[Problem] Elastix + SPA962 with TLS/SRTP
wosscr001
We're having issues getting the SPA962 phones to work with Elastix 2.2 (Asterisk 1.8.7) using TLS/SRTP.
Server side everything is setup and seems to be working properly as we use Bria as client and it works with TLS/SRTP, but when we swtich the SPA962 phones to TLS as transport it fails.
It gets into a loop and does that forever, I'm not sure why is it checking SIP/TCP and gets disconnected when it checks SIP/TLS it is OK
In the phone's SysLog we can see this:
SIP/TLS:Connect OK
[0:5071]->MY-PBX-IP-ADDRESS:5061{512)
REGISTER sip:MY-PBX-HOST-NAME SIP/2.0
Via: SIP/2.0/TLS MY-LOCAL-IP-ADDRESS:5071;branch=z9hG4bK-86a1cfdb
From: "MY-NAME" <sip:MY-EXTENSION@MY-PBX-HOST-NAME>;tag=40d65ca2d5d8bc84o0
To: "MY-NAME" <sip:MY-EXTENSION@MY-PBX-HOST-NAME>
Call-ID: 146fa03b-89661975@MY-LOCAL-IP-ADDRESS
CSeq: 25006 REGISTER
Max-Forwards: 70
Contact: "MY-NAME" <sip:MY-EXTENSION@MY-LOCAL-IP-ADDRESS:5071;transport=tls>;expires=3600
User-Agent: Linksys/SPA962-6.1.5(a)
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: replaces
[0]SIP TCP server disconnected -257
[0]SIP TCP No Alt Server
[0]SIP/TCP:Connecting...(19)
[0]SIP:RegFailed;Retry in 30s
[0]SIP/TCP:Connect=0
[0]SIP/TLS:Connecting ...
X509 depth=1, code=20
SIP/TLS:Connect OK
[0]SIP TCP Idle
Via: SIP/2.0/TLS MY-LOCAL-IP-ADDRESS:5071;branch=z9hG4bK-3900bb99
CSeq: 25007 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: replaces
Any help will be much appreaciated.
0 Replies 0
