Unable to access BE3000 after wizard
david.sua
Level 4
Level 4
                   Hi all,
I have configured a BE3000 using Wizard with manual setup and after restart I'm not able to access https://192.168.1.250 or https://192.168.1.250/cucmadmin/
Any help?
Thanks in advance.
Andrew Hickman
Hi David,
If you can, connect a monitor to the display port on the BE3000 and it should display the management IP address there.
If not, use the "configure.xml" template from BE3000-utils_8_6_4.zip download to set a new IP address, store the file to a USB and connect to the BE3000.  This will add a temporary management address for you to access the system with.
Hope that helps,
Andy
Andrew Hickman
Hi David,
Hope that helps,
Andy
Thank you Andrew but the issue solve by itself.
Before post I try with a monitor to wait the full power on process but the need more time, I don't know why. I could see the message that indicate that BE is power on and I can ping the IP address. After wait for 10 or 15 minutes I try again and them I can access!
