06-09-2011 02:10 PM - edited 03-21-2019 09:36 AM
Hi All!
I have a problem with my WRP400 WAN-to-LAN speed no more than 48Mbit/s incoming and up to 42-45 MBit/s outgoing.
My connection is 100/100 Mbit/s, Firmware 2.00.26 , OS Win 7 Ultimate.
QoS disabled, VoIP not in use.
Is there any possibility to increase speed?
Thanks in advance.
06-10-2011 02:12 AM
Hi, I've more than 2000 WRP400s 2.00.26 in my network.
Your speed values are exactly the same that I've registered to my customers.
In my cases these are satisfactory values.
In my opinion these are the maximum performance of WRP devices.
Regards.
12-08-2014 08:19 AM
Hi, I have the same problem.
I have WRP400 (firmware 2.00.32 - I try all firmware).
Now my connection is 100/10 Mbit/s.
Directly connecting the modem to the computer I get the maximum speed 100 Mbit/s download and 10 Mbit/s upload.
By connecting the router I get up to speed 47Mbit/s download and 10 Mbit/s upload.
www.speedtest.net/my-result/3969122353
In the router settings (SETUP / ADVANCED SETTINS) when the change parameter "WAN Phy Flow Control" to 100 half, the results are the same. When I change to 100 full I get speed for 10.
I thing the option 100FULL is not working. Only 100 HALF.
