返信
UC540 power-off?
JOHN THIEN
There doesn't seem to be a shutdown feature in CCA, just a restart.
If I want to power the unit down to (for example) relocate it, am I supposed to just pull the power plug?
Also, I have noticed that when I do pull the power plug, and then subsequently use CCA, I get a message about voicemail possibly not working, and that I need to run the troubleshooter (which I do).  Is this to be expected?
Anything anyone can say about power on the UC540 is welcome to type.
1件の返信1
danplacek
Level 4
Level 4
There is no "shutdown" option in IOS... just pull the plug.
However, it doesn't hurt to do a shutdown of CUE before pulling the power, as CUE uses databases that could become corrupted from power loss. (not sure if this can be done from CCA?)
If you launch CCA immediately after booting and get that message it may be expected as CUE is still booting (it takes much longer than IOS).
In my experience, power loss on a UC500 rarely causes problems.
-Dan
Please rate useful posts.
