05-25-2009 01:03 PM - edited 03-21-2019 01:07 AM
Hello everyone,
Is there a easy way to connect a SIP client to the UC520?
by example using ekiga software.
using browser (10.1.10.1) i added a user: jonatan with password:12345 and ext:250
and i try to connect ekiga to 10.1.10.2 server but it cant
what is the easy way to connect it.
thanks.
05-25-2009 04:34 PM
The integration with SIP clients requires CLI directly. Look here for some ideas:
https://supportforums.cisco.com/docs/DOC-9465
Please notice that non-Cisco IP phones (or softphones) are not supported by TAC.
Thanks, Marcos
05-27-2009 04:43 PM
Thanks Marcos
I used the document https://supportforums.cisco.com/docs/DOC-9465 as you said and with some other parameter found in the file attached i configured the UC500 as SIP Server and i have a linksys SPA962 connected and works great.
I cant connect a softphone jet but im working on.
Thank you for your help
