UC540 Phones not pulling down DNs
Scott Hanson
Level 3
Level 3
Hello all,
I have a UC540 where the phones are registering but not pulling doown the config it seems.  They are showing the UC as the TFTP server.  ANy idea where to start?
All replies rated!
Hello Scott,
First check if there are ephones confiured with the proper mac address and buttons on them.
If they are in place restart the UC.
HTH,
Alex
David Trad
Hi Scott,
Further to what Alex has requested, can you please provide us a "debug tftp event"?
I would love to see where it is failing to see if we can resolve this quickly.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) **
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Thanks guys.  It got heated here so I ended up wiping the config and doing it from scratch using CCA.  Problem solved.
