UC320 firewall
canadianicon25
What settings are there by default in the 320's firewall?  What is the behaviour, so to speak, of this firewall.  Are there any documents that talk about this?
bmccoy
Feature description guide:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps11388/guide_c07-641629.pdf
It says:
Basic firewall provides support for port forwarding and inbound firewall.
David Trad
Hi There,
I would highly recommend you place before the UC either an IOS enabled router such as the 800 series or an SRP series router, or even the SR range, this will give you ACL capabilities or standardized SPI/Firewall setups.
Just a thought, we put the SRP routers in front of them and just turn of the WiFi, or if you want a Guest access WiFi you can enable it on the SRP and then leave the UC WiFi for internal use.
Just a thought.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I would recommend a SA500 if you need a robust firewall.
