03-13-2014 05:05 AM - edited 03-21-2019 08:09 AM
Here is the layout..
We have site A and site B.
Call comes into site A and goes directly to hunt group 502
Hunt group 502 is set to ring one member on site A then if not answered goes to hunt group 503
Hunt group 503 is set to ring one member on site B then if not answered goes to the auto attendant on site B
When calling in, the phone will ring a few times then end up at the Auto attendant. It seems to be skipping all the steps in between.This once worked but something was altered when editing via CCA and CLI... it messed it up. I know from the test that it does forward across the VPN tunnel to site B because it gets to the auto attendant fine, but even the local extension at site A doesn't seem to be called when an incoming call is routed. Configuration below with debugs toward the bottom.
The voice-port config is this:
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 502
description Configured by CCA 4 FXO-0/1/0-Custom-OP
caller-id enable
voice-port 0/1/1
description Configured by CCA 4FXO-0/1/1-Custom-OP
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-Custom-OP
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-Custom-OP
caller-id enable
The hunt groups are set like this:
ephone-hunt 2 sequential
pilot 502
list 306
final 503
timeout 8
no-reg pilot
statistics collect
ephone-hunt 3 sequential
pilot 503
list 216 <-- This extension is on site B. See below for config
final 81398 <-- this has the prefix to get forwarded to site B's AA
timeout 8
no-reg pilot
statistics collect
The site A extension 306 is configured on site A like this:
ephone-dn 28 dual-line
number 306 no-reg primary
label Receptionist x306
description Receptionist
call-forward busy 399
call-forward noan 399 timeout 20
The site B extension 216 is configured on site A like this:
ephone-dn 33 dual-line
number 216 no-reg primary
label Robin x216
call-forward all 81216 <-- causes the number to be forwarded to site B
Output of the debug voice ccapi inout. At 000558 you can see the incomming call is forwarded to 502, at 000616 the call is forwarded to an odd destination that I'm unsure about, at 000707 is seems like something is happening with 503 but I don't see it forwarded, at 000752 it gets forwarded to AA at 81398. Ideas?
Thanks!!!
000558: //-1/E5340FE78025/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=9703001769
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=502
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=0 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
000559: //-1/E5340FE78025/CCAPI/cc_api_call_setup_ind_common:
Interface=0x884D9660, Call Info(
Calling Number=9703001769,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=502(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=69, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
000560: //-1/E5340FE78025/CCAPI/ccCheckClipClir:
In: Calling Number=9703001769(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000561: //-1/E5340FE78025/CCAPI/ccCheckClipClir:
Out: Calling Number=9703001769(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
000562: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000563: :cc_get_feature_vsa malloc success
000564: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000565: cc_get_feature_vsa count is 3
000566: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000567: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332101624,feature_id:33
000568: //9/E5340FE78025/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=9703001769(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=502(TON=Unknown, NPI=Unknown))
000569: //9/E5340FE78025/CCAPI/cc_process_call_setup_ind:
Event=0x88478A60
000570: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 502
000571: //9/E5340FE78025/CCAPI/ccCallSetContext:
Context=0x8B03665C
000572: //9/E5340FE78025/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 9 with tag 69 to app "_ManagedAppProcess_Default"
000573: //9/E5340FE78025/CCAPI/ccCallProceeding:
Progress Indication=NULL(0)
000574: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
type=6 redirecting_number=502
000575: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=502, Called Number=502, Calling Number=9703001769, Calling DN=-1 Calling Id=9,
Redirect Number=A502A0100, Redirect Reason=15
000576: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
000577: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000578: :cc_get_feature_vsa malloc success
000579: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000580: cc_get_feature_vsa count is 4
000581: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000582: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100952,feature_id:34
000583: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000584: feature_vsa is 8B010BF0,featname is 0
000585: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000586: :cc_get_feature_vsa malloc success
000587: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000588: cc_get_feature_vsa count is 5
000589: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000590: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100280,feature_id:35
000591: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000592: : Generating new featurevsa,inserting it
000593: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000594: feature call forward featname is 1
000595: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000596: :cc_free_feature_vsa freeing 8B010950
000597: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000598: vsacount in free is 4
000599: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000600: :cc_get_feature_vsa malloc success
000601: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000602: cc_get_feature_vsa count is 5
000603: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000604: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100952,feature_id:36
000605: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000606: feature call forward featname is 1
000607: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000608: :cc_free_feature_vsa freeing 8B010950
000609: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000610: vsacount in free is 4
000611: //9/E5340FE78025/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=20036, Params=0x8B037B6C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
000612: //9/E5340FE78025/CCAPI/ccCheckClipClir:
000613: //9/E5340FE78025/CCAPI/ccCheckClipClir:
000614: //9/E5340FE78025/CCAPI/ccCallSetupRequest:
Destination Pattern=A502A0100, Called Number=A502A0100, Digit Strip=TRUE
000615: //9/E5340FE78025/CCAPI/ccCallSetupRequest:
Called Number=A502A0100(TON=Unknown, NPI=Unknown),
Redirect Number=502, Display Info=
Account Number=, Final Destination Flag=TRUE,
Guid=E5368087-A9D9-11E3-8029-D4AA1B98B2FC, Outgoing Dial-peer=20036
000616: //9/E5340FE78025/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=A502A0100
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=502
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=15 fwd_final_type =0
hunt_group_timeout =8
000617: //9/E5340FE78025/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x8946E098, Interface Type=6, Destination=, Mode=0x0,
Call Params(Calling Number=9703001769,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=A502A0100(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20036, Call Count On=FALSE,
Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
000618: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000619: :cc_get_feature_vsa malloc success
000620: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000621: cc_get_feature_vsa count is 5
000622: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000623: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100952,feature_id:37
000624: //10/E5340FE78025/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
000625: //10/E5340FE78025/CCAPI/ccCallSetContext:
Context=0x8B037B1C
000626: //9/E5340FE78025/CCAPI/ccSaveDialpeerTag:
000627: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000628: feature call forward featname is 1
000629: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000630: feature_vsa is 8B010950,featname is 0
000631: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000632: :cc_get_feature_vsa malloc success
000633: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000634: cc_get_feature_vsa count is 6
000635: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000636: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100056,feature_id:38
000637: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000638: : Generating new featurevsa,inserting it
000639: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000640: feature call forward featname is 1
000641: //10/E5340FE78025/CCAPI/cc_api_update_call_info:
Interface=0x8946E098, Call Id=0xA
LSL02-UC-01#
000642: //10/E5340FE78025/CCAPI/cc_api_call_proceeding:
Interface=0x8946E098, Progress Indication=NULL(0)
000643: //10/E5340FE78025/CCAPI/cc_api_call_alert:
Interface=0x8946E098, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
000644: //10/E5340FE78025/CCAPI/cc_api_call_alert:
Call Entry(Retry Count=0, Responsed=TRUE)
000645: //9/E5340FE78025/CCAPI/ccCallAlert:
000646: //9/E5340FE78025/CCAPI/ccCallAlert:
Call Entry(Responsed=TRUE, Alert Sent=TRUE)
000647: //10/E5340FE78025/CCAPI/ccCallFeature:
Feature Type=25, Call Id=10
LSL02-UC-01#
000648: //10/E5340FE78025/CCAPI/cc_api_call_disconnected:
Cause Value=19, Interface=0x8946E098, Call Id=10
000649: //10/E5340FE78025/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
000650: //9/E5340FE78025/CCAPI/ccCallReleaseResources:
release reserved xcoding resource.
000651: //10/E5340FE78025/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
000652: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=A502A0100, Called Number=A502A0100, Calling Number=9703001769, Calling DN=-1 Calling Id=9,
Redirect Number=503, Redirect Reason=2
000653: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
000654: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000655: :cc_get_feature_vsa malloc success
000656: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000657: cc_get_feature_vsa count is 7
000658: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000659: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100728,feature_id:39
000660: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000661: feature_vsa is 8B0106B0,featname is 1
000662: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000663: feature_vsa is 8B010BF0,featname is 0
000664: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000665: :cc_get_feature_vsa malloc success
000666: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000667: cc_get_feature_vsa count is 8
000668: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000669: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332101176,feature_id:40
000670: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000671: : Generating new featurevsa,inserting it
000672: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000673: feature call forward featname is 3
000674: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000675: feature_vsa is 8B0105D0,featname is 1
000676: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000677: feature_vsa is 8B010950,featname is 0
000678: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000679: :cc_get_feature_vsa malloc success
000680: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000681: cc_get_feature_vsa count is 9
000682: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000683: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100504,feature_id:41
000684: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000685: : Generating new featurevsa,inserting it
000686: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000687: feature call forward featname is 3
000688: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000689: :cc_free_feature_vsa freeing 8B010870
000690: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000691: vsacount in free is 8
000692: //10/E5340FE78025/CCAPI/ccCallSetAAA_Accounting:
Accounting=0, Call Id=10
000693: //10/E5340FE78025/CCAPI/ccCallDisconnect:
Cause Value=19, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
000694: //10/E5340FE78025/CCAPI/ccCallDisconnect:
Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
000695: //10/E5340FE78025/CCAPI/cc_api_get_transfer_info:
000696: //9/E5340FE78025/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Null,
Tone Direction=Network, Params=0x0, Call Id=9
000697: //10/E5340FE78025/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x8946E098, Tag=0x0, Call Id=10,
Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
000698: //10/E5340FE78025/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
000699: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000700: :cc_free_feature_vsa freeing 8B010790
000701: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000702: vsacount in free is 7
000703: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000704: vsacount in free is 6
000705: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000706: vsacount in free is 5
000707: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
type=6 Original Called Number=503, Called Number=503, Calling Number=9703001769, Calling DN=-1 Calling Id=9,
Redirect Number=A503A0200, Redirect Reason=15
000708: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
type=6 redirecting_number=503
000709: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000710: :cc_get_feature_vsa malloc success
000711: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000712: cc_get_feature_vsa count is 6
000713: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000714: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100952,feature_id:42
000715: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000716: feature_vsa is 8B010A30,featname is 3
000717: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000718: :cc_get_feature_vsa malloc success
000719: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000720: cc_get_feature_vsa count is 7
000721: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000722: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100056,feature_id:43
000723: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000724: : Generating new featurevsa,inserting it
000725: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000726: feature call forward featname is 1
000727: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000728: :cc_free_feature_vsa freeing 8B010950
000729: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000730: vsacount in free is 6
000731: //-1/xxxxxxxxxxxx/CCAPI/cc_find_feature_vsa:
000732: inside while in find feature_sa
000733: //-1/xxxxxxxxxxxx/CCAPI/cc_find_feature_vsa:
000734: inside while in find feature_sa
000735: //-1/xxxxxxxxxxxx/CCAPI/cc_find_feature_vsa:
000736: inside while in find feature_sa
000737: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000738: feature_vsa is 8B0105D0,featname is 1
000739: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000740: feature_vsa is 8B010A30,featname is 3
000741: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000742: feature_vsa is 8B0106B0,featname is 1
000743: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000744: : updating existing feature vsa
000745: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000746: feature call basic
000747: //9/E5340FE78025/CCAPI/ccCallSetupRequest:
Outgoing Dial-peer=2101, Params=0x8B03902C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
000748: //9/E5340FE78025/CCAPI/ccCheckClipClir:
000749: //9/E5340FE78025/CCAPI/ccCheckClipClir:
000750: //9/E5340FE78025/CCAPI/ccCallSetupRequest:
Destination Pattern=81..., Called Number=81398, Digit Strip=FALSE
000751: //9/E5340FE78025/CCAPI/ccCallSetupRequest:
Called Number=81398(TON=Unknown, NPI=Unknown),
Guid=E9FF7C3C-A9D9-11E3-802F-D4AA1B98B2FC, Outgoing Dial-peer=2101
000752: //9/E5340FE78025/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=
cisco-ani=9703001969
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=81398
cisco-desttype=0
cisco-destplan=0
cisco-rdie=73
cisco-rdn=502
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
000753: //9/E5340FE78025/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x872D2EB4, Interface Type=1, Destination=, Mode=0x0,
Called Number=81398(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2101, Call Count On=FALSE,
000754: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000755: :cc_get_feature_vsa malloc success
000756: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000757: cc_get_feature_vsa count is 7
000758: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000759: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100952,feature_id:44
000760: //11/E5340FE78025/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
000761: //11/E5340FE78025/CCAPI/ccCallSetContext:
Context=0x8B038FDC
000762: //9/E5340FE78025/CCAPI/ccSaveDialpeerTag:
000763: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000764: feature call forward featname is 1
000765: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000766: feature_vsa is 8B010950,featname is 0
LSL02-UC-01#
000767: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000768: :cc_get_feature_vsa malloc success
000769: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000770: cc_get_feature_vsa count is 8
000771: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
000772: :FEATURE_VSA attributes are: feature_name:0,feature_time:2332100504,feature_id:45
000773: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000774: : Generating new featurevsa,inserting it
000775: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
000776: feature call forward featname is 1
000777: //11/E5340FE78025/CCAPI/cc_api_call_proceeding:
Interface=0x872D2EB4, Progress Indication=NULL(0)
000778: //11/E5340FE78025/CCAPI/cc_api_set_delay_xport:
CallInfo(delay xport=TRUE)
000779: //11/E5340FE78025/CCAPI/cc_api_call_alert:
Interface=0x872D2EB4, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
000780: //11/E5340FE78025/CCAPI/cc_api_call_alert:
000781: //9/E5340FE78025/CCAPI/ccCallAlert:
000782: //9/E5340FE78025/CCAPI/ccCallAlert:
000783: //9/E5340FE78025/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=FALSE, Tone=Ring Back,
000784: //11/E5340FE78025/CCAPI/cc_api_call_notify:
Data Bitmask=0x7, Interface=0x872D2EB4, Call Id=11
000785: //11/E5340FE78025/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
CallInfo(ssCTreRoutingNotSupported=FALSE)
000786: //9/E5340FE78025/CCAPI/ccCallNotify:
Data Bitmask=0x7, Call Id=9
000787: //11/E5340FE78025/CCAPI/ccIsInfoRingback:
Returning dpRingBack=0
000788: //11/E5340FE78025/CCAPI/ccIsInfoRingback:
000789: //11/E5340FE78025/CCAPI/cc_api_call_connected:
Interface=0x872D2EB4, Data Bitmask=0x1, Progress Indication=NULL(0),
Connection Handle=0
000790: //11/E5340FE78025/CCAPI/cc_api_call_connected:
Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
000791: //11/E5340FE78025/CCAPI/cc_api_call_notify:
000792: //9/E5340FE78025/CCAPI/ccGenerateToneInfo:
000793: //9/E5340FE78025/CCAPI/ccConferenceCreate:
(confID=0x8B1273E0, callID1=0x9, gcid=E5340FE7-A9D911E3-8025D4AA-1B98B2FC, tag=0x0)
000794: //11/E5340FE78025/CCAPI/ccConferenceCreate:
(confID=0x8B1273E0, callID2=0xB, gcid=E5340FE7-A9D911E3-8025D4AA-1B98B2FC, tag=0x0)
000795: //9/E5340FE78025/CCAPI/ccConferenceCreate:
Conference Id=0x8B1273E0, Call Id1=9, Call Id2=11, Tag=0x0
000796: //9/E5340FE78025/CCAPI/cc_api_bridge_done:
Conference Id=0x4, Source Interface=0x884D9660, Source Call Id=9,
Destination Call Id=11, Disposition=0x0, Tag=0xFFFFFFFF
000797: //11/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
000798: cc_api_get_xcode_stream : 4702
000799: //11/E5340FE78025/CCAPI/cc_api_bridge_done:
Conference Id=0x4, Source Interface=0x872D2EB4, Source Call Id=11,
Destination Call Id=9, Disposition=0x0, Tag=0x0
000800: //9/E5340FE78025/CCAPI/cc_generic_bridge_done:
000801: //9/E5340FE78025/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x4, Destination Call Id=11)
000802: //11/E5340FE78025/CCAPI/ccConferenceCreate:
Call Entry(Conference Id=0x4, Destination Call Id=9)
000803: //9/E5340FE78025/CCAPI/cc_api_caps_ind:
Destination Interface=0x872D2EB4, Destination Call Id=11, Source Call Id=9,
Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
Modem=0x2, Codec Bytes=20, Signal Type=3)
000804: //9/E5340FE78025/CCAPI/cc_api_caps_ind:
Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
Playout Max=1000(ms), Fax Nom=300(ms))
000805: //11/E5340FE78025/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
000806: //9/E5340FE78025/CCAPI/ccCallNotify:
000807: //9/E5340FE78025/CCAPI/cc_process_notify_bridge_done:
Conference Id=0x4, Call Id1=9, Call Id2=11
000808: //11/E5340FE78025/CCAPI/cc_api_caps_ind:
Destination Interface=0x884D9660, Destination Call Id=9, Source Call Id=11,
Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
Modem=0x0, Codec Bytes=160, Signal Type=2)
000809: //11/E5340FE78025/CCAPI/cc_api_caps_ind:
000810: //11/E5340FE78025/CCAPI/cc_api_caps_ack:
Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1666)
000811: //9/E5340FE78025/CCAPI/cc_api_caps_ack:
LSL02-UC-01#
000812: //9/E5340FE78025/CCAPI/ccCallConnect:
Progress Indication=NULL(0), Data Bitmask=0x1
000813: //9/E5340FE78025/CCAPI/ccCallConnect:
Call Entry(Connected=TRUE, Responsed=TRUE)
000814: //9/E5340FE78025/CCAPI/cc_api_voice_mode_event:
Call Id=9
000815: //9/E5340FE78025/CCAPI/cc_api_voice_mode_event:
Call Entry(Context=0x8B03665C)
LSL02-UC-01#
000816: //9/E5340FE78025/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x884D9660, Call Id=9
000817: //9/E5340FE78025/CCAPI/cc_api_call_disconnected:
Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
000818: //9/E5340FE78025/CCAPI/ccConferenceDestroy:
Conference Id=0x4, Tag=0x0
000819: //9/E5340FE78025/CCAPI/cc_api_bridge_drop_done:
Destination Call Id=11, Disposition=0x0, Tag=0x0
000820: //11/E5340FE78025/CCAPI/cc_api_bridge_drop_done:
000821: //9/E5340FE78025/CCAPI/cc_generic_bridge_done:
000822: //9/E5340FE78025/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
000823: //9/E5340FE78025/CCAPI/ccCallDisconnect:
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
000824: //9/E5340FE78025/CCAPI/cc_api_get_transfer_info:
000825: //11/E5340FE78025/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
000826: //11/E5340FE78025/CCAPI/ccCallDisconnect:
000827: //11/E5340FE78025/CCAPI/cc_api_get_transfer_info:
000828: //11/E5340FE78025/CCAPI/cc_api_get_transfer_info:
000829: //11/E5340FE78025/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x872D2EB4, Tag=0x0, Call Id=11,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
000830: //11/E5340FE78025/CCAPI/cc_api_call_disconnect_done:
000831: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
000832: :cc_free_feature_vsa freeing 8B010790
03-13-2014 08:35 AM
Hello Nathan,
The configuration of the hunt group is not correct.
You cannot use call forward all under extension in hunt group because it is ignored this is the reason why the call flow is not working.
This is one of the restrictions of the hunt groups, please check the following link.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmecover.html#wp1117433
You need to set the call flow in another way.
HTH,
Alex
*Please rate helpful posts
03-13-2014 12:11 PM
Okay, thanks for that input! So that fixes the local extension of 306 in the hunt group, but how can I get the hunt group to send the call to the second site? I am using call forward all because the hunt group won't let me use 81216 as a list member. I reference a folating extenstion (? not sure if this is correct term) that is 216 and that extension forwards to 81216 to go across the tunnel.
Thanks!
03-16-2014 10:00 PM
Hello Nathan,
There are different approaches e.g. you may choose final to send the call to the other site and then back to the first site voicemail. Just be careful so that you do not create a loop.
HTH,
Alex
