01-26-2012 05:29 AM - edited 03-21-2019 05:15 AM
Hi Everyone,
Are you able to disable call waiting tones on UC320 SPA handsets? We have a customer who is experiencing high call volumes as part of a hunt group so would like to disable the "beeps".
Thanks a lot
Matt
Solved! Go to Solution.
01-26-2012 03:01 PM
Hi Matt,
Are you on a current release like 2.1.4(3)? Very early releases had the call waiting tones enabled, but current releases have the Call Waiting Tones diabled by default unless you specifically enable them via a PMF.
There is a setting on the phone LCD screen under the settings menu to enable/diable call waiting tone.
Chris
01-26-2012 03:01 PM
Hi Matt,
Chris
01-27-2012 05:01 AM
Hi Chris,
I hope you're well? Thanks for the info I didnt realise there was a user setting.. I did see the PMF file to enable the feature which confused me a little. I suspect the user has enabled the feature by accident so I'll investigate.
Thanks for your help.
Matt
