UC500 BRI/GSM Gateway Solution
SteveOrfanos
Level 5
Level 5
Hi All
I am looking at providing a solution for a customer who has 3 ISDN BRI's (6 voice channels) on his existing PABX and a GSM Gateway for outgoing calls.The problem is I can't build a solution for him on the UC500 platform that can support his ISDN requirements plus an FXO port to accommodate his PSTN/GSM Gateway.
Am I missing something? Can the UC560 with 4 FXS/FXO ports support 2 x BRI VICS in the expansion slots.
Appreciate your help.
Steve
Alberto Montilla
Dear Sir;
You can use a UC560-BRI-K9 and add one additional BRI card plus one additional FXO card, or the combination you mentioned below. This would make the deal.
Alberto
Alberto Montilla
Dear Sir;
Alberto
Thanks Alberto,
Are there any limitations with the expansion slots when designing a solution with a UC560. Can you use any combination of VIC's (T1/E1, BRI, FXO, FXS). If the customer decided to increase his ISDN BRI to 6 (12 voice channels) and remove the GSM gateway can we use the UC560-BRI-K9 with 2 additional BRI VIC's.
Steve
