01-22-2011 05:25 PM - edited 03-21-2019 03:33 AM
All,
After configuring skype for sip, I am nolonger able to dial to the CUE. I looked for a while through searches and i've seen the question asked but never found a working answer.
Thanks for your help.
-John
Solved! Go to Solution.
01-23-2011 11:46 AM
Hi John,
Try the following
Conf t
Sip
No sip-profiles 1000
I have seen the sip-profile command break the link between CME and CUE.
-Mario
01-23-2011 01:09 AM
John,
Can you post your configuration?
-Mario
01-23-2011 11:35 AM
BC_VOIP_01#sh run
Building configuration...
Current configuration : 37308 bytes
! Last configuration change at 21:11:29 EST Sat Jan 22 2011 by administrator
version 12.4
parser config cache interface
no service pad
no service timestamps debug uptime
service internal
service compress-config
service sequence-numbers
hostname BC_VOIP_01
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-20.T2(2).bin
boot-end-marker
logging message-counter syslog
no logging buffered
no logging rate-limit
enable secret 5 $1$hcEO$dg2IewFQdqWycHDccuz8a/
aaa new-model
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-2006719407
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2006719407
revocation-check none
rsakeypair TP-self-signed-2006719407
crypto pki certificate chain TP-self-signed-2006719407
certificate self-signed 01
dot11 syslog
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.10.241 192.168.10.255
ip dhcp excluded-address 192.168.5.241 192.168.5.255
ip dhcp excluded-address 192.168.5.1 192.168.5.9
ip dhcp pool phone
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
option 150 ip 192.168.5.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.0.3
ip domain name bcnet.com
ip name-server 192.168.0.3
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
registrar server expires max 3600 min 3600
localhost dns:bcnet.com
no update-callerid
sip-profiles 1000
voice class codec 1
codec preference 1 g729r8
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
voice register global
max-dn 56
max-pool 14
voice hunt-group 1 parallel
final 199
list 102,103,101
timeout 16
pilot 111
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 1
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 2
voice translation-rule 4
rule 1 /16179399004/ /111/
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^...$/ /99051000127350/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile DID-SIP-BG_Called_4
translate called 4
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
username administrator privilege 15 secret 5 *******
archive
log config
logging enable
logging size 600
hidekeys
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip virtual-reassembly
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
shutdown
ssid cisco-data
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
interface BVI100
ip address 192.168.5.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
access-list 1 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 192.168.10.1
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 63.209.144.201
access-list 2 deny any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-4.bin alias spa525g-7-4-4.bin
tftp-server flash:/phones/5x5/spa5x5-7-4-4.bin alias spa5x5-7-4-4.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6. sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6. sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.load s
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.lo ads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.lo ads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.3.4SR1.SBN alias APPS-1.3.4SR1.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.4SR1.LOADS alias CP7921G-1.3.4SR1.LOA DS
tftp-server flash:/phones/7921/GUI-1.3.4SR1.SBN alias GUI-1.3.4SR1.SBN
tftp-server flash:/phones/7921/MISC-1.3.4SR1.SBN alias MISC-1.3.4SR1.SBN
tftp-server flash:/phones/7921/SYS-1.3.4SR1.SBN alias SYS-1.3.4SR1.SBN
tftp-server flash:/phones/7921/TNUX-1.3.4SR1.SBN alias TNUX-1.3.4SR1.SBN
tftp-server flash:/phones/7921/WLAN-1.3.4SR1.SBN alias WLAN-1.3.4SR1.SBN
tftp-server flash:/phones/7925/APPSH-1.3.4SR1.SBN alias APPSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.4SR1.LOADS alias CP7925G-1.3.4SR1.LOA DS
tftp-server flash:/phones/7925/GUIH-1.3.4SR1.SBN alias GUIH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/MISCH-1.3.4SR1.SBN alias MISCH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.4SR1.SBN alias SYSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.4SR1.SBN alias TNUXH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.4SR1.SBN alias WLANH-1.3.4SR1.SBN
tftp-server flash:/phones/7931/apps31.8-5-3TH1-6.sbn alias apps31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-3TH1-6.sbn alias cnu31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-3TH1-6.sbn alias cvm31sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-3TH1-6.sbn alias dsp31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-3TH1-6.sbn alias jar31sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-3S.loads alias SCCP31.8-5-3S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-20-0.bin alias cmterm_7936.3-3-20 -0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.b in
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-3TH1-6.sbn alias cnu41.8-5-3TH1-6. sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6. sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.load s
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.lo ads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.lo ads
tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6. sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6. sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.load s
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.lo ads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.lo ads
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6. sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6. sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.load s
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.lo ads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.lo ads
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6. sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6. sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.load s
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.lo ads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.lo ads
tftp-server flash:/phones/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.x ml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsb usy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidopt ion.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_h old.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_men u.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_o perator.au
tftp-server flash:/Desktops/320x212x12/TN-BCNET.png
tftp-server flash:/Desktops/320x212x12/BCNET.png
tftp-server flash:/ringtones/CTU.raw alias CTU.raw
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
station-id number 101
caller-id enable
voice-port 0/0/1
shutdown
caller-id enable
voice-port 0/0/2
shutdown
caller-id enable
voice-port 0/0/3
shutdown
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 111
description Configured by CCA 4 FXO-0/1/0-BG
caller-id enable
voice-port 0/1/1
connection plar 202
shutdown
caller-id enable
voice-port 0/1/2
connection plar 203
shutdown
caller-id enable
voice-port 0/1/3
connection plar 204
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 192.168.5.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtp001d706e6280
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Skype for SIP
codec g711ulaw
codec g729abr8
codec g729ar8
maximum sessions 6
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name PSTN-fax
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list call-fax
member PSTN-fax
dial-peer voice 1 pots
destination-pattern 101
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description catch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 199
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Skype for SIP) **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session target sip-server
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (Skype for SIP) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1021 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
description **CCA*North American-7-digit*Service Numbers**
preference 6
destination-pattern 9[2-9]11
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
description **CCA*North American-7-digit*7-Digit Local**
preference 6
destination-pattern 9[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
corlist outgoing call-national
description **CCA*North American-7-digit*Long Distance**
preference 6
destination-pattern 91[2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3000 voip
description DID-SIP-BG
translation-profile incoming DID-SIP-BG_Called_4
voice-class codec 1
incoming called-number 16179399004
dtmf-relay rtp-nte
no vad
dial-peer voice 60 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
no dial-peer outbound status-check pots
sip-ua
credentials username 99051000127350 password 7 ******
realm sip.skype.com
authentication username 99051000127350 password 7 ******* C
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
connection-reuse
host-registrar
g729-annexb override
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 6
sdspfarm tag 2 mtp001d706e6280
video
fxo hook-flash
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.4SR1
load 7925 CP7925G-1.3.4SR1
load 7931 SCCP31.8-5-3S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-3S
load 7941GE SCCP41.8-5-3S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-3S
load 7961 SCCP41.8-5-3S
load 7961GE SCCP41.8-5-3S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-3S
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-4
max-ephones 14
max-dn 56
ip source-address 192.168.5.1 port 2000
auto assign 1 to 1 type bri
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message BCNET
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 12
keepalive 30 auxiliary 4
voicemail 199
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 ******
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Jan 19 2011 21:37:33
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 1
number 123 no-reg primary
description IP-Paging1
name AllApartment
paging ip 239.1.1.1 port 2000
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 12 dual-line
number 203 no-reg primary
label 203
description 203
name 203
ephone-dn 13 dual-line
number 204 no-reg primary
label 204
description 204
name 204
ephone-dn 14 dual-line
number 205 no-reg primary
label 205
description 205
name 205
ephone-dn 15 dual-line
number 206 no-reg primary
label 206
description 206
name 206
ephone-dn 16 dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn 17 dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn 18 dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn 19 dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn 52 octo-line
number 103 no-reg primary
label 103
description Bedroom Desk
name Bedroom Desk
call-forward busy 199
call-forward noan 199 timeout 20
ephone-dn 53 dual-line
number 102 no-reg primary
label 102
description Movie Theater
name Movie Theater
ephone-dn 54
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 199
ephone-dn 55
number A801... no-reg primary
mwi off
ephone-dn 56
number A800... no-reg primary
mwi on
ephone 5
device-security-mode none
mac-address 0016.C7AE.DF2A
ephone-template 16
username "MTheater" password 123456
paging-dn 1
type 7970
button 1:53
ephone 6
video
mac-address 0014.A892.5405
ephone-template 16
username "BDesk" password 123456
speed-dial 1 916176824665 label "NOC HOTLINE"
type 7970
button 1:52
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.0. Mon Ja n 17 19:08:01 EST 2011^^C
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
01-23-2011 11:46 AM
Hi John,
Try the following
Conf t
Sip
-Mario
01-23-2011 05:49 PM
Hi Mario,
Thanks for your help with this however seems like thats not working:
BC_VOIP_01(config-sip-ua)#no sip-profiles 1000
% Invalid input detected at '^' marker.
Should I do:
no voice class sip-profiles 1000
Thanks!
John
01-23-2011 05:50 PM
-John
