08-07-2011 05:13 AM - edited 03-21-2019 04:28 AM
I am having problems with CCA version 3.0(1) after my laptop goes into hibernation (i.e. I shut the lid and go to the other room). After I press the refresh button (actually it is a GUI button), the router I was recently working on is listed as unavailable. The only way for me go back to what I was doing is to restart the CCA.
Is there a better way?
08-09-2011 09:03 AM
Luke,
This is a MS issue on the way they handle hibernation. I saw the same issue and the only work around is to disable the hibernation mode. If you are working the on CCA, I would increase the time before hibernation starts, this may help you in the short term.
The issue happens when the hibernation disconnects all it's connection, CCA sees this as a shut down or broken connection.
I hope this helps
08-09-2011 12:24 PM
That's right, blame Microsoft. I wish I could use that excuse with my boss.
I have writen numerous apps using Visual Studio connecting to the network. No, this is a problem with the design and implementation a fault tolerant application. MSDN clearly outlines the hibernation procedure and how applications are to handle the condition.
08-09-2011 12:30 PM
I once had a guy named Dave C (protect the innocent) working for me in the early 90's at Siemens and he used to 'hibernate' in his cube. Once I caught him eyes closed. I shook him awake (in those days you were allowed to touch) and he said he was 'thinking' as he wiped the dribble from his chin :-)
LOL
