03-27-2012 01:26 AM - edited 03-21-2019 05:34 AM
Good Morning,
It appears that UC320's are being shipped with older firmware applied on them, and as a result we are having difficulty logging into them using the latest versions of IE;Firefox and Google Chrome. Although I havent tried Safari I imagine it will be the same.
The only way we can gain access is by using an older version of IE which generally means sourcing a Windows XP PC which is becoming increasingly difficult to do.
Once we have logged in with the elusive XP machine and updated the firmware there is not a problem.
My dilema is this - How do we gain access to these UC320's with the old firmware in the absence of an older version of a browser?
03-27-2012 01:42 PM
Hi Aaron,
The original shipping firmware did have a compatability issue with Flash version 11.
The firmware loaded during manufacturing has since been updated to resolve this issue in the future.
Here is a work around to the flash compatability issue.
NOTE:
If you are having problems logging in or upgrading from firmware versions below 2.1.2, you may be experiencing the
Adobe Flash Player version 11 incompatibility with pre-2.1.2 firmware
issue. Click the link for workaround.
For additional information on UC320W firmware releases please select this link:
https://supportforums.cisco.com/docs/DOC-22559
Randy
03-30-2012 11:12 AM
I ran into same issue, and Randall is correct. Make sure you get a lower version of flash. you can get it at www.filehippo.com they have multiple versions of flash there. The UC tends to have issue's with IE as well. I would use firefox for uc. So far I have flashed about 4 of them to the current version, and nary a problem save the slow internet at a couple of sites.
Good luck!
William Ramos
