UC540 and VoIP.MS
jlauer
I have just installed a Cisco UC540 and connected both in and outbound VoIP lines with VoIP.MS the issue that I keep running into is the inbound calls stop or do not get routed?
The system will work perfect until no outbound or in bound calls are made for example first thing in the morning after no one has been in the office overnight. Calls will not get routed to the UC540?
Help?
paolo bevilacqua
Update IOS, then if still triuble, you will need to take traces, etc.
I have updated the Firware on the Box as per tech support, I am assuming that is the ISO
