Multisite deployment over a Wan
Joseph Chambers
Can you do a multisite deployment over a WAN (MPLS) or does it have to go through a VPN?
You sure can. The MPLS network is essentially a VPN and is ideal for voice applications. You can choose to use the VPN services on your UC500 devices to provide for extra security if you want.
Cole
So you would need to connect uc520 to the MPLS network via the WAN port on the uc5xx?
Yes
