adelaide incorrect timezone
stephen
I have setup several UC520 systems with CCA 2.2 and everytime I choose Adelaide/Australia timezone it sets incorrect timezone settings in CME.
clock timezone ADT 9 30
clock summer-time ADT recurring last Sun Oct 2:00 last Sun Mar 3:00
Both of these are incorrect as the correct settings should be
clock timezone CST 9 30
clock summer-time CST recurring 1 Sun Oct 2:00 1 Sun Apr 3:00
Unless I'm doing something wrong? Apologies if this has already been discussed but I could not find any similar issue when searching.
Stephen
David Trad
Hi Stephen,
This is what i use when determining the time on the UC, i change it via CLI not sure how CCA would do it has i have never checked, but it is on my list now :)
http://www.timeanddate.com/library/abbreviations/timezones/
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
David Harper
Hi Stephen,
Can you please log a case for this.  The SBSC engineer will then log a bug to get CCA fixed.  In the meantime, the use of CLI is the only option to change the timezone/summer time behaviour.
Cheers,
Dave.
