06-10-2013 08:44 AM - edited 03-21-2019 07:26 AM
Hello sir, how are you?
I'm looking for dial plan based on minutes to use:
Follow a example:
I have 3000 mins over E1, 200 min over FXO and unlimited over VoIP.
So, I wanna use my minutes of the E1 and FXO, but Im scared to use more than I have.
Have a way to config my UC500 to use 2800 min on E1, 180 min on fxo and after use all minutes pre configured use my voip line?
Sorry if I worng on english.
Thanks for help
Solved! Go to Solution.
06-10-2013 09:09 AM
That could be done only by manually tracking dial-peer usage, or possibly a complex EEM script.
06-10-2013 09:09 AM
06-10-2013 09:18 AM
Hello Paolo, thanks for help!
Did you have a demo of this script or a manual to manually tracking dial peer?
Based on your experience, its hard?
thanks so much!
06-10-2013 10:23 AM
I do not have any demo. Hard or easy, you can judge after trying.
