Hi:
How can I recover password for a UC560 to access CLI and/or CCA. I have access to CUE but I need to change some AA configuration.
Solved! Go to Solution.
Follow these steps and you can reset the username and password to access through CLI and CCA.
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/22188-pswdrec-2600.pdf
Chris
Chris
Hermann
