07-26-2011 06:00 PM - last edited on 03-25-2019 10:58 PM by ciscomoderator
Hi Cisco Team,
Would like to bring to the attention of the Cisco Dev's the following issues that are somewhat disturbing and worrying, they have been noticed in particular of the last two larger deployments using UC-560 systems, they are continual and require some further investigating.
Some of these issues may seem like nothing, but I do believe they have a larger implication to the system functioning correctly. Please be aware this will be quite long as it has been an ongoing investigation for a little over 2 months now, SBCS has not been involved as of yet with all the issues only on the most pressing ones (Complicated story as to why).
System Outline:
First Issue:
Second Issue:
Third Issue:
Fourth Issue:
Fith Issue:
There are a host of other issue including that of CDR records, SCC, simple system management, but right now I am emotionally and mentally drained, plus my hands are getting really sore from typing non-stop since I come into work putting out fires, I cannot remember ever being so exhausted working with Cisco System, yeah sure they gave you problems but they were easily fixed with a simple call to TAC, Now when I call SBCS I get people on the phone either cannot speak fluent English or understand me, ask me to do stupid things which are of no relevance to the issue at hand, or cannot merry up the support contract on a device to the UC system because of what ever arrangement is in place between our national carrier and Cisco, the headache is so huge what ever margins are made on selling the things is gobbled up just in managing the clients issues and trying to work through the lack of SBCS support (Not taking shots at the guys because they are only doing their jobs, simple, and I have no animosity towards them what-so-ever).
I could understand and appreciate if this issue was happening on a single system, but when the issues start to surface on more then one system, and many hours are spend looking at if the problem falls squarely with what I am doing, I am left with limited options, I have even tried to side-step SBCS all together by trying to wean some basic support from Dave Harper when I clearly know I shouldn't because desperation sets in to just clear this problem out, which again yields its own problems, because I am now making someone else accountable for the issue when it clearly is not in their domain
HELP!!!
Please take this rant with all seriousness, I am not asking for an army of support but just someone who is in the know to look at the problems, on all fronts I.E CCA/OM/UC-500 as each one will require their own set of expertise. I have worked on UC's and Deployed enough of them in the last 3 years to have hit every issue, but the most recent ones just linger around like a bad smell.
Cheers,
David.
07-27-2011 11:29 PM
Geee I hope my post didn't scare the Cisco Team off
The silence is defining
Regardless I am trying to work out a way to get Support involved, although it is not simple to do as replicating the problem would be extremely disruptive to both sites as the phones are constantly ringing off-hook (Yes this problem had to happen in busy sites).
But if the Cisco Team or even the community has any suggestions, it would be great to get some feed-back.
Cheers,
David.
07-28-2011 07:50 AM
This isn't really a helpful answer, but I thought I'd add our experiences.
We have seen similar problems with both CCA and Office Manager, I have very little confidence in either of them. We try to avoid giving customers either of them if at all possible - not because we wouldn't want them to be able to make changes -- but out of fear of what might break.
One of the biggest problems I have is that so many of these issues are difficult to reproduce, and Cisco seems to be of the opinion that if it isn't easily reproducible -- it doesn't exist. STAC's only course of action for things that are *clearly* bugs seems to be to blindly change firmware versions until it works -or- just stop responding and close the case.
We've had a great deal more issues than the ones you've listed here even (phones rebooting randomly, un-deletable voicemail messages, paging not going to some phones, phones freezing, screeching noises on incoming calls). Cisco seems to be unable to help with anything thats clearly in the "bug" category and not a configuration problem.
A side note here -- its been my experience that any configuration thats even semi-complex -- there is CLI changes required. Which inevitably makes things with cca and om even worse. Cisco's inability to make management software that is compatible with their own configuration "language" is insane to me.
I could go on about this at length like you have above, but I doubt anything will come of this thread anyway. Its both comforting and depressing that I am not alone with these problems...
07-29-2011 11:54 AM
David,
We have done many installations of the UC-series and recently made the decision to move onto 2900 series ISRs with 79xx series phones. So far, it's been wonderful. I think it's even costing our customers less money and definitely causing less headaches. You get to stick with TAC and Cisco Configuration Professional appears much more stable than CCA if you prefer a GUI.
The other advantage is you can use the latest IOS/CME/CUE & practically every non-SPA phone. The 6900 series has many affordable phones that take the place of that stuff anyway.
It sounds like with the experience you have moving to ISR should not be an issue.
Good luck.
07-28-2011 02:09 PM
I am right there with you David. My biggest issue is this:
Phones Randomly Locking up and becoming unresponsive
This only happens to any of the SPA phones that I install. Any phones from the 79xx line have no issues what so ever. I am to the point that I am about to not sell the UC5xx line and stick with ISR's and 79xx phones.
Also with support. When I had issues with my first install (UC520 w/ 5 phones), I called TAC and was able to get my issues resolved asap as I always got an engineer on the line. Now it seems that when I call Small Business Support, I get a call center rep reading from a script that has no idea what the issue is and it takes weeks to resolve anything.
07-28-2011 03:14 PM
Hi Danial,
I fully understand your sentiment here, although I find myself in a different thought process. If I do not consider giving them some form of management, basic at that even, I will find myself doing so much Gratis work that again your margins (Bottom Line) starts to get hit, not a good thing for the boss to see
Oh never even scraped the sides of the issues that are being faced, I dont even think the forum would allow such a long post
Never have I seen Cisco in a Rutt like this, and every single angle I look at this with, it all seems to stem from the the 3 main issues... SPA-500 Series phones, Incompatibilities between published applications (CCA/OM/SCC), and what appears to be but may not in fact be, Lack of QA on the CUE more so than the CME prior to release, CME/CUE version 7.1 seemed to be the start of this spiral effect.
However in saying that, the admiration and respect is given for Cisco's ability to quickly turn out updates to resolve it, but it still begs the question, why a reactive approach and not a pro-active one??
Hi Thomas,
There is actually very little differences between the UC-500 series and say the 2800 ISR or 2900 series ISR's, fundamentally the CME's are practically the same excluding any UC-500 series specific functionality, and I guess greater capacity to do things like VPN and larger Dial-Plans and more users, the rest are quite close.
I am of the opinion that the UC-500's are brilliant and if not the best at least close to being the market leaders in SOHO/SME systems, but their flaws are frustrating, and I can only put this down to potentially a new breed of programmers/developers, that maybe do not hold the old candle of the way to do things... I am certain CCA has a memory leak in its Java code.
The most hardest issue for me to talk about, and I guess because at times I have a bad habit of polarizing people indirectly and non-intentionally. In the dealings I have had with SBCS support, 80% of them have been a pleasant experience, but the same could be said with TAC as well, NOT always did I have a wonderful experience with TAC either, ocasionally getting a CCIE certified person who actually had very little clue about voice fundamentals, but were very proficient with data, they were very destructive and the ending of the conversation seemed more productive than continuing it with them.
I guess my concerns are that these forums seem to have lost the old school boys who were so damn proactive and worked endlessly to resolve issues, with the advent of CCA becoming the predominant method of programming the systems, these old school people have deserted the forums, and now Steve hovering in the shadows and not formally a Cisco Employee, we are down to 2 maybe 3 tops old school who know the community intimately and understand what we go through in the cold face of the customer.. Harsh yes I know but sadly I believe it to be true... The old school boys know who they are so no need to name them.
My fears every day seem to be coming to past, and now with the culling of 6500 emplyees, I fear they will remove those with the most experience but yet MOSTLY under valued and not appreciated for their comitment to the company and the partners/customers alike... I truly hope this does not happen, it will be a devastating blow to ones confidence in Cisco performing as they have in the past.
Cheers,
David.
07-28-2011 05:40 PM
Hi David,
First of all, thank you for taking time to let us know about the issues you have came across in the last couple of months. We really appreciate your candor, and hope to work together with you to get to the bottom of this.
I will try to address some of the points related to CCA/OM, and I have reached out to my UC500/SPA colleagues and asked them to chime in regarding the other concerns you outlined below.
First Issue:
Did you happen to save a CCA application log for this issue? Especially because this issue is random, it would be good to take a look at the logs and see what may be happening with the system. The best approach, in cases like these, would be to collect the logs as soon as the issue appears for the first time (or resurfaces). Even if you don't call SBSC and open a case right away, at least you have some hard evidence of what was happening, and you can refer to it later.
In many cases, SBSC team can pin point the issue or escalate to CCA engineering team if the logs are collected.
Third Issue:
The slowness of OM, as you pointed out, has to do with the fact that OM has to access every user voicemail box on the system (CUE) one at a time, and then load that configuration. This performance issue should be addressed on the CUE side, as it is also the reason why CCA is sometimes slow (taking 30-45 secs to load Users and Phones window is one of the examples).
Early next week, we are releasing maintenance release for Office Manager, and I believe it should address the time-out issue that you mentioned. I would like to get your feedback on this OM release and find out if it addresses the time-out issue for your customers or not.
OM reporting a phone being down when in fact it is up and running is something I haven't heard before. Let me talk to the OM engineering team if they have any ideas as to what might be happening, and I'll get back to you on it early next week.
Sincerely,
Anna
07-28-2011 05:49 PM
Hi Anna,
I will see if CCA has saved any logs, not sure if it does this automatically and date/time stamps it, but if there are logs there I will scroll through it and start picking it apart.
What ever I can do to help you guys out with narrowing down on these issues I will, I don't care if I have to spend personal time on it, if it means making CCA better you have my attention
Will post up the logs if they are there and produce the results needed to help out...
Cheers,
David.
08-01-2011 12:49 PM
Hi David,
Just wanted to check back with you if you were able to find any relevant CCA logs to help us understand the issues you ran into recently?
You can send the logs directly to me: atsukerm@cisco.com
Anna
08-01-2011 02:46 PM
Hi Anna,
I searched for the logs and I cannot seem to find them, and I think I know what the problem is
I upgraded CCA 3.0.1 to 3.1 and didn't make a copy of the logs in the directory, everything seems to have been re-arranged and there is only 1 log file present now, so it would seem the upgrade procedure removes files from within the directory when you do an upgrade.
I am going out to see the client today, If I have to do any work there today and problem arise I will make sure i pass on the logs, although I am not operating on 3.1 no longer 3.0.1
Cheers,
David.
08-01-2011 07:39 PM
Hi David,
Thank you. Please let me know if you come across the same issues again (now with CCA 3.1).
Also, new OM 2.0 release is out. If you get a chance to give it a try, please let me know if it addresses the timeout issue you experienced before.
Thank you,
Anna
08-01-2011 07:53 PM
Hi Anna,
I was just out at the customers site again today and upgraded their OM to version 2.0, it is much worse than the last one
This time it refuses to acknowledge the manual input of the UC's IP address, instead it takes about 80 minutes for it to finish scanning the network to find the UC.
OM then does odd behaviors once you finally manage to get in, for instance under groups (Blast Groups) when you try to remove a user from the group, it just drags over all the users that were previously removed, it then renames them on the fly to "A Column" Ext Number and "B Column" External Number.... I have no idea why, or what this means.
So we made some password changes to the second reception phone just incase it cause a problem (Vacant at the time) and in OM that phones information on the screen just turned to gibberish.. HUH??? I would have laughed although the receptionist is a hard lady and I am sure she would have back handed me so i maintained a stern composure look on my face and then a puzzled one.
I am at a loss, downgrading back to 1.2 was not an option it errored out when trying to reinstall it, to do it I would have to use CCLEANER and remove all existance of OM of the system... I am not in between a rock and a hard place, between this issue and her SPA-525G2 causing instability on the system and constantly rebooting, Cisco is no longer looking like the quality system it was promoted as... I am somewhat deflated at the moment
Anyway will soldier on and tackle each problem one-by-one, I made the mistake of installing OM on a clients system without first testing the latest version on my own back in the office, desperation causes desperate moves which leads to more problems.
Cheers,
David.
08-02-2011 08:29 PM
Hi David,
One of the engineers on our team has looked at your OM comments in regards to the OM 2.0 and the "Third Issue:" from the very first post on this thread.
Regarding OM 2.0 issues you've run into, this is the first time that both he and I hear about this. None of this has beed observed in the testing environment... As to the "Third Issue:" , there may be a solution for this, but we don't want to me guessing.
What is really needed to diagnose the problem is real OM logs with debug turned on, without the logs we can only guess and speculate as to what the problem is. Can you please email me these logs?
Here are the steps to create the debug log file we need (they are also listed in the OM Installation guide as well as the OM help under the section “Setting Debug Options and Creating Log Files for Troubleshooting”).
I have listed the instruction below.
Follow the steps in this section to clear Office Manager logs, set trace levels for debugging, and collect log files that can be submitted to Cisco Small Business Support for troubleshooting. Office Manager usually runs at the normal trace level, which only allows errors to be placed in the log files. These log files are stored in the Office Manager installation directory. Log files
begin with “Cisco-OM-Log-” and have a timestamp and a .txt extension (for example, Cisco-OM-Log-2010-08-19-15-54-41.txt). Log files are kept for 7 days (older log files are deleted). The maximum size for a single log file is 1.99 GB. When the maximum log file size is reached, a new file is created.
To set debug trace options and gather more detailed log files, follow these steps.
STEP 1 Launch Office Manager and click the Advanced Settings link at the top of the page.
STEP 2 Locate the Cisco Support Options under the Miscellaneous section on the page.
STEP 3 Click Clear Logs.
STEP 4 Click Set Debug Trace to set the debug trace level so that additional information can be collected when the problem occurs.
STEP 5 Close Office Manager.
STEP 6 Restart Office Manager.
STEP 7 Re-create the problem.
STEP 8 After you are finished re-creating the problem, click Set Normal Trace to set the trace level back to Normal.
CAUTION It is very important that you set the trace level back to Normal. When
the trace level is set to Debug, the log files that are generated can grow rapidly
and consume a large amount of disk space.
STEP 9 Exit Office Manager.
STEP 10 On the PC running Office Manager, go to the Office Manager installation directory.
The default installation location is
C:\Program Files\Cisco Small Business Office Manager
(supported 32-bit Windows operating systems)
or
C\Program Files (x86)\Cisco Small Business Office Manager
(supported 64-bit Windows operating systems)
STEP 11 Collect all of the log file(s) that begin with “Cisco-OM-LOG”.
STEP 12 Create a .zip file that contains all of the log files and submit it as directed by Cisco Small Business Support.
Thank you,
Anna
08-02-2011 08:37 PM
Hi Anna,
I'll gather all this for you, from how many machines do you want me to do this?? I have more than one client and even ourselves have hit this issue ... Actually all of them
I will start the logs as soon as I can do a remote desktop session with the receptionist, she gets cranky at me when I disturb her so I have to time it right.
Shall have you something soon though.
Cheers,
David.
08-02-2011 09:00 PM
Hi David,
As many logs as you can gather comfortably without disturbing receptionists too much .
Anna
