UC540 + ASA5505 SIP issue
lukaszzyla
Hi Guys!
I am no professional, just an enthusiast. I am managing smb office with 20 employees.
We have just purchased UC540 as a new voip device.
We have ASA5505 (8.2 with asdm 7.1(3)) with security plus licence.
ASA is configured as a router/firewall with a public ip.
inside network is 192.168.1.0, UC is connected through LAN port and data network is set to 192.168.1.2
DHCP on UC data network is disabled and windows DC takes care of it (DHCP relay configured)
WAN port on UC is disabled.
voice network is 10.1.1.1
CUE is 10.1.10.2
I configured static route on UC for 0.0.0.0/0.0.0.0 with default gateway being ASA.
I managed to register with my voip provider and can make calls, but cannot receive any ;-(
My ACL and NAT knowlegde on ASA is very limited and everything i have configured was through experiments.
unfortunatelly I am using ASDM and not CLI - my CLI knowledge is next to none ;-)
I have been trying to make it work for 2 weeks already and am very close to giving up.
Can somebody help me please?
I believe problem lies with ASA config, as when testing UC with directly connected WAN I did not have issues.
I configured many things on ASA and made so many different versions of config that I do not know where to look for the problem now.
I read too many documents and forums. I am not even sure know where to go next and what to try
I am hoping maybe one of you could help?
My question is:
1. what should my acl look like?
In the beginning i allowed on the OUTSIDE interface:
ANY to OUTSIDE INTERFACE
UDP/4000-6500
UDP/10000-20000
tcp-udp/5060
tcp-udp/5061
udp/domain
udp/snmp
udp/ntp
udp/snmptrap
What am I doing wrong here?
2. NAT
inside:
i configured NAT EXEMPT for:
inside network to 10.1.10.0
10.1.10.0 to inside network
also added static policies for:
original: src: 10.1.10.2 (tried also with UC data ip 192.168.1.2) TRANSLATED: interface:outside address:outside interface with DNS rewrite for:
udp/5060-5061
tcp/5060-5061
wasnt able to forward port ranges for rtp(udp: 4000-6500 and 10000-20000)
i also experimented with service policy rules:
added:
global policy:
global class, match, any, any, default inspection: sip, sccp, h323 h225, h323 ras
Please help!
is there anybody who could help??!!
I'm despaired!
Lukasz
lukaszzyla
here is my config:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address WAN1 255.255.255.0
ipv6 enable
interface Ethernet0/0
switchport access vlan 2
dns domain-lookup inside
dns server-group DefaultDNS
name-server DC
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network obj_any
object-group icmp-type DM_INLINE_ICMP_1
icmp-object echo
icmp-object echo-reply
icmp-object time-exceeded
icmp-object traceroute
icmp-object unreachable
object-group service DM_INLINE_SERVICE_1
service-object tcp eq sip
service-object udp eq domain
service-object udp eq ntp
service-object udp eq snmp
service-object udp eq snmptrap
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group service DM_INLINE_SERVICE_2
service-object tcp-udp eq sip
service-object tcp-udp eq 5061
object-group service DM_INLINE_UDP_1 udp
port-object range 10000 20000
port-object range 4000 6500
access-list outside_access_in extended permit icmp any interface outside object-group DM_INLINE_ICMP_1 inactive
access-list outside_access_in remark do zmiany z any na ip providera? ew ntp i moze inne protokoly do osobnych
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any interface outside
access-list outside_access_in extended permit tcp any interface outside object-group DM_INLINE_TCP_1
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in extended permit tcp any interface outside eq 8080
access-list outside_access_in extended permit udp any interface outside object-group DM_INLINE_UDP_1
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_2 any interface outside
access-list inside_nat0_outbound extended permit ip any 192.168.1.240 255.255.255.240
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.1.240 255.255.255.240
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 ucvoice-network 255.255.255.0
access-list inside_nat0_outbound extended permit ip ucvoice-network 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_access_in extended permit ip host IIS any
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit ip host NAS any
access-list inside_access_in extended deny tcp any any eq smtp
arp timeout 14400
global (inside) 1 interface
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface https IIS https netmask 255.255.255.255  dns tcp 200 200 udp 200
static (inside,outside) tcp interface www IIS www netmask 255.255.255.255  dns tcp 200 200 udp 200
static (inside,outside) tcp interface smtp IIS smtp netmask 255.255.255.255  dns
static (inside,outside) tcp interface pop3 IIS pop3 netmask 255.255.255.255  dns
static (inside,outside) tcp interface 8080 NAS 8080 netmask 255.255.255.255  dns
static (inside,outside) udp interface 5061 10.1.10.2 (tried also with 192.168.1.2 - UC Data network) 5061 netmask 255.255.255.255  dns
static (inside,outside) tcp interface 5061 10.1.10.2 5061 netmask 255.255.255.255  dns
static (inside,outside) udp interface sip 10.1.10.2 sip netmask 255.255.255.255  dns
static (inside,outside) tcp interface sip 10.1.10.2 sip netmask 255.255.255.255  dns
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.x
route inside 10.1.1.0 (ucvoice-network) 255.255.255.0 192.168.1.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
Hi Lukasz,
When you say you cannot receive calls does that mean one way audio or phones not ringing at all?
If they are not ringing it would be something stopping the traffic on the ASA. I would allow all traffic from IP addresses of your sip provider to the public IP (the NAT-ed) address on the ASA for the sake of this test. Then go onto the UC and do a debug (debug ccsip messages) and see if something comes up when you dial the SIP number.
Cheers,
David
