, job time: 0
3014 08/22 11:07:41.539 VMSS mnot 0 EmailSender: Wait time=0
Exchange is in 192.168.10.0 subnet.  I think but I am not sure that UC is sending from 10.1.10.1 .. Do I need some sort of a email transport in order to transfer email from one subnet to another
Thank you,
Darren
You were right. I just added route and everything worked perfectly.
