UC540 SIP-TRUNK with T-Com Provider ???
m.stefani
Hi All,
I am looking for an answer to the followwing question:
Is it possible to connect a UC 540 via SIP-Trunking to the T-Com provider?
Many Thnaks in advance
Michael
10 Replies 10
danplacek
Level 4
Level 4
Yes, we do many deployments with SIP delivered over a T1 by the ISP.
We have worked with Earthlink, TDS, and CBeyond successfully.
SIP to ITSPs works as well -- but SIP over the public internet is an invitation for problems.
I'm usind sip trunk with sipgate over thr public internet without any problems.
The uc need some special configuration for the authentication, but that is all.
Best regards
Christian
- Please rate helpful posts -
Hi Christian,
I am also working on getting a SIP Trunk to SIPGate working in my Lab.
Would you mind to share your settings?
What special configuration is needed for authentication?
I am struggling at the moment with Natting. My router has no direct connection to the internet. Its behind a NAT Router and my SIP register requests to sipgate has only my internal ip address in the via or contact header.
Is there a way to replace my internal ip with my external ip or should this happen automaticly when my request reaches sipconnect.sipgate.de ?
regards,
Bernhard
Hi Bernahrd,
you need the CUBE functionality to modify the SIP header of your packets. There you can replace the ip. Can you please post a sample header of your outgoing sip packet.
regards
Christian
Hi Christian,
Thanks for your reply.
Indeed my outgoing SIP Packet has internal IP addresses.
I will check for the CUBE functionality to modify the SIP Header. thank you!
What special authentication is needed?
I've got following sip-ua config:
sip-ua
credentials username XXXXXXt0 password 7 xxxxxxxx realm sipconnect.sipgate.de
authentication username XXXXXXt0 password 7 xxxxxxxxx realm sipconnect.sipgate.de
no remote-party-id
retry invite 5
retry register 10
timers connect 100
registrar dns:sipconnect.sipgate.de:5060 expires 3600
sip-server dns:sipconnect.sipgate.de:5060
best regards,
Bernhard
Hi Bernhard,
is it now possible to add characters in the username? The last time I configured SIP it wasn't possible.
I will check later my documents.
regards
Christian
Hi Christian,
I am using a 2921 router with 15.2(4)M3 IOS and it is possible to add characters. Unfortunately registering is still not working.
I got now CUBE Header replace in place and i see in my sip messages the following:
Sent:
REGISTER sip:sipconnect.sipgate.de:5060 SIP/2.0
Via: SIP/2.0/UDP :5060;branch=z9hG4bK18ED
From: <>xxxxxxxxt0@sipconnect.sipgate.de>;tag=ADED78-1E6
To: <>xxxxxxxxt0@sipconnect.sipgate.de>
Date: Wed, 10 Apr 2013 13:47:56 GMT
Call-ID: 84DDCD30-A11B11E2-800296FE-57E3AE87
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M3
Max-Forwards: 70
Timestamp: 1365601676
CSeq: 3 REGISTER
Contact: :5060>
Expires:  3600
Supported: path
Content-Length: 0
on my NAT Router i got a port forwarding to my internal address for udp 5060.
I used following config for replacement:
voice class sip-profiles 1
request REGISTER sip-header Contact modify "internal ip" "external ip"
request REGISTER sip-header Via modify "internal ip" "external ip"
and have the sip profile applied to voice service voip.
Of course you have to replace "internal ip" and "external ip" with the correct ip addresses.
but i see only outbound SIP requests nothing comes inbound...
anything else i need to modify?
regards,
Bernhard
Hi Bernhard,
can you check if your WAN router is receiving the SIP answer?
I found some infos that you need to configure:
no ip nat service sip udp port 5060
But I've never tried this.
Hi Bernhard,
I tested this in my lab on the weekend. I used a CME behind a ASA to connect to sipgate and there was no configuration needed in the CME to modify the SIP headers for this scenario.
So I think your problem is somewhere in the WAN router.
best regards
Christian
I know this post is quite old but I was wondering if you would be able to provide a basic config for this? I am having trouble registering my UC540 with sipgate.
Richard
