UC560- T1/E1 no caen las llamadas entrantes
danielriera
Buenas,
   Tengo un Uc560 con una tarjeta E1 con 10 lineas, puedo realizar llamadas por esos numeros, pero a la hora de recibir llamadas estas se caen, que configuracion del dial-peer tengo que realizar por medio de CLI para las llamadas entrantes?
  agredeceria mucho su ayuda
5 Replies 5
paolo bevilacqua
You need to add full details for the problem to be understoon and solved.
Necesito la configuracion exacta para las llamadas entrantes del E1, ya he configurado reglas y profile pero las llamadas entrantes no logran redireccionarse. aca dejo parte de la config que tengo
trunk group ALL_E1T1
hunt-scheme sequential
translation-profile incoming E1_Entrantes
translation-profile outgoing PROFILE_ALL_E1T1
trunk group All_E1T1_entrantes
controller E1 0/2/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country venezuela
  category 2
  answer-signal group-a 6
  dnis-digits min 1 max 10
  ani-digits min 1 max 10
  groupa-callerid-end
  trunk-group ALL_E1T1 64
description Troncales Digitales
process-max-time 50
dial-peer voice 3000 pots
incoming called-number 2414524100
direct-inward-dial
port 0/2/0:0
Just to begin with, configure translation profile under voice-port, not dial-peer.
voice call send-alert
voice rtp send-recv
voice service pots
translation-profile incoming controller E1 0/2/0 E1_Entrantes
voice translation-rule 4
rule 15 /^....$/ /02414524100/
voice translation-rule 10
rule 1 /2414524100/ /1098/
voice translation-rule 13
rule 1 /4100/ /1098/
voice translation-rule 14
rule 1 /4101/ /1601/
voice translation-rule 15
voice translation-rule 16
voice translation-profile E1_Entrantes
translate redirect-called 3000
There is no rule for called number under profile.
And there is to see what telco is actually sending.
