UC540W Default Config does not load any IP Addresses
Apex889
I recently acquired a decommissioned UC540W from one of our partner companies. We have loaded the default configuration to the unit, however the configuration does not assign any addresses. Even loading the backup configuration, no ip addresses are assigned anywhere in the unit. Are we perhaps missing something on the default config where no addresses are being populated? We would like to get the unit to a point where we can configure it in CCA, however I know with these units a reset also needs to be done on the CUE service module - however if this has no IP starting a session with it is rather impossible to preform the reset.
Show Run below...
Router#show run
Building configuration...
Current configuration : 1681 bytes
version 15.1
no service pad
hostname Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid UC540W-FXO-K9 sn FGL1512205S
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Integrated-Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Dot11Radio0/5/0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control
description Music On Hold Port
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
login
transport input all
end
jms
Were you able to resolve your issue? If so can you share what you did
