UC560 Unity Express: Retrieving deleted messages
spalatucci
Is there a way to set CUE to keep deleted messages in the Deleted Messages folder for a specified period of time after you hang up?
With default settings, once you delete a message and end the call it gets deleted from that folder.
Hello Samuel,
I am not aware of such option unless undelete in the same session but when you finish the session you cannot undelete. You may try the integrated messaging (IMAP) of the CUE you may save the files on the PC.
More info on the following link:
https://supportforums.cisco.com/docs/DOC-9688
HTH,
Alex
*Please rate helpful posts
