Where dial plan sets?
Efim Kuznetsov
Why you isn't provide tools or feature set in firmware for customize dial plan???
It must be troubles of your customers?
Nima Norbu
Hi Efim,
By default UC320 supports dial plan based on the country region you select.These dial plan are non-editable
Example:Go to configuration-->Region-->select the country from dropdown list.
then select the dial plan digits and timezone.
Feature not available for customize dial plan.The only way to control what goes through which trunk is through steering digits.
Nima
Many thanks, Cap
