call voicemail extension
ggirodda87
I use spa502g ip phone with spa500s connect to an asterisk server. I want to know, how I can call the voicemail of extension 7999 directly without the choice of the extension? I try to insert
fnc=sd+cp+blf;sub=*987999@pbxIp
in the attendant console, but it's the same than when I call *98 without the number of extension...
Thank you and sorry for my bad english
Ok, I try with fnc=sd;ext=*987999@myIp but it still doesn't works, I always be redirect to simple *98 service.
7.5.2
You should consider to upgrade firmware to something more recent.
(*xx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
Everything is clear now. It seems you should teach something about "Dial Plan" configuration option. If only one pattern match and has been matched completely, the number is considered complete and dialed. Let's allow me to analyze your case number by number:
Digits collected so far
Dial Plan matching state
*Only one pattern matches, but not completely. Wait for more digits (up to Interdigit_Long_Timeout)
*9
*98
Only one pattern matches and matches completely (the *xx). Number completed. Dialing comitted
Rest of number si ignored.
Try this Dial Plan:
(*xx|*98xxxx|[3469]11|0|00|[2-9]xxxxxx|1xxx[2-9]xxxxxxS0|xxxxxxxxxxxx.)
Also note this excelent document: Explaining Dial Plans
Mark response as correct answer if it solve your problem.
11 Replies 11
Dan Lukes
May be I just don't understand your question correctly, but
  1. why are you configuring sub=*987999 when you want to call maibox and mailbox number is 7999 not *987999 ?
  2. why you are not using button dedicated to access to mailbox ? See number 7 on picture below. Note that phone number of mailbox should be configured into "Voice Mail Number" option of "Phone" tab section "General"
http://motioncommunications.co.uk/wp-content/uploads/SPA-502G.jpg
ggirodda87
The *98 number is used to enter in the general asterisk voicemail, for example to access user 7999 voicemail I call *987999 that is voicemail number + user number. When I call this number with any internal phone I can access the user 7999 voicemail, but if I register in the attendant console fnc=sd+cp+blf;sub=*987999@pbxIp
I get the same thing than when I call the only *98 number,
so I enter in the general voicemail, not in the user 7999 one.
I already use the Cisco voicemail default button to call the number *97 to access the cisco extension voicemail, user 7999 is for general messages
Thank you
OK
I assume you deconfigured *98 as service code of blind transfer in the phone (tab "regional" section "Vertical Service Activation Codes")
What I don't know is the detail of implementation within asterisk. Access code *98 7999 may mean either true access number or access code *98 followed by 7999 transmitted as DTMF. If you don't know what I'm speaking about catch the SIP communication between phone and Asterisk during call to general messages voicemail. The INVITE message is the message that interests me.
This is the log during a call between extension 7006 and 7999 voicemail make from my iphone with zoiper application, thank you for your help
<--- SIP read from UDP:192.168.1.27:45045 --->
INVITE sip:*987999@192.168.1.31;transport=UDP SIP/2.0
Via: SIP/2.0/UDP myExternalIp:45045;branch=z9hG4bK-d8754z-22c15f9e82446736-1---d8754z-;rport
Max-Forwards: 70
Contact: <7006>
To: <>
Call-ID: ZjhjZjhhYWVlZjYyODg0NGQ1Y2IzMzgzYjZkNzlhMDk.
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, BYE, NOTIFY, REFER, MESSAGE, OPTIONS, INFO, SUBSCRIBE
Content-Type: application/sdp
Supported: replaces, norefersub, extended-refer, timer, X-cisco-serviceuri
User-Agent: Zoiper r19016
Allow-Events: presence, kpml
Content-Length: 238
v=0
o=Z 0 0 IN IP4 myExternalIp
s=Z
c=IN IP4 myExternalIp
t=0 0
m=audio 32538 RTP/AVP 3 110 98 8 0 101
a=rtpmap:110 speex/8000
a=rtpmap:98 iLBC/8000
a=fmtp:98 mode=20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: --- (14 headers 12 lines) ---
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: Sending to 192.168.1.27:45045 (NAT)
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Sending to 192.168.1.27:45045 (NAT)
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Using INVITE request as basis request - ZjhjZjhhYWVlZjYyODg0NGQ1Y2IzMzgzYjZkNzlhMDk.
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found peer '7006' for '7006' from 192.168.1.27:45045
<--- Reliably Transmitting (NAT) to 192.168.1.27:45045 --->
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP myExternalIp:45045;branch=z9hG4bK-d8754z-22c15f9e82446736-1---d8754z-;received=192.168.1.27;rport=45045
To: <>;tag=as2c451c2d
CSeq: 1 INVITE
Server: FPBX-2.11.0(11.4.0)
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="552f73f9"
Content-Length: 0
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Scheduling destruction of SIP dialog 'ZjhjZjhhYWVlZjYyODg0NGQ1Y2IzMzgzYjZkNzlhMDk.' in 6400 ms (Method: INVITE)
ACK sip:*987999@192.168.1.31;transport=UDP SIP/2.0
Max-Forwards: 70
CSeq: 1 ACK
Content-Length: 0
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: --- (8 headers 0 lines) ---
Via: SIP/2.0/UDP myExternalIp:45045;branch=z9hG4bK-d8754z-8168df8f25abea3a-1---d8754z-;rport
Max-Forwards: 70
Contact: <7006>
To: <>
CSeq: 2 INVITE
Authorization: Digest username="7006",realm="asterisk",nonce="552f73f9",uri="sip:*987999@192.168.1.31;transport=UDP",response="614b5226b49bc2f4f39fd5707f6480b9",algorithm=MD5
Content-Length: 238
v=0
s=Z
t=0 0
a=fmtp:98 mode=20
a=fmtp:101 0-15
a=sendrecv
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: --- (15 headers 12 lines) ---
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] netsock2.c: == Using SIP RTP TOS bits 184
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] netsock2.c: == Using SIP RTP CoS mark 5
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found RTP audio format 3
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found RTP audio format 110
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found RTP audio format 98
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found RTP audio format 8
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found RTP audio format 0
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found RTP audio format 101
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found audio description format speex for ID 110
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found audio description format iLBC for ID 98
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Found audio description format telephone-event for ID 101
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Capabilities: us - (gsm|ulaw|alaw), peer - audio=(gsm|ulaw|alaw|speex|ilbc)/video=(nothing)/text=(nothing), combined - (gsm|ulaw|alaw)
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Non-codec capabilities (dtmf): us - 0x1 (telephone-event|), peer - 0x1 (telephone-event|), combined - 0x1 (telephone-event|)
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Peer audio RTP is at port myExternalIp:32538
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: Looking for *987999 in from-internal (domain 192.168.1.31)
[2013-09-14 11:53:34] VERBOSE[1833][C-0000004c] chan_sip.c: list_route: hop: <7006>
<--- Transmitting (NAT) to 192.168.1.27:45045 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP myExternalIp:45045;branch=z9hG4bK-d8754z-8168df8f25abea3a-1---d8754z-;received=192.168.1.27;rport=45045
To: <>
CSeq: 2 INVITE
Session-Expires: 1800;refresher=uas
Contact: <>
Content-Length: 0
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] pbx.c: -- Executing [*987999@from-internal:1] Answer("SIP/7006-00000080", "") in new stack
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] chan_sip.c: Audio is at 10026
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] chan_sip.c: Adding codec 100003 (ulaw) to SDP
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] chan_sip.c: Adding codec 100004 (alaw) to SDP
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] chan_sip.c: Adding codec 100002 (gsm) to SDP
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] chan_sip.c: Adding non-codec 0x1 (telephone-event) to SDP
SIP/2.0 200 OK
To: <>;tag=as2f227118
CSeq: 2 INVITE
Contact: <>
Require: timer
Content-Length: 278
v=0
o=root 24814030 24814030 IN IP4 192.168.1.31
s=Asterisk PBX 11.4.0
c=IN IP4 192.168.1.31
t=0 0
m=audio 10026 RTP/AVP 0 8 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: Retransmitting #1 (NAT) to 192.168.1.27:45045:
SIP/2.0 200 OK
CSeq: 2 INVITE
Contact: <>
Require: timer
Content-Length: 278
v=0
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
<--- SIP read from UDP:212.27.52.5:5060 --->
Cirpack KeepAlive Packet
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: Retransmitting #2 (NAT) to 192.168.1.27:45045:
SIP/2.0 200 OK
CSeq: 2 INVITE
Contact: <>
Require: timer
Content-Length: 278
v=0
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
ACK sip:*987999@192.168.1.31:5060 SIP/2.0
Via: SIP/2.0/UDP myExternalIp:45045;branch=z9hG4bK-d8754z-262de34169506106-1---d8754z-;rport
Max-Forwards: 70
Contact: <7006>
CSeq: 2 ACK
Content-Length: 0
[2013-09-14 11:53:34] VERBOSE[1833] chan_sip.c: --- (11 headers 0 lines) ---
Max-Forwards: 70
Contact: <7006>
CSeq: 2 ACK
Content-Length: 0
Max-Forwards: 70
Contact: <7006>
CSeq: 2 ACK
Content-Length: 0
[2013-09-14 11:53:34] VERBOSE[589][C-0000004c] pbx.c: -- Executing [*987999@from-internal:2] Wait("SIP/7006-00000080", "1") in new stack
[2013-09-14 11:53:35] VERBOSE[1833] chan_sip.c:
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] pbx.c: -- Executing [*987999@from-internal:3] Macro("SIP/7006-00000080", "get-vmcontext,7999") in new stack
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] pbx.c: -- Executing [s@macro-get-vmcontext:1] Set("SIP/7006-00000080", "VMCONTEXT=default") in new stack
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] pbx.c: -- Executing [s@macro-get-vmcontext:2] GotoIf("SIP/7006-00000080", "0?200:300") in new stack
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] pbx.c: -- Goto (macro-get-vmcontext,s,300)
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] pbx.c: -- Executing [s@macro-get-vmcontext:300] NoOp("SIP/7006-00000080", "") in new stack
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] pbx.c: -- Executing [*987999@from-internal:4] VoiceMailMain("SIP/7006-00000080", "7999@default") in new stack
[2013-09-14 11:53:35] VERBOSE[589][C-0000004c] file.c: -- Playing 'vm-youhave.alaw' (language 'fr')
OK, so *987999 is the complete access number. Now we need to see INVITE packet generated by your phone when you push the button on console. It should generate INVITE to *987999 as well. If not, it's because:
  1. incorrect button definition (try fnc=sd;ext=*987999@pbxIp instead)
  2. *98 is defined as special prefix somewhere or incorrect dial plan - we need to inspect configuration of phone, e.g. content of
    http:///admin/spacfg.xml
This is my spacfg.xml
Static IP
192.168.100.242
ciscospa502g
255.255.255.0
192.168.100.254
212.27.40.240
212.27.40.241
SPA502G
CCQ17040C92
7.5.2
1.0.4
E02F6D629A01
Installed
Open
None
9/17/2013 15:56:22
00:13:44
670
67029
48160
211
33760
40
19601
39
22350
N/A
100M Full Duplex
Link Down
Registered
9/17/2013 15:54:21
113 s
No
Idle
None
G711u
G711u
Outbound
No
*98
00:00:01
301
211
48160
33760
70 ms
0 ms
Not Available
0 ms
0 ms
0 ms
Idle
None
Idle
Not Installed
Not Installed
Not Installed
Yes
80
Yes
SIP
Yes
No
No
Normal
Static IP
192.168.100.242
255.255.255.0
192.168.100.254
ciscospa502g
212.27.40.240
212.27.40.241
Manual
Parallel
No
No
Yes
No
Yes
Yes
No Limit
No
$VERSION
$VERSION
application/dtmf-relay
application/hook-flash
No
No
No
No
No
No
No
No
Yes
No
Yes
5060
5080
No
PAID-RPID-FROM
x-sipura
No
No
No
No
.5
16
16
16
16
240
30
30
1200
10040
0.020
No
No
No
101
98
97
99
112
113
G711u
telephone-event
PCMU
PCMA
G726-16
G726-24
G726-32
G726-40
G729a
G729ab
G722
encaprtp
No
No
No
No
No
No
No
No
15
No
No
224.168.168.168:6061
Yes
none
Yes
Yes
Yes
3600
3600
14400
Yes
Yes
Yes
/spa$PSN.cfg
66,160,159,150,60,43,125
https
$PN $MAC -- Requesting resync $SCHEME://$SERVIP:$PORT$PATH
$PN $MAC -- Successful resync $SCHEME://$SERVIP:$PORT$PATH
$PN $MAC -- Resync failed: $ERR
Yes
Yes
3600
$PN $MAC -- Requesting upgrade $SCHEME://$SERVIP:$PORT$PATH
$PN $MAC -- Successful upgrade $SCHEME://$SERVIP:$PORT$PATH -- $ERR
$PN $MAC -- Upgrade failed: $ERR
350@-19,440@-19;10(*/0/1+2)
420@-16;10(*/0/1)
520@-19,620@-19;10(*/0/1+2)
480@-19,620@-19;10(.5/.5/1+2)
480@-19,620@-19;10(.25/.25/1+2)
480@-10,620@0;10(.125/.125/1+2)
440@-19,480@-19;*(2/4/1+2)
440@-10;30(.3/9.7/1)
600@-16;1(.25/.25/1)
985@-16,1428@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)
914@-16,1371@-16,1777@-16;20(.274/0/1,.274/0/2,.380/0/3,0/4/0)
914@-16,1371@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)
985@-16,1371@-16,1777@-16;20(.380/0/1,.274/0/2,.380/0/3,0/4/0)
350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)
350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)
600@-19;25(.1/.1/1,.1/.1/1,.1/9.5/1)
350@-19;20(.1/.1/1,.1/9.7/1)
397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)
600@-16;.3(.05/0.05/1)
600@-19;.2(.05/0.05/1)
60(2/4)
60(.3/.2,1/.2,.3/4)
60(.8/.4,.8/4)
60(.4/.2,.3/.2,.8/4)
60(.2/.2,.2/.2,.2/.2,1/4)
60(.2/.4,.2/.4,.2/4)
60(4.5/4)
60(0.25/9.75)
60(.4/.2,.4/2)
255
1800
30
.5
*69
*66
*86
*72
*73
*90
*91
*92
*93
*56
*57
*71
*70
*67
*68
*81
*82
*77
*87
*78
*79
*16
*17
*18
*19
*96
*38
*36
*39
*37
*03
*017110
*027110
*017111
*027111
*01722
*02722
*0172616
*0272616
*0172624
*0272624
*0172632
*0272632
*0172640
*0272640
*01729
*02729
GMT+01:00
Yes
Yes
-16
.1
12dB
ISO-8859-1
en-US
CISCOSPA502G
CISCOSPA502G
*97
Default
Text Logo
Auto
No
300
Background Picture
$USER
private
Scrollable
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Yes
No
n=Classic-1;w=3;c=1
n=Classic-2;w=3;c=2
n=Classic-3;w=3;c=3
n=Classic-4;w=3;c=4
n=Simple-1;w=2;c=1
n=Simple-2;w=2;c=2
n=Simple-3;w=2;c=3
n=Simple-4;w=2;c=4
n=Simple-5;w=2;c=5
n=Office;w=4;c=1
n=Pulse;w=5;c=1
n=Du-dut;w=6;c=1
pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;
No
Enterprise
No
None
Trusted
No
No
em_login|1;acd_login|1;acd_logout|1;astate|2;avail|3;unavail|3;redial|5;dir|6;cfwd|7;dnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout
lcr|1;miss|4
redial|1;dir|2;cfwd|3;dnd|4;lcr|5;unpark|6;pickup|7;gpickup|8;starcode|11;alpha|12
dial|1;delchar|2;clear|3;cancel|4;left|5;right|6;starcode|7;alpha|8;dir
endcall|2
hold|1;endcall|2;conf|3;xfer|4;toggle;bxfer;confLx;xferLx;park;phold;flash;
hold|1;endcall|2;xfer|4;toggle;
hold|1;endcall|2;conf|3;toggle;
hold|1;endcall|2;join|4
endcall|2;
resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd
answer|1;ignore|2;toggle|4
newcall|1;barge|2;cfwd|3;dnd|4
resume|1;barge|2;cfwd|3;dnd|4
Yes
private
3600
No
No
No
$NOTIFY
$PROXY
0x68
0xb8
6
high
up and down
UDP
5060
No
Yes
No
No
none
No
No
Yes
Yes
none
No
No
No
No
No
No
No
Yes
No
No
192.168.100.240
No
Yes
Yes
No
300
No
No
No
3600
Normal
No
CISCO
8001
No
G711u
No
G711a
Unspecified
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
No
Auto
No
Default
Yes
No
20
Yes
No
No
No
No
No
Yes
Speaker
No
12hr
month/day
Yes
Yes
automatic
source
media
Yes
No
No
Yes
Yes
9
8
Auto
Default
Yes
8
10 s
1800
30
Yes
Yes
Asterisk
No
*8
*68
*88
Yes
12
7
fnc=sd+cp+blf;sub=8001@192.168.100.240
fnc=sd+cp+blf;sub=8008@192.168.100.240
fnc=sd;ext=*987999@192.168.100.240
and this is the log of the call in asterisk
[2013-09-17 16:42:40] VERBOSE[32523] chan_sip.c: --- (8 headers 0 lines) ---
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c:
<--- SIP read from UDP:192.168.100.242:5060 --->
INVITE sip:*98@192.168.100.240 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-834fc996
To: <>
Call-ID: aec7f1e6-31a08809@192.168.100.242
CSeq: 101 INVITE
Max-Forwards: 70
Contact: "CISCO" <8001>
Expires: 240
User-Agent: Cisco/SPA502G-7.5.2
Content-Length: 397
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
Supported: replaces
v=0
o=- 3640 3640 IN IP4 192.168.100.242
s=-
c=IN IP4 192.168.100.242
t=0 0
m=audio 10035 RTP/AVP 0 8 2 9 18 96 97 98 101
a=rtpmap:2 G726-32/8000
a=rtpmap:9 G722/8000
a=rtpmap:18 G729a/8000
a=rtpmap:96 G726-40/8000
a=rtpmap:97 G726-24/8000
a=rtpmap:98 G726-16/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c: --- (14 headers 18 lines) ---
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c: Sending to 192.168.100.242:5060 (NAT)
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Sending to 192.168.100.242:5060 (NAT)
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Using INVITE request as basis request - aec7f1e6-31a08809@192.168.100.242
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found peer '8001' for '8001' from 192.168.100.242:5060
<--- Reliably Transmitting (NAT) to 192.168.100.242:5060 --->
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-834fc996;received=192.168.100.242;rport=5060
To: <>;tag=as09f233a1
CSeq: 101 INVITE
Server: FPBX-2.11.0(11.5.0)
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="2847dbe8"
Content-Length: 0
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Scheduling destruction of SIP dialog 'aec7f1e6-31a08809@192.168.100.242' in 6400 ms (Method: INVITE)
ACK sip:*98@192.168.100.240 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c: --- (10 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-6132ab66
To: <>
CSeq: 102 INVITE
Max-Forwards: 70
Authorization: Digest username="8001",realm="asterisk",nonce="2847dbe8",uri="sip:*98@192.168.100.240",algorithm=MD5,response="f4a1ef5ed0d7e5bec2c603a783fe04ff"
Expires: 240
Content-Length: 397
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c: --- (15 headers 18 lines) ---
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] netsock2.c: == Using SIP RTP TOS bits 184
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] netsock2.c: == Using SIP RTP CoS mark 5
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 0
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 8
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 2
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 9
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 18
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 96
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 97
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 98
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found RTP audio format 101
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found audio description format PCMU for ID 0
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found audio description format PCMA for ID 8
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found audio description format G726-32 for ID 2
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found audio description format G722 for ID 9
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found audio description format G729a for ID 18
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found unknown media description format G726-40 for ID 96
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found unknown media description format G726-24 for ID 97
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found unknown media description format G726-16 for ID 98
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Found audio description format telephone-event for ID 101
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Capabilities: us - (gsm|ulaw|alaw), peer - audio=(ulaw|alaw|g726|g729|g722)/video=(nothing)/text=(nothing), combined - (ulaw|alaw)
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Non-codec capabilities (dtmf): us - 0x1 (telephone-event|), peer - 0x1 (telephone-event|), combined - 0x1 (telephone-event|)
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Peer audio RTP is at port 192.168.100.242:10035
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: Looking for *98 in from-internal (domain 192.168.100.240)
[2013-09-17 16:42:46] VERBOSE[32503] chan_sip.c: set_destination: Parsing <8001> for address/port to send to
[2013-09-17 16:42:46] VERBOSE[32503] chan_sip.c: set_destination: set destination to 192.168.100.242:5060
[2013-09-17 16:42:46] VERBOSE[32503] chan_sip.c: Reliably Transmitting (NAT) to 192.168.100.242:5060:
NOTIFY sip:8001@192.168.100.242:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.240:5060;branch=z9hG4bK5b2eaf36;rport
Max-Forwards: 70
To: "CISCO" <8001>;tag=4b051e1ec62e863d
Contact: <8001>
Call-ID: 892e5072-ae14d7f9@192.168.100.242
CSeq: 103 NOTIFY
User-Agent: FPBX-2.11.0(11.5.0)
Subscription-State: active
Event: dialog
Content-Type: application/dialog-info+xml
Content-Length: 207
confirmed
[2013-09-17 16:42:46] VERBOSE[32503] chan_sip.c: == Extension Changed 8001[ext-local] new state InUse for Notify User 8001
[2013-09-17 16:42:46] VERBOSE[32523][C-00000006] chan_sip.c: list_route: hop: <8001>
<--- Transmitting (NAT) to 192.168.100.242:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-6132ab66;received=192.168.100.242;rport=5060
To: <>
CSeq: 102 INVITE
Contact: <>
Content-Length: 0
[2013-09-17 16:42:46] VERBOSE[32747][C-00000006] pbx.c: -- Executing [*98@from-internal:1] Answer("SIP/8001-00000008", "") in new stack
[2013-09-17 16:42:46] VERBOSE[32747][C-00000006] chan_sip.c: Audio is at 10032
[2013-09-17 16:42:46] VERBOSE[32747][C-00000006] chan_sip.c: Adding codec 100003 (ulaw) to SDP
[2013-09-17 16:42:46] VERBOSE[32747][C-00000006] chan_sip.c: Adding codec 100004 (alaw) to SDP
[2013-09-17 16:42:46] VERBOSE[32747][C-00000006] chan_sip.c: Adding non-codec 0x1 (telephone-event) to SDP
SIP/2.0 200 OK
To: <>;tag=as466725aa
CSeq: 102 INVITE
Contact: <>
Content-Length: 265
v=0
o=root 2104859674 2104859674 IN IP4 192.168.100.240
s=Asterisk PBX 11.5.0
c=IN IP4 192.168.100.240
t=0 0
m=audio 10032 RTP/AVP 0 8 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 103 NOTIFY
Server: Cisco/SPA502G-7.5.2
Content-Length: 0
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c: --- (8 headers 0 lines) ---
ACK sip:*98@192.168.100.240:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-e8d91c8c
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
[2013-09-17 16:42:46] VERBOSE[32523] chan_sip.c: --- (11 headers 0 lines) ---
[2013-09-17 16:42:46] VERBOSE[32747][C-00000006] pbx.c: -- Executing [*98@from-internal:2] Wait("SIP/8001-00000008", "1") in new stack
[2013-09-17 16:42:47] VERBOSE[32747][C-00000006] pbx.c: -- Executing [*98@from-internal:3] NoOp("SIP/8001-00000008", "app-dialvm: Asking for mailbox") in new stack
[2013-09-17 16:42:47] VERBOSE[32747][C-00000006] pbx.c: -- Executing [*98@from-internal:4] Read("SIP/8001-00000008", "MAILBOX,vm-login,,,3,2") in new stack
[2013-09-17 16:42:47] VERBOSE[32747][C-00000006] file.c: -- Playing 'vm-login.gsm' (language 'fr')
[2013-09-17 16:42:50] VERBOSE[32523] chan_sip.c: Really destroying SIP dialog '7a755620-6e12d2fa@192.168.100.150' Method: REGISTER
[2013-09-17 16:42:51] VERBOSE[32523] chan_sip.c: Really destroying SIP dialog 'dcd8f7d2-aeeb4cf0@192.168.100.150' Method: REGISTER
[2013-09-17 16:42:52] VERBOSE[32523] chan_sip.c:
BYE sip:*98@192.168.100.240:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-def5f005
CSeq: 103 BYE
Max-Forwards: 70
Authorization: Digest username="8001",realm="asterisk",nonce="2847dbe8",uri="sip:*98@192.168.100.240:5060",algorithm=MD5,response="8a4e6470356a8e1ea82eb36413e682cf"
Content-Length: 0
[2013-09-17 16:42:52] VERBOSE[32523] chan_sip.c: --- (10 headers 0 lines) ---
[2013-09-17 16:42:52] VERBOSE[32523][C-00000006] chan_sip.c: Sending to 192.168.100.242:5060 (NAT)
[2013-09-17 16:42:52] VERBOSE[32523][C-00000006] chan_sip.c: Scheduling destruction of SIP dialog 'aec7f1e6-31a08809@192.168.100.242' in 6400 ms (Method: BYE)
SIP/2.0 200 OK
Via: SIP/2.0/UDP 192.168.100.242:5060;branch=z9hG4bK-def5f005;received=192.168.100.242;rport=5060
CSeq: 103 BYE
Content-Length: 0
[2013-09-17 16:42:52] VERBOSE[32747][C-00000006] app_read.c: -- User disconnected
[2013-09-17 16:42:52] VERBOSE[32747][C-00000006] pbx.c: -- Executing [h@from-internal:1] Hangup("SIP/8001-00000008", "") in new stack
[2013-09-17 16:42:52] VERBOSE[32747][C-00000006] pbx.c: == Spawn extension (from-internal, h, 1) exited non-zero on 'SIP/8001-00000008'
[2013-09-17 16:42:52] VERBOSE[32503] chan_sip.c: set_destination: Parsing <8001> for address/port to send to
[2013-09-17 16:42:52] VERBOSE[32503] chan_sip.c: set_destination: set destination to 192.168.100.242:5060
[2013-09-17 16:42:52] VERBOSE[32503] chan_sip.c: Reliably Transmitting (NAT) to 192.168.100.242:5060:
Via: SIP/2.0/UDP 192.168.100.240:5060;branch=z9hG4bK60445d1d;rport
Max-Forwards: 70
Contact: <8001>
CSeq: 104 NOTIFY
Event: dialog
Content-Length: 208
terminated
[2013-09-17 16:42:52] VERBOSE[32503] chan_sip.c: == Extension Changed 8001[ext-local] new state Idle for Notify User 8001
SIP/2.0 200 OK
CSeq: 104 NOTIFY
Content-Length: 0
[2013-09-17 16:42:52] VERBOSE[32523] chan_sip.c: --- (8 headers 0 lines) ---
[2013-09-17 16:42:58] VERBOSE[32523] chan_sip.c: Really destroying SIP dialog 'aec7f1e6-31a08809@192.168.100.242' Method: BYE
[2013-09-17 16:43:02] VERBOSE[32744] asterisk.c: -- Remote UNIX connection disconnected
Thank you
7.5.2
*9
*98
Try this Dial Plan:
Thank you!!!!
Nice to hear it work now.
Note that you should develop your own Dial Plan that fit your local numbering plan as well as outside national calls and international calls. The default Dial Plan is designed for US and may not fit your needs.
By the way, the standard codec for the France PSTN is aLaw (PCMA), so you should prefer it against uLaw. uLaw calls terminated in PSTN need transcoding which may distort a sound somewhat.
You should change the configuration of your phones as well as the configuration of FreePBX.
Yes, I will do that. Thank you
