Unable to login to UC320
barnesc64
Using Firefox 3.6 on Windows 7
All I get is the Cisco banner and a green line, the tab says "Cisco UC320W Firmware Upgrade"
No Login Prompt at all!
David Harper
It's not the Flash 11 problem is it?  Check
https://supportforums.cisco.com/message/3478189
for details.
Cheers,
Dave.
David Harper
for details.
Cheers,
Dave.
Thanks Dave, that was the problem. I used the online cloud upgrade method to update the device, all worked perfectly.
Cool.  Glad you are all sorted.
Cheers,
Dave.
