09-10-2010 10:02 AM - edited 03-21-2019 02:59 AM
All,
I have configured the UC540 FXS with 2 user and 2 fax type extensions.
All the FXS ports can call the IP Sets.
However whenever an IP Set or Analog set tries to call an Analog set I just get a busy tone.
Nothing can call my analog sets.
I'm guessing I'm missing something in the config.
I'd appreciate any pointers.
Chris
09-10-2010 11:33 AM
Hi Chris,
Did you use TSW (Telephpony Setup Wizard) to configure FXS analog stations?
Did you configure them as User Mode?
What extensions did you assign them?
Steve
09-10-2010 02:12 PM
Here's the current config:
Port Role Sig Ext
0/0/0 User LS 221
0/0/1 FAX LS 222
0/0/2 User LS 223
0/0/3 User LS 224
Chris
09-10-2010 06:50 PM
Ok, now check to see that there is one, and only one ephone-dn for each user mode analog phone.
If you have more that one, we need to remove one.
09-13-2010 07:52 PM
how did this end up?
