UC520 Outgoing Call Digit
Jesse Shumaker
anyone know how I can change the digit that must be pushed to get access to an outgoing line?
thanks
5 Replies 5
Hi Jesse,
If you are using CCA please go to configure->telephony->dial plan->outgoing dial plan. There you may change the prefix.
If you are using CLI you need to modify the dial-peer for outbound calls and under the outgoing voip dialppers you need to add translation rules.
HTH,
Alex
*Please rate helpful posts
This is the area I felt I should change and we wanted to dial 8 for that outside line but when I changed the bolded area's destination pattern to start out with 8 there were issues and I didn't get to an outside line? could something be conflicting or did I miss something? thanks
dial-peer voice 54 pots
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 55 pots
preference 5
destination-pattern 911
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 56 pots
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 57 pots
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 58 pots
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 60 pots
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 9011T
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 61 pots
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 62 pots
preference 5
destination-pattern 91888.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 63 pots
preference 5
destination-pattern 91877.......
port 0/2/0:23
forward-digits all
no sip-register
dial-peer voice 64 pots
preference 5
destination-pattern 91866.......
port 0/2/0:23
forward-digits all
no sip-register
Hi Jesse,
Please check the rules in the OUTGOING_TRANSLATION_PROFILE how the digit manipulation is done.
HTH,
Alex
voice translation-rule 1112
rule 1 /^9/ //
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
I figured it out with that little push from Alexander. thanks. basically these are the areas that need to be changed. cisco is nice and modulated so one item references another. I think this situation is nested about 3 levels deep. I'll document to help others.
Change the rule to look for 8 in that first digit
rule 1 /^8/ //
Have a voice translation profile setup which references the voice rule we just made
have your dial peers change their outgoing pattern and make sure it references the translation profile above
preference 5
destination-pattern 8[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 8[2-9]11
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81[2-9]..[2-9]......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 8011T
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81800.......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81888.......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81877.......
port 0/2/0:23
forward-digits all
no sip-register
preference 5
destination-pattern 81866.......
port 0/2/0:23
forward-digits all
no sip-register
to change dial tone to 8 do the following
telephony-service
  secondary-dialtone 8
