08-23-2011 02:11 AM - edited 03-21-2019 04:33 AM
Is it possible to remove the instructions that come at the end of a users greeting message? The instructions that say
"leave your message at the tone, when you are finished hang up or press hash/pound for other options"?
Thanks.
Solved! Go to Solution.
08-23-2011 06:38 PM
OK, I double check with our DE and we do have a way to remove that system prompt.
However, you need to do it via cli.
Once the cli activate, the impact is system wide.
In CUE prompt...
conf t
no voicemail conversation caller recording-prompt
end
The above configuration will remove the prompt you mentioned.
-David Liao
08-23-2011 09:16 AM
No, it is part of system prompt.
-David
08-23-2011 03:58 PM
Hi David,
Drop a line to your Dev/BU team and let them know that 95% of the systems out there allow you to add your own so this can be modified and a client can get their own professional recordings done...
I am more than happy to provide them with a list of all competing products that do this...
Personally I like the default prompts, but the amount of times I get asked if this could be change, and If I was paid 1$ for it, I would have plenty of Beer money to satisfy me every week
I hope you can convey this to the powers above
Cheers,
David.
08-23-2011 06:38 PM
In CUE prompt...
conf t
end
-David Liao
08-25-2011 12:24 AM
Thanks David x 2 works a treat!!
