UC320 - how to disable send ext. as Clid
abxeoeinkauf
I hope, someone can help me:
I have installed a UC320w, use 1 Sip-Client and calling in and out is no problem, but I cannot manage to disable, that outgoing calls send the CLID Extension with them;
I have tried to manage it with the inbound rules, but even if I disable the checkbox (use 12345601 as calling line id) the extension is sent.
Any idea, how to disable this?
thanks.
Nima Norbu
Hi Mario,
we don't have a phone setting to block it. One  workaround would be to have your incoming trunk (FXO or SIP) configured by your provider not to deliver caller ID.However using star code,  outgoing clid was able to block succesfully.
Please try the following steps.
From SPA phone go off hook and enter *81.  You should hear confirmation tone.
Then dial 8 or 9 to select your trunk and enter the called party number.
Nima
