Help recovering 7970 & 7975
mross1572
I have 2 phones that are both doing the same thing.
after resetting them the are stuck in a continuous reboot and sitting at the cisco screen with a target symbol at the bottom left.
Any ideas what i should try?
the loads are in my UC520 system, and we have other 7970's & 7975's working fine.
here are the loads in my UC;
25 0 Dec 17 2011 15:31:46 phones/7970_7971
26 2933341 Dec 17 2011 15:34:38 phones/7970_7971/apps70.8-5-4TH1-6.sbn
27 500233 Dec 17 2011 15:34:42 phones/7970_7971/cnu70.8-5-4TH1-6.sbn
28 2105286 Dec 17 2011 15:34:58 phones/7970_7971/cvm70sccp.8-5-4TH1-6.sbn
29 539513 Dec 17 2011 15:35:04 phones/7970_7971/dsp70.8-5-4TH1-6.sbn
30 1828427 Dec 17 2011 15:35:16 phones/7970_7971/jar70sccp.8-5-4TH1-6.sbn
31 650 Dec 17 2011 15:35:18 phones/7970_7971/SCCP70.8-5-4S.loads
32 654 Dec 17 2011 15:35:18 phones/7970_7971/term70.default.loads
33 654 Dec 17 2011 15:35:18 phones/7970_7971/term71.default.loads
34 0 Dec 17 2011 15:31:46 phones/7975
35 2936005 Dec 17 2011 15:35:38 phones/7975/apps75.8-5-4TH1-6.sbn
36 525004 Dec 17 2011 15:35:42 phones/7975/cnu75.8-5-4TH1-6.sbn
37 2103364 Dec 17 2011 15:35:58 phones/7975/cvm75sccp.8-5-4TH1-6.sbn
38 342219 Dec 17 2011 15:36:02 phones/7975/dsp75.8-5-4TH1-6.sbn
39 1887312 Dec 17 2011 15:36:16 phones/7975/jar75sccp.8-5-4TH1-6.sbn
40 650 Dec 17 2011 15:36:18 phones/7975/SCCP75.8-5-4S.loads
41 654 Dec 17 2011 15:36:20 phones/7975/term75.default.loads
my UC520 ver is as follows;
Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T4, RELEASE SOFTWARE (fc1)
Also attached is a copy of the UC520's configuration.
Thanks for any help in advance.
mcasimirc63
Level 4
Level 4
I would make sure you have the following things out of the way.
  1. If you are using a SF or SG 200 or 300 switch, reboot it.
  2. Make sure the switchport is set to voice vlan 100 (or whatever voice vlan you are using)
  3. If you are using another switch make sure the trunk port is allowing vlan 100 to pass
  4. Make sure that the phone on vlan 100 can reach the ip source address (default 10.1.1.1)
  5. Check the DHCP pool and make sure option 150 is set, network subnet is 10.1.1.x and default router is set to your IP source address
  6. During the boot up process, check the settings and make sure the phone gets a DHCP address that starts with 10.x.x.x
  7. If you are using another switch make sure the trunk port is allowing vlan 100 to pass
  8. Make sure that the correct phone load set for the firmware version you have http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/UC7.0.1/release_notes/rnipt701.html#wp1426841
  9. Make sure that your tftp statements point to all the 797X firmware files on flash.
  10. Then you should hard reset the phone. Shown in the youtube clip.
http://www.youtube.com/watch?v=-18PvQ216e8
If you configured your 520 with CCA, you wont necessarily need to worry about steps 4,5, 8, 9
David Trad
Hi there...
Cool you got the logo of death and also the loop of death both at the same time... your as bad as me
Ok two things you need to do:
  • Factory reset the phone using the 7900 series sequence
  • Plug it directly into the UC not into switch... Unless it is a UC-560, in which case further instructions will be required
The 7970 - 7975 phones can become stale after an upgrade or become lazy and stop provisioning correctly, or if you are doing a firmware upgrade that is too big of a step you may need to go through a two or even three stage upgrade process, big upgrades will also place the phone in the loop of death
Give the above a go and let us know how get on.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
mross1572
