VoIP Unlimited Template
val.jackos
Parameter
Value
Comment
Name of ITSP
VoIP Unlimited
Enter name as you would like to see it in CCA drop down, i.e   VU Trunk or Test Trunk…
Dialplan locale
UK
National Format
Display Proxy Server (Primary) field
Yes
sip.voip-unlimited.net:5060
Display Proxy Server (Backup) field
N/A
(optional) field to enter IP address or DNS of ITSP's backup   SIP proxy server
Display Registrar Server field
Yes
Display Outbound Proxy Server field
Yes
Display Digest Authentication (Username / Password)
YES
field to enter username / password for SIP registration or   calling, this is provided by VoIP Unlimited
Display Customer Company Name field
No
(optional)  choose YES if specific caller name is   required for outbound calls, usually ITSP does this
Display Call Admission Control field
No
(optional) choose YES if ITSP requires the UC500 limit # of   SIP calls, usually ITSP does this
Display User Credentials field
No
(optional) choose YES if ITSP requires SIP registration of all   DIDs associated to the UC500 with a unique username / password per DID
ITSP SIP TRUNK PARAMETERS
Voice Codec
G711u,G711a and G729
You can choose any one of the 3 codecs shown
Fax protocol
T.38
We support T.38
RFC2833 (DTMF) payload type
101
Default value is 101, if change is required, then enter value   in range from 97 to 121
Should UC500 register all DIDs to ITSP
No
Register only the main number
Is SIP registration for DID(s) using same username / password or   unique username / password per DID
N/A
lgaughan
Valentina,
One follow-up question before generating the template.  Which voice codec is preferred?  G711alaw, as for UC320?  For UC500, we recommend configuring a single voice codec to avoid any renegotiation of codecs on different call legs that may be hairpinned.
Thank you.
Laura
Hi Laura,
We support all 3 codecs. We normally recommend G711alaw or G711ulaw as G729 its a compressed codec. When we did the testing the first codec that has been negotiated was G711alaw, so I will probbly ask you to stick with that.
Thanks.
Hi Valentina,
Attached please find the template for VoIP Unlimited based on your inputs.  This template is ready for Add/Import into CCA.   Please refer to this document for some more information and tips on SIP trunks on the UC500:
https://supportforums.cisco.com/docs/DOC-9830
Let us know whether you need any further assistance.
Laura
