No call park key in SPA504G 7.4.8 firmware.
rhuang8x8
I did a factory reset and then configure my SIP account.
Here is my connected key list
hold|1;endcall|2;conf|3;xfer|4;toggle;bxfer;confLx;xferLx;park;phold;flash
I believe it's the default value, because I never touched it.
However, it's not showing park while I'm in a call.
I also tried to implement it with programmable key. But don't know besides speed dial, blf and prk.
What else, hold etc, I can use for programmable key function.
Is there any document for programmable key?
Thanks.
Patrick Born
Hi Rui,
The call park you see in the programmable soft keys only works with Cisco call control such as SPA9000 or UC300.
Using 3rd party call control, you need to define a speed dial dial to dial the star code to use your call-control's call park.
Make sure that your phone's vertical service activation codes do not conflict with the star code you're trying to use with call park.
Here's an example of configuring call park with Broadsoft (SIP): https://supportforums.cisco.com/docs/DOC-15426
Asterisk-type configuration is similar to Broadsoft's.
Patrick
   One reference document to locate SPA phone resources
I solved the problem by defining a key with call park star code, by default it's *38. Thanks for your help.
This used to work with REFER to "callpark" extension for park, and INVITE to "pickup" extension for unpark. I managed to comply with that scenario on my ssw. How can I re-enable those settings which used to work < 7.4.7 and work on Linksys SPA9xx?
Ognjen
rhuang8x8
Hi, Patrick
Thanks for your reply. I tried with speed dial programmable key as the document mentioned.
When I push the PSK, it'll send a REFER, This more like a blink transfer, which at the moment
cannot meet my requirment, because I want to announce which spot it's parking at before transfering.
I understand, unlike regular blink transfer, it may require my server do the announcement after
REFER before sending out BYE, but I want to know is there any easier way to do this without much change
on our server side implementation.
Basically I want something more like attendant transfer, put the call on hold, make a new call to
parking number, listen to parking announcement IVR, after finish, the server disconnect it.
Is there anyway that I can define a programmable key that can put the call on hold and open a new line
to speed dial.
Thanks.
