UC560 redial issue
daniel.ryder
Hi. I've just implemented a new UC560 install for the company I work for. Over all its gone well but we seem to have an issue with redailing numbers from the "Call History" menu.
Basically the calls are saved in the list without the "9" prefix, so when we try to redial the call fails. I think I could simply change the "Access Code" to "0" but unfortunatly we Prefix all outgoing calls with "141" which also appears on the phone.
Has anybody experienced this in the past?
I'm not sure if its relevent but we are based in the UK and conenct to the PSTN using a 10 channel E1
Cheers
Steven DiStefano
This is default behavior and what the edit/dial button which appears on the phone is used for.  In the cisco campus on Communications Manager it is the same.
Posted from my mobile device.
Thanks Steve
So we have to edit each number and add a 9? Seems to be a poor way of doing things, is there no way of adding the 9 automatically?
I just spoke to support, and there is currently not a way to do this through the CCA 2.0.  You have to add a dial tranlsation rule through CLI.
