UC540 Unknown caller id
Mohd SaberUddin
Hi All,
i am facing strange problem, only one time caller id appears and  next time it always shows UNKNOWN Number ??
I try with a normal phone and the telco is  sending the caller information.
i am using UC540:
"flash:uc500-advipservicesk9-mz.151-4.M5"
voice-port 0/1/0
supervisory disconnect dualtone mid-call
cptone BE
timeouts interdigit 2
timeouts call-disconnect 3
timeouts ringing 20
timeouts wait-release 3
connection plar opx 123
impedance complex2
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
000636: Jul 22 13:26:24.415: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
000637: Jul 22 13:26:24.415: htsp_timer - 125 msec
000638: Jul 22 13:26:24.543: htsp_process_event: [0/1/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
000639: Jul 22 13:26:24.543: htsp_timer - 10000 msec
000640: Jul 22 13:26:25.543: htsp_process_event: [0/1/0, FXOLS_RINGING, E_DSP_SIG_0100]
000641: Jul 22 13:26:25.543: fxols_ringing_not
000642: Jul 22 13:26:25.543: htsp_timer_stop
000643: Jul 22 13:26:25.543: htsp_timer_stop3
000644: Jul 22 13:26:25.543: [0/1/0] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
000645: Jul 22 13:26:25.543: [0/1/0] get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
000646: Jul 22 13:26:25.543: [0/1/0] get_local_station_id calling num= calling name= calling time=07/22 16:26  orig called=
000647: Jul 22 13:26:25.547: [0/1/0] htsp_dsm_close_done
000648: Jul 22 13:26:25.547: htsp_process_event: [0/1/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
000649: Jul 22 13:26:25.547: fxols_wait_setup_ack:
000650: Jul 22 13:26:25.547: htsp_timer - 6000 msec
000651: Jul 22 13:26:25.555: htsp_timer_stop3
000652: Jul 22 13:26:25.555: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_prochtsp_setup_req
000653: Jul 22 13:26:25.559: htsp_process_event: [50/0/123.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
000654: Jul 22 13:26:25.559: htsp_ephone_start_caller_id_tx calling num= calling name = called num=123 orig called num=
000655: Jul 22 13:26:25.559: [50/0/123.1] set signal state = 0x0 timestamp = 0
000656: Jul 22 13:26:25.559: efxs_onhook_setup: local target is available
htsp_alerthtsp_alert_notify
000657: Jul 22 13:26:25.567: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
000658: Jul 22 13:26:29.435: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000659: Jul 22 13:26:29.435: htsp_timer_stop
000660: Jul 22 13:26:30.543: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000661: Jul 22 13:26:30.543: htsp_timer_stop2
000662: Jul 22 13:26:30.543: htsp_timer - 6000 msec
000663: Jul 22 13:26:34.435: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000664: Jul 22 13:26:34.435: htsp_timer_stop
000665: Jul 22 13:26:35.543: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000666: Jul 22 13:26:35.543: htsp_timer_stop2
000667: Jul 22 13:26:35.543: htsp_timer - 6000 msec
000668: Jul 22 13:26:39.435: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000669: Jul 22 13:26:39.435: htsp_timer_stop
000670: Jul 22 13:26:40.543: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000671: Jul 22 13:26:40.543: htsp_timer_stop2
000672: Jul 22 13:26:40.543: htsp_timer - 6000 msec
000673: Jul 22 13:26:45.567: htsp_timer_stop3
000674: Jul 22 13:26:45.571: htsp_process_event: [50/0/123.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
000675: Jul 22 13:26:45.571: [50/0/123.1] set signal state = 0x4 timestamp = 0
000676: Jul 22 13:26:45.683: htsp_call_bridged invoked
000677: Jul 22 13:26:45.687: htsp_process_event: [0/1/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
000678: Jul 22 13:26:45.687: [0/1/0] set signal state = 0xC timestamp = 0
000679: Jul 22 13:26:45.687: htsp_timer_stop
000680: Jul 22 13:26:45.691: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
000681: Jul 22 13:27:17.955: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_DSP_SUP_DISCONNECT]fxols_conn_sup_disc
000682: Jul 22 13:27:17.955: htsp_timer2 - 3000 msec
000683: Jul 22 13:27:20.955: htsp_process_event: [0/1/0, FXOLS_CONNECT, E_HTSP_EVENT_TIMER2]fxols_disc_confirm
000684: Jul 22 13:27:20.955: htsp_timer_stop
000685: Jul 22 13:27:20.955: htsp_timer_stop2
000686: Jul 22 13:27:20.955: htsp_timer_stop3
000687: Jul 22 13:27:20.955: htsp_timer_stop3
000688: Jul 22 13:27:20.987: htsp_process_event: [0/1/0, FXOLS_REMOTE_RELEASE, E_HTSP_RELEASE_REQ]fxols_offhook_release
000689: Jul 22 13:27:20.987: htsp_timer_stop
000690: Jul 22 13:27:20.987: htsp_timer_stop2
000691: Jul 22 13:27:20.987: htsp_timer_stop3
000692: Jul 22 13:27:20.987: [0/1/0] set signal state = 0x4 timestamp = 0
000693: Jul 22 13:27:20.987: htsp_timer - 2000 msec
000694: Jul 22 13:27:21.775: htsp_timer_stop3 htsp_setup_req
000695: Jul 22 13:27:21.775: htsp_process_event: [50/0/300.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
000696: Jul 22 13:27:21.775: htsp_ephone_start_caller_id_tx calling num=297 calling name = called num=A800123 orig called num=
000697: Jul 22 13:27:21.779: [50/0/300.1] set signal state = 0x0 timestamp = 0
000698: Jul 22 13:27:21.779: efxs_onhook_setup: local target is available
htsp_alerthtsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 0
000699: Jul 22 13:27:21.787: htsp_process_event: [50/0/300.1, EFXS_WAIT_OFFHOOK, E_HTSP_CALLERID_WAITING]
000700: Jul 22 13:27:21.787: efxs_callerid_update
000701: Jul 22 13:27:21.787: efxs_callerid_update process caller_id_string
000702: Jul 22 13:27:21.787: efxs_callerid_update process caller_id_string OK
000703: Jul 22 13:27:21.787: efxs_callerid_update number= [297] name= []
000704: Jul 22 13:27:22.987: htsp_process_event: [0/1/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
000705: Jul 22 13:27:22.987: fxols_dsp_prealloc_clid_wait. Line reversal alerting DSP preallocation done
000706: Jul 22 13:27:22.987: [0/1/0] htsp_start_caller_id_rx:ETSI_DTMF
000707: Jul 22 13:27:22.987: htsp_start_caller_id_rx create dsp_stream_manager
000708: Jul 22 13:27:22.987: htsp_process_event: [0/1/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
000709: Jul 22 13:27:22.987: [0/1/0] htsp_dsm_create_success  returns 1
000710: Jul 22 13:27:26.767: htsp_timer_stop3
000711: Jul 22 13:27:26.771: htsp_process_event: [50/0/300.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
000712: Jul 22 13:27:26.771: [50/0/300.1] set signal state = 0x4 timestamp = 0
0 Replies 0
